Windows 11 - Insider Preview - canal Beta
Re: Windows 11 - Insider Preview - CO_RELEASE - canal Dev - canal Beta
Les fichiers ISOs de la build 22000.132 sont disponibles sur la page dédiée
https://www.microsoft.com/en-us/softwar ... previewiso
Windows 11 Build 22000.160 - KB5005189 - CO_RELEASE - canal Dev et Beta
https://blogs.windows.com/windows-insid ... 22000-160/
Windows 11 Build 22000.168 - KB5005191 - CO_RELEASE - canal Dev et Beta
https://blogs.windows.com/windows-insid ... 22000-168/
Suite pour le canal Dev ici -> post38604.html#p38604
Re: Windows 11 - Insider Preview - CO_RELEASE - canal Beta
Windows 11 Build 22000.176 - KB5006050 - CO_RELEASE - canal Beta
https://blogs.windows.com/windows-insid ... 22000-176/
Mise à jour de la fiche du Blog :
UPDATE 7:10PM PDT: Recently, Windows Insiders in both the Dev and Beta Channels began reporting that Start and Taskbar were unresponsive and Settings and other areas of the OS wouldn’t load. We quickly discovered an issue with a server-side deployment that went out to Insiders and canceled that deployment. If you were impacted by this issue, you can use the following steps to get back into a working state on your PC.
Step 1: Use CTRL-ALT-DEL and choose to open Task Manager.
Step 2: Choose “More details” at the bottom of Task Manager to expand Task Manager.
Step 3: Go to “File” and choose “Run new task”.
Step 4: Type “cmd” in the “Open” field.
Step 5: Paste the following (everything in bold):
  • reg delete HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\IrisService /f && shutdown -r -t 0
Step 6: Hit enter, and then your PC should reboot. After rebooting, everything should be back to normal.
MISE À JOUR 19:10 PDT: Récemment, les initiés de Windows dans les canaux de développement et bêta ont commencé à signaler que le démarrage et la barre des tâches ne répondaient pas et que les paramètres et d'autres zones du système d'exploitation ne se chargeaient pas. Nous avons rapidement découvert un problème avec un déploiement côté serveur qui a été envoyé aux initiés et a annulé ce déploiement. Si vous avez été touché par ce problème, vous pouvez utiliser les étapes suivantes pour revenir à un état de fonctionnement sur votre PC.
Étape 1 : Utilisez CTRL-ALT-DEL et choisissez d'ouvrir le Gestionnaire des tâches.
Étape 2 : Choisissez « Plus de détails » au bas du Gestionnaire des tâches pour développer le Gestionnaire des tâches.
Étape 3 : Allez dans « Fichier » et choisissez « Exécuter une nouvelle tâche ».
Étape 4: Tapez "cmd" dans le champ "Ouvrir".
Étape 5 : collez ce qui suit (tout en gras) :
Étape 6 : Appuyez sur Entrée, puis votre PC devrait redémarrer. Après le redémarrage, tout devrait revenir à la normale.
Windows 11 Build 22000.184 - KB5005642 - CO_RELEASE - canal Beta
https://blogs.windows.com/windows-insid ... 22000-184/
Windows 11 Build 22000.194 - KB5005635 - CO_RELEASE - canal Beta
https://blogs.windows.com/windows-insid ... 22000-194/
Pour info, la KB5005635 est disponible dans le catalogue Microsoft Update
https://www.catalog.update.microsoft.co ... =KB5005635
Windows 11 Insider Preview Build 22000.194 est disponible dans le canal Release Preview (sur un PC éligible).
Les fichiers ISOs de la Build 22000.194 sont disponibles sur la page dédiée
Re: Windows 11 - Insider Preview - CO_RELEASE - canal Beta - canal Release Preview
Windows 11 Insider Preview - KB5006674 - Build 22000.258 est disponible dans le canal Beta et Release Preview
