Mise à jour cumulative KB4462933 - Windows 10 - version 1803
La mise à jour cumulative KB4462933 est disponible via Windows Update pour Windows 10 - version 1803
Improvements and fixes
Addresses an issue that sometimes prevents documents from appearing in the Microsoft Edge DevTools debugger.
Addresses an issue that sometimes prevents Microsoft Edge extension scripts from appearing in Microsoft Edge DevTools.
Addresses the redenomination of local currency that the Central Bank of Venezuela implemented to enter the Bolivar Soberano into circulation.
Addresses additional issues with updated time zone information.
Addresses an issue that causes sysprep /generalize to fail in audit mode because of a race condition while deleting certain registry keys.
Addresses an issue with legacy Bluetooth® Basic Rate (BR) device inbound pairing.
Addresses an issue that causes the audio service to stop working or become unresponsive while using call control, controlling volume, and streaming music to Bluetooth audio devices. Error messages that appear include:
Exception error 0x8000000e in btagservice.dll.
Exception error 0xc0000005 or 0xc0000409 in bthavctpsvc.dll.
Stop 0xD1 BSOD error in btha2dp.sys.
Addresses an issue that causes the OS to stop working when a Bluetooth device is accidently removed.
Addresses an issue that causes the Event Log service to stop responding and degrades reliability in various areas of the operating system until you restart. This occurs when the Event Log is full and you selected Do not overwrite events (Clear logs manually) in Log Properties–System > When maximum event log size is reached:.
Addresses an issue to support Microsoft Office events in the “Limit Enhanced” Group Policy setting list.
Addresses an issue that makes it impossible to disable TLS 1.0 and TLS 1.1 when the Federal Information Processing Standard (FIPS) mode is enabled.
Addresses an issue in which applications on systems with more than 4 GB of memory receive Access Denied error code “0x5” when calling CreateProcessWithLogonW().
Addresses an issue in which the AccountName in the Event Log entry for the Microsoft-Windows-Kerberos-Key-Distribution-Center source and Event ID 7 sometimes appears corrupted.
Addresses an issue in which applications have handle leaks when using client authentication certificates with the TLS protocol. This issue occurs when the FreeCredentialsHandle call occurs before the DeleteSecurityContext call in the application code.
Addresses an issue that might cause TCP connections opened for an application running on Windows Container to fail sporadically. This occurs when the container runs on a Network Address Translation (NAT) Network provided by Windows Network Address Translation (WinNAT). A SYN timeout occurs after reaching the maximum SYN Retransmit count.
Addresses an issue with a warning message that appears when using Microsoft Edge to print some PDFs.
Addresses an issue that causes the printing of PDF files from SharePoint Online to fail with the error, “Couldn't open PDF”.
Addresses an issue that can cause App-V packages to fail because of a missing file or DLL error.
Addresses an issue that may cause container snapshot restoration to fail because of a missing file error.
Addresses an issue that prevents the deletion of Immediate Tasks when their deletion timer occurs, such as when you configure Group Policy preferences for Immediate Task actions.
Addresses an issue that causes Scheduled Tasks to remain in a queue and not execute until the first user logs on to a Windows 10, version 1803 device. Some affected scenarios include:
Scheduled Tasks that are defined in the last phase of setup won’t execute.
“Auto-enroll” computer certificates and “root and intermediate” certificates are missing.
Addresses an issue that prevented the launch of Windows Defender Application Guard (WDAG) on Windows 10N (Europe) devices after servicing.
Addresses an issue that incorrectly implies that user policies have not been applied after configuring a user rights Group Policy setting. Reporting tools, such as RSOP.MSC or Gpresult.exe /h, do not show the user rights policies or display a red “X” instead.
Addresses an issue in which connection group folders are not properly merged.
Addresses an issue in which Scheduled Tasks configured to run on a specific day of the week don't execute at the expected time.
Addresses an issue that prevents the clock and date flyout from appearing when the region format is Spanish (Spain) and the sorting method is Traditional.
Addresses an issue in which the System.Security.Cryptography.Algorithms reference was not correctly loaded on .NET Framework 4.7.1 after the July 10, 2018 and August 14, 2018 patches.
Addresses an issue that may cause the system to stop working during the shutdown of some Windows Presentation Foundation (WPF) apps because of TaskCanceledException. Apps that are vulnerable to this issue perform work involving weak events or data binding after the Application.Run() function returns values.
