La version 1.1 finale est disponible avec un lot imposant d'améliorations:
changelog complet
dont notamment:
• Added drag & drop including rearranging items in the all programs tree.
• Added rename support in the tree.
• Added feature : Folders pinned to the startmenu allow you to view the first X items as a jumplist.
• Added opening Winkey+X menu option instead of start menu.
• Added feature : Custom places locations. Add a Dropbox location for example.
Téléchargement direct
Selon le CEO de Stardock, Start8 a été téléchargé 3 millions de fois depuis son lancement commercial et se vend à des milliers d'exemplaires par jour.
[MAJ Important] Start8 : le retour du menu démarrer sous Windows 8, possible avec la RTM
Re: [MAJ Important] Start8 : le retour du menu démarrer sous
Une mise à jour de maintenance 1.10.1 Bêta est en cours d'évaluation depuis fin Janvier avec de nouvelles améliorations:
• Added Start8tweak.exe advanced configuration for extra options including enabling / disabling Start8 on a per account basis.
• Added email category to search results.
• Added support for Modern UI app closing to return to the desktop rather than the Windows 8 menu on advanced settings.
• Added native support for the DisplayFusion secondary taskbar.
• Added support for BMP files as start button. RGB (255,0,255) is permitted for transparency.
• Added registry entry to control if hidden items should be included in the All programs list.
• Added registry entry to control if the user picture should have a border or not in the default theme.
• Added registry entry to control if the tree has a horizontal scroll bar.
• Added support for Search the Internet button on search results via registry key.
• Documents, Pictures, Music, Computer and Recorded TV places will use the name set in explorer for them if the user has renamed them.
• Shutdown button menu will have an item selected when accessed via the keyboard.
• Adjusted start menu sizing to prevent bottom item on the places list from being slightly clipped in certain circumstances.
• Modified shutdown menu to prevent surplus separator line showing when the machine doesn't support sleep or hibernate.
Publication finale courant Février.
Version 1.11 disponible en mise à jour.
Même changelog que celui cité plus haut, auquel s'ajoute:
• Tweaked to prevent .lnk text showing in tree on occasion.
• Tweaked code to better handle closing a docked Modern UI application when at the desktop when the charms bar is set to disabled.
• Fixed an issue with right click on the places list.
• Jumplists close when you pin / unpin something / delete it.
Re: [MAJ Important] Start8 : le retour du menu démarrer sous Windows 8, possible avec la RTM
Mise à jour de maintenance 1.12 du 19 Mars avec quelques corrections et améliorations.
changelog:
• Added support for BMP start buttons with alpha channels,
• Fix for a possible crash while searching,
• Fix for frequently used apps list not filtering out some pinned taskbar items,
• Assorted tweaks and performance improvements.
changelog:
