Tu as posté 2 fois le même rapport ..... je n'ai pas le rapport_SX.txt
Infection probable
Re: Infection probable
johnmarcus11
Désolé
All processes killed
Error: Unable to interpret < > in the current context!
Error: Unable to interpret <--------------------------------------------------------------------------------> in the current context!
========== OTL ==========
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{CF34647C-9652-8FD7-75CB-3AA928906563}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CF34647C-9652-8FD7-75CB-3AA928906563}\ not found.
Folder C:\ProgramData\BetterSoft\ not found.
Folder C:\ProgramData\StarApp\ not found.
========== FILES ==========
File\Folder C:\ProgramData\BetterSoft\OptimizerPro not found.
< ipconfig /flushdns /c >
Configuration IP de Windows
Cache de r‚solution DNS vid‚.
C:\Users\JM\Desktop\cmd.bat deleted successfully.
C:\Users\JM\Desktop\cmd.txt deleted successfully.
========== COMMANDS ==========
[EMPTYTEMP]
User: All Users
User: Default
->Temp folder emptied: 0 bytes
->Temporary Internet Files folder emptied: 0 bytes
User: Default User
User: Default.migrated
User: DefaultAppPool
User: JM
->Temp folder emptied: 1917565 bytes
->Temporary Internet Files folder emptied: 4162252 bytes
->Google Chrome cache emptied: 0 bytes
->Flash cache emptied: 492 bytes
User: Public
%systemdrive% .tmp files removed: 0 bytes
%systemroot% .tmp files removed: 0 bytes
%systemroot%\System32 .tmp files removed: 0 bytes
%systemroot%\System32 (64bit) .tmp files removed: 0 bytes
%systemroot%\System32\drivers .tmp files removed: 0 bytes
Windows Temp folder emptied: 21838 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 0 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 6,00 mb
Restore point Set: OTL Restore Point
OTL by OldTimer - Version 3.2.69.0 log created on 06092013_094858
Files\Folders moved on Reboot...
C:\Users\JM\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
File move failed. C:\WINDOWS\temp\_avast_\Webshlock.txt scheduled to be moved on reboot.
PendingFileRenameOperations files...
Registry entries deleted on Reboot...
[EMPTYTEMP]
User: All Users
User: Default
User: Default User
User: JM
User: Public
Non, désolée ... c'est l'autre rapport qu'il me faut, celui généré par l'outil SXCU.
johnmarcus11
Pourtant,je l'avais pri sur le bureau,piges pas.
J'espère que cette fois,c'est le bon.
SX Check&Update
Lien vers le tutoriel : http://forum.security-x.fr/tutoriels-31 ... eckupdate/
Windows Version : Windows 8 64bits
Aucun Service Pack
UserName : JM
09/06/2013
17:29:02
version = v0.3.3
Windows Update Information :
AUOptions : 2
Notify Download and Install
Nom : Google Chrome
Version : 27.0.1453.110
Nom : Adobe Reader XI (11.0.03)
Version : 11.0.03
Adobe Reader est à jour
Nom (svc) : Internet Explorer
Version : 10.0.9200.16580
Nom : Flash Player Active X : Windows 8 :
Version : 11.7.700.202
SX Check&Update
Aucun Service Pack
UserName : JM
09/06/2013
17:29:02
version = v0.3.3
AUOptions : 2
Nom : Google Chrome
Version : 11.0.03
Oui, cette fois-ci c'est le bon rapport.
Tout est à jour, c'est parfait
Tu n'as pas répondu à la question "Comment se comporte le système ?"
Si tout va bien, plus de pages publicitaires, nous pourrons finaliser la procédure.
johnmarcus11
Excuse moi,ton mail était parti dans les spams.
Il semblerait que tout soit rentré dans l'ordre,sous réserve d'observer pendant quelques temps.
Je pense que tu peux finaliser.
OK on finalise la procédure.
Purge points de restauration :
Désinstallation des outils utilisés :
Pour en savoir plus, clique sur l'image pour télécharger ce PDF
Purge points de restauration :- Ferme toutes les autres fenêtres et double-clique sur OTL.exe
/!\ Sous Vista et Windows 7, il faut lancer le fichier par clic-droit -> Exécuter en tant qu'administrateur - Copie l'intégralité de ce script hébergé ci-dessous
http://up.security-x.fr/file.php?h=R231 ... e8a7606367 - Colle l'intégralité du code dans le cadre Personnalisation
- Clique ensuite sur le bouton Correction
- Si l'outil te demande de redémarrer le PC, tu acceptes
Désinstallation des outils utilisés :- Ferme toutes les autres fenêtres et double-clique sur OTL.exe
/!\ Sous Vista et Windows 7, il faut lancer le fichier par clic-droit -> Exécuter en tant qu'administrateur - Clique sur Purge d'outils
- Valide l'avertissement par OK et laisse le pc redémarrer
- Relance AdwCleaner et clique sur Désinstaller
- Supprime SXCU de ton Bureau
- Supprime tous les rapports générés restants
Quelques précisions et conseils :- D'une manière générale, il faut être prudent sur le net et ne pas cliquer sur tout ce qui paraît attrayant.
Pourquoi et comment je me fais infecter ?
/!\ Ne jamais ouvrir une pièce-jointe dans un mail d'un expéditeur inconnu - Maintenir son antivrus à jour et analyser le système régulièrement, avec en parallèle un scan avec Malwarebytes
- Tenir son système à jour, au niveau des mises à jour Windows Update, sans oublier les logiciels installés.
Penser à décocher les options proposées en même temps que Java et Flash Player (Barre Google, Scan McAfee ....
Maintenir Java, Adobe Reader et le player Flash à jour
Exploitation SWF/PDF et Java - système non à jour = danger - Au niveau de Firefox et Chrome, tu peux sécuriser ta navigation
johnmarcus11
Voilà,c'est fait.
C'est lourd comme procédure.
Un GRAND merci à toi.
Je suis pourtant très prudent,je sais pas trop comment ça a pu m'arriver.
Merci encore et bonne soirée dans l'Aude.
A toi aussi .... en espérant que le soleil va revenir parce que la pluie, on en a assez !johnmarcus11 a écrit :Merci encore et bonne soirée dans l'Aude.
Bonne continuation