Addresses a race condition in temporary files and some antivirus scanners that causes .NET Framework applications to stop working. The error message is, "The process cannot access the file <name of temp file>".
Updates the .NET Framework's support for the formatting of Japanese dates for the first year in the eras. When the format pattern is “y年”, the year format will use the symbol 元 and not use year number 1. Additionally, the .NET Framework will support dates that include 元. For more information, see KB4469068.
Updates Venezuela currency information. This will affect the culture of “es-VE” as follows:
The currency symbol is “Bs.S”.
The English currency name is “Bolívar Soberano”.
The local currency name is “bolívar soberano”.
The International Currency Code is “VES”.
Addresses an issue that may cause an application that has a child window to stop processing mouse inputs. This issue occurs when a precision touchpad triggers a WM_MOUSEWHEEL event.
Addresses an issue that may cause some applications to stop working after unplugging a tablet.
Addresses an issue in which application titles that were unexpectedly long were not predictably displayed using ellipses (…). In some cases, the text truncations that appear may confuse users.
Addresses an issue that causes the Windows 8.1 app to stop working when it calls the ProjectionManager.StartProjectingAsync API. The error code is 0x80070057.
Addresses an issue with Windows Text Input Framework. A layout request may cause some application text input elements to stop responding.
Addresses an issue in which users cannot enter East Asian text when prompted to create password hints during the upgrade process.
Addresses a multi-monitor issue that may incorrectly render an application that is in full-screen mode after changing the display mode.
Addresses an issue with leaks of window-related Graphics Device Interface (GDI) objects during window destruction.
Addresses an issue that occurs when typing in a text box of a Windows Presentation Foundation (WPF) application using the on-screen keyboard. If you select one of the predictive text suggestions, that word appears to be entered, but will disappear when you select a different control.
Addresses an issue that prevents applications from displaying a pop-up window or dialog box when the applications are in full-screen mode. For example, in a full-screen game, attempting to alter settings such as Multisampling Antialiasing (MSAA) will fail because the confirmation dialog does not appear. The dialog is hidden behind the application.
Addresses an issue that causes navigation across eras to stop working in the Japanese Calendar view. For more information, see KB4469068.
Addresses an issue related to the date format for the Japanese era calendar. For more information, see KB4469068.
Addresses an issue that causes the GetCalendarInfo function to return a wrong value for the Japanese era. For more information, see KB4469068.
If you installed earlier updates, only the new fixes in this package will be downloaded and installed on your device.
https://support.microsoft.com/fr-fr/hel ... -kb4462933
KB4462933
Un redémarrage est requis.
La version Windows 10 passe à 17134.376
J@M3S
Re: Mise à jour cumulative KB4462933 - Windows 10 - version 1803
Message par J@M3S »
Encore un truc + un truc pour changer :mdr: ce Windows 10 n'est toujours pas aboutit malgrès les testeurs Insider :roll: .
Bonjour la mise en page sur le lien et le Fr c'est ou chez crosoft :?:
Traduction pour les francophones:
Améliorations et corrections
Cette mise à jour inclut des améliorations de qualité. Aucune nouvelle fonctionnalité du système d'exploitation n'est introduite dans cette mise à jour. Les changements clés incluent:
• Résolution d'un problème qui empêche parfois les documents d'apparaître dans le débogueur de Microsoft Edge DevTools.
• Résout un problème qui empêche parfois les scripts d'extension Microsoft Edge d'apparaître dans Microsoft Edge DevTools.
• Aborde la redénomination de la monnaie locale mise en œuvre par la Banque centrale du Venezuela pour la mise en circulation de Bolivar Soberano.
• Résout les problèmes supplémentaires liés aux informations de fuseau horaire mises à jour.
• Résolution d'un problème entraînant l'échec de sysprep / generalize en mode audit en raison d'une situation de concurrence critique lors de la suppression de certaines clés de registre.
• Résolution d'un problème lié au couplage entrant de périphériques Bluetooth® Basic Rate (BR) hérité.
• Résolution d'un problème qui empêche le service audio de fonctionner ou cesse de répondre tout en utilisant le contrôle des appels, le contrôle du volume et la diffusion de musique en continu sur des périphériques audio Bluetooth. Les messages d'erreur qui apparaissent incluent:
? Erreur d'exception 0x8000000e dans btagservice.dll.
