[Info] VirtualBox versions 4.2.0 ~ 4.x.x... compatibles Windows 8.1
Re: [Info] VirtualBox en version 4.2.0 finale... maj 4.2.18 pour Windows 8.1
La 4.3 Beta 2 est sortie pour ceux qui veulent faire des essais:
VirtualBox-4.3.0_BETA2-88827-Win.exe
La Release Candidate 1 est en ligne pour les amateurs, avec un guide d'utilisation actualisé.
Changelog (extrait):
• GUI: use the number of physical cores for the recommendation for the maximum number of virtual CPUs,
• GUI: fixed crash during medium enumeration,
• GUI: NLS updates,
• 3D: Google Earth fixes for Windows guests running the WDDM driver,
• 3D: seamless fixes,
• EFI: several fixes,
• IDE/SATA: fix for newer Linux kernels not detecting a hard disk as SSD when using the IDE or SATA controller,
• IDE/SATA: Store the passthrough flag for CD/DVD drives even if there is no medium attached,
• Guest Control: several fixes,
• Windows Additions: fixed memory leak with certain Windows guests.
VirtualBox-4.3.0_RC1-89687-Win.exe
• GUI: NLS updates,
Re: [Info] VirtualBox version 4.2.0 ~ 4.3.0... compatible Windows 8.1
La version 4.3 finale est disponible...
Principales nouveautés:
• VMM: major rewrite of the VT-x code and the AMD-V code including many bug fixes and performance improvements,
• GUI: extended messaging mechanism (new non-modal popup overlays used to show non-critical warnings and provide user with additional information),
• GUI: keyboard shortcuts management (input page of global preferences extended with possibility to edit general keyboard shortcuts for VirtualBox Manager and Virtual Machine),
• GUI: video capturing support,
• Added USB touch device emulation,
• Added experimental support for webcam passthrough complementing USB passthrough (see the manual for more information),
• Added SCSI CD-ROM emulation, including boot support,
• VRDP: support for IPv6.
• Guest Control: guest sessions now are running in dedicated, impersonated session processes (needs at least Guest Additions 4.3 installed),
• NAT: experimental virtual router mode: several VMs are attached to the same internal network and share one NAT service (see the manual for more information).
Téléchargement:
VirtualBox binaries
Téléchargement:
VirtualBox binaries
nardino
Bonsoir Jango,
Merci une fois de plus pour ton travail d'alerte sur ces outils que nous affectionnons tant.
Re: [Info] VirtualBox version 4.2.0 ~ 4.x.x... compatibles Windows 8.1
Une grosse mise à jour de maintenance 4.3.2 publiée le 1er Novembre, avec au moins un bonne vingtaine de corrections de bugs et quelques améliorations.
A récupérer sur la page habituelle.
note: la 4.3.1 n'a pas dépassé le stade de Test Build qui solutionnait un problème d'écran bleu sur Windows 8.1.
Re: [Info] VirtualBox versions 4.2.0 ~ 4.x.x... compatibles Windows 8.1
Encore une importante mise à jour de maintenance 4.3.4 du 29 Novembre qui n'apporte que des corrections, dont certaines concernent l'interface GUI, l'accélération 2D Vidéo, la gestion des hôtes Windows et les Additions Invité.
Téléchargement:
VirtualBox-4.3.4-91027-Win.exe
Manuel utilisateur à jour:
UserManual.pdf
Téléchargement:
UserManual.pdf
Mise à jour de maintenance 4.3.6 du 18 Décembre avec quelques nouvelles corrections.
Téléchargement:
VirtualBox-4.3.6-91406-Win.exe
Manuel utilisateur actualisé:
UserManual.pdf
Téléchargement:
UserManual.pdf
Une grosse mise à jour de maintenance 4.3.8 est en préparation... et la Release Candidate 1 vient de sortir pour les testeurs.
Changelog détaillé avec une longue liste de corrections:
VirtualBox 4.3.8 RC1 released
La 4.3.8 est en version finale du 25 Février avec une palanquée de corrections de bugs.
Téléchargement:
VirtualBox-4.3.8-92456-Win.exe
UserManual.pdf
Téléchargement:
UserManual.pdf