? Erreur d'exception 0xc0000005 ou 0xc0000409 dans bthavctpsvc.dll.
• Stop 0xD1 erreur BSOD dans btha2dp.sys.
• Résout un problème qui empêche le système d'exploitation de fonctionner lorsqu'un périphérique Bluetooth est supprimé par inadvertance.
• Résolution d'un problème qui empêche le service de journal des événements de répondre et dégrade la fiabilité dans différentes zones du système d'exploitation jusqu'à ce que vous redémarriez. Cela se produit lorsque le journal des événements est plein et que vous avez sélectionné Ne pas écraser les événements (effacer les journaux manuellement) dans Propriétés du journal - Système> Lorsque la taille maximale du journal des événements est atteinte :
• Résout un problème de prise en charge d'événements Microsoft Office dans la liste de paramètres de stratégie de groupe «Limite améliorée».
• Résolution d'un problème rendant impossible la désactivation de TLS 1.0 et TLS 1.1 lorsque le mode FIPS (Federal Information Processing Standard) est activé.
• Résolution d'un problème concernant le fait que les applications situées sur des systèmes dotés de plus de 4 Go de mémoire reçoivent le code d'erreur Accès refusé «0x5» lors de l'appel de CreateProcessWithLogonW ().
• Résout un problème dans lequel l'entrée AccountName dans l'entrée de journal des événements pour la source Microsoft-Windows-Kerberos-Key-Distribution-Center et l'ID d'événement 7 semblent parfois endommagés.
• Résolution du problème de fuite de traitement des applications lors de l'utilisation de certificats d'authentification client avec le protocole TLS. Ce problème se produit lorsque l'appel FreeCredentialsHandle a lieu avant l'appel DeleteSecurityContext dans le code de l'application.
• Résolution d'un problème pouvant entraîner l'échec sporadique des connexions TCP ouvertes pour une application s'exécutant sur un conteneur Windows. Cela se produit lorsque le conteneur s'exécute sur un réseau de traduction d'adresses réseau (NAT) fourni par la traduction d'adresses réseau Windows (WinNAT). Une temporisation SYN survient après avoir atteint le nombre maximal de retransmissions SYN.
• Résolution d'un problème avec un message d'avertissement qui apparaît lorsque Microsoft Edge est utilisé pour imprimer certains fichiers PDF.
• Résolution d'un problème entraînant l'échec de l'impression de fichiers PDF à partir de SharePoint Online avec le message d'erreur «Impossible d'ouvrir le fichier PDF».
• Résolution d'un problème pouvant entraîner l'échec des packages App-V en raison d'un fichier manquant ou d'une erreur de DLL.
• Résout un problème pouvant entraîner l'échec de la restauration de l'instantané du conteneur en raison d'une erreur de fichier manquante.
• Résout un problème qui empêche la suppression des tâches immédiates lorsque leur minuterie de suppression se produit, par exemple lorsque vous configurez les préférences de stratégie de groupe pour les actions de tâche immédiate.
• Résolution d'un problème qui fait que les tâches planifiées restent dans une file d'attente et ne s'exécutent que lorsque le premier utilisateur ouvre une session sur un périphérique Windows 10, version 1803. Certains scénarios concernés incluent:
• Les tâches planifiées définies dans la dernière phase de la configuration ne seront pas exécutées.
• Les certificats d'ordinateur «à inscription automatique» et les certificats «racine et intermédiaires» sont manquants.
• Résout un problème qui empêchait le lancement de WDAG (Windows Defender Application Guard) sur les périphériques Windows 10N (Europe) après réparation.
• Résolution d'un problème qui implique de manière incorrecte que les stratégies utilisateur n'ont pas été appliquées après la configuration d'un paramètre de stratégie de groupe des droits des utilisateurs. Les outils de génération de rapports, tels que RSOP.MSC ou Gpresult.exe / h, n'affichent pas les stratégies de droits des utilisateurs ni un «X» rouge.
• Résout un problème dans lequel les dossiers du groupe de connexion ne sont pas correctement fusionnés.
• Résout un problème dans lequel les tâches planifiées configurées pour s'exécuter un jour spécifique de la semaine ne s'exécutent pas à l'heure prévue.
• Résolution d'un problème empêchant l'affichage des menus déroulants horloge et date lorsque le format de région est Espagnol (Espagne) et que la méthode de tri est Traditionnelle.
• Résolution d'un problème pour lequel la référence System.Security.Cryptography.Algorithms n'a pas été chargée correctement sur .NET Framework 4.7.1 après les correctifs du 10 juillet 2018 et du 14 août 2018.
• Résolution d'un problème pouvant empêcher le système de fonctionner pendant l'arrêt de certaines applications Windows Presentation Foundation (WPF) à cause de TaskCanceledException. Les applications vulnérables à ce problème exécutent des tâches impliquant des événements faibles ou une liaison de données après que la fonction Application.Run () a renvoyé des valeurs.
• Adresse une condition de concurrence dans les fichiers temporaires et certains analyseurs antivirus provoquant l'arrêt des applications .NET Framework. Le message d'erreur est "Le processus ne peut pas accéder au fichier <nom du fichier temporaire>".
• Met à jour la prise en charge du .NET Framework pour le formatage des dates japonaises pour la première année des ères. Lorsque le modèle de format est «y», le format d'année utilisera le symbole ? et non le numéro d'année 1. En outre, le .NET Framework prendra en charge les dates qui incluent. Pour plus d'informations, voir KB4469068.
• Met à jour les informations sur la devise du Venezuela. Cela affectera la culture de «es-VE» comme suit:
• Le symbole monétaire est «Bs.S».
• Le nom de la devise anglaise est «Bolívar Soberano».
• Le nom de la devise locale est “bolívar soberano”.
• Le code de devise internationale est «VES».
• Résolution d'un problème pouvant empêcher une application disposant d'une fenêtre enfant de traiter les entrées de la souris. Ce problème se produit lorsqu'un touchpad de précision déclenche un événement WM_MOUSEWHEEL.
• Résolution d'un problème pouvant empêcher certaines applications de fonctionner après avoir débranché une tablette.
• Résolution d'un problème pour lequel les titres d'applications dont la longueur était inattendue étaient non affichés de manière prévisible à l'aide d'ellipses (…). Dans certains cas, les troncatures de texte qui apparaissent peuvent être source de confusion pour les utilisateurs.
• Résolution d'un problème entraînant l'arrêt de l'application Windows 8.1 lorsque celle-ci appelle l'API ProjectionManager.StartProjectingAsync. Le code d'erreur est 0x80070057.
• Résolution d'un problème avec Windows Text Input Framework. Une demande de mise en page peut empêcher certains éléments de saisie de texte d'application de répondre.
• Résout un problème dans lequel les utilisateurs ne peuvent pas saisir de texte est-asiatique lorsqu'ils sont invités à créer des indicateurs de mot de passe pendant le processus de mise à niveau.
• Résolution d'un problème multi-moniteurs susceptible de rendre de manière incorrecte le rendu d'une application en mode plein écran après la modification du mode d'affichage.
• Résolution d'un problème de fuites d'objets GDI (Graphics Device Interface) liés aux fenêtres lors de la destruction de la fenêtre.
• Résolution d'un problème qui survient lors de la saisie dans une zone de texte d'une application Windows Presentation Foundation (WPF) à l'aide du clavier à l'écran. Si vous sélectionnez l'une des suggestions de texte prédictif, ce mot semble être entré, mais disparaît lorsque vous sélectionnez un contrôle différent.
• Résolution d'un problème empêchant les applications d'afficher une fenêtre contextuelle ou une boîte de dialogue lorsque les applications sont en mode plein écran. Par exemple, dans un jeu en plein écran, toute tentative de modification de paramètres tels que l'anti-crénelage multiple (MSAA) échouera, car la boîte de dialogue de confirmation n'apparaît pas. La boîte de dialogue est cachée derrière l'application.
• Résolution d'un problème qui empêche la navigation dans les époques de fonctionner dans la vue du calendrier japonais. Pour plus d'informations, voir KB4469068.
• Résout un problème lié au format de date du calendrier de l'ère japonaise. Pour plus d'informations, voir KB4469068.
? Résout un problème qui provoque la fonction GetCalendarInfo pour renvoyer une valeur incorrecte pour l'ère japonaise. Pour plus d'informations, voir KB4469068.
Si vous avez installé des mises à jour antérieures, seuls les nouveaux correctifs contenus dans ce package seront téléchargés et installés sur votre appareil.
Problèmes connus dans cette mise à jour
Microsoft n'a pas connaissance de problèmes avec cette mise à jour.
Comment obtenir cette mise à jour
Avant d'installer cette mise à jour
Les mises à jour cumulatives Windows nécessitent l'installation de la dernière mise à jour de la pile de maintenance (SSU) pour votre système d'exploitation avant l'installation de la dernière mise à jour cumulative (LCU). Cela permet d’atténuer les problèmes potentiels lors de l’installation de la LCU. Pour plus d'informations, voir Maintenance des mises à jour de la pile.
Si vous utilisez Windows Update, la dernière SSU (KB4456655) vous sera proposée automatiquement. Pour obtenir le package autonome de la dernière SSU, accédez au catalogue Microsoft Update.
Installer cette mise à jour
Pour télécharger et installer cette mise à jour, accédez à Paramètres> Mise à jour et sécurité> Windows Update et sélectionnez Vérifier les mises à jour.
Pour obtenir le package autonome pour cette mise à jour, accédez au site Web du catalogue Microsoft Update.
Moi, j'aime bien savoir ce qu'il s'installe dans les soi-disant améliorations
Bonour,
J'indique toujours le lien Fr, il est en général automatiquement traduit au bout de quelques jours.
De toute façon, tu n'as pas le choix, cette mise à jour cumulative va t'être imposée à un moment ou un autre.
Perso, je suis sous la version 1809, sans avoir tous les dysfonctionnements listés dans les différents articles.
J@M3S
Message par J@M3S »
Bonoir :mdr: ,
chantal11 a écrit : J'indique toujours le lien Fr, il est en général automatiquement traduit au bout de quelques jours.
Je sais bien cela mais, c'est quand même pas très pratique pour les utilisateurs qui ne parlent pas du tout EN et il va falloir que crosoft trouve une solution avec leur
chantal11 a écrit :De toute façon, tu n'as pas le choix, cette mise à jour cumulative va t'être imposée à un moment ou un autre.
Je sais bien, mais ça devient très rébarbatif pour pas grand chose car les problèmes de certains ne sont toujours pas résolu même après leur MAJ.
En ce qui me concerne je suis déjà en 1809 donc cette MAJ n'est pas pour moi.
chantal11 a écrit :Perso, je suis sous la version 1809, sans avoir tous les dysfonctionnements listés dans les différents articles.
Idem, chez moi tout fonctionne normalement même avec une config plus basse que la préconisée.
C'est juste le RLB du jour :coucou:
Modifié en dernier par J@M3S le dim. 28 oct. 2018 08:19, modifié 1 fois.
CAHORSLOT
Message par CAHORSLOT »
Cette mise à jour a été assez indigeste pour mon ordinateur; en effet, son installation m'a privé de deux logiciels (Money et Comptes bancaires) et j'ai été obligé de faire une restauration d'image système antérieure à la mise à jour. Un fait remarquable à signaler, lors de l'installation de cette MAJ, celle-ci a progressé jusqu'à 30% puis elle est repartie à 10% pour aller à son terme.
du fait de cette restauration la dite mise à jour n'est pas installée. Je ne sais que faire: la réinstaller ou pas.
Merci de vos conseils.
Si tu as toujours Kaspersky installé, désactive complètement Kaspersky avant de recommencer l'installation de cette MaJ cumulative.
Bonjour CAHORSLOT,
Comme tu le sais Money pose quelques problèmes avec Windows 10, rappel de ce post:
discussions-generales-f21/topic2751.html
pages2
Message par pages2 »
bonjour,
oui, j'ai installé la mise à jour KB4462933 sous windows update 1803
Ca s'est bien passé :-)
Bonne journée
micpal
Message par micpal »
Bonjour CAHORSLOT
J'ai deux PC sur lesquels j'utilise money2005.
sur le premier la mise à jour KB4462933 ne m'a posé aucun problème avec money
sur le deuxième cette mise à jour s'est installée en même temps que la KB4100347 et là money a perdu ses billes, je m'en suis sorti en ouvrant directement le fichier money et en acceptant le contrat de licence, dans mon cas, il n'est plus sous application data, ...., c'était trop compliqué pour le changer, mais directement sous document, money
Par contre, il a fallut que je reprogramme certains paramètres de l'application: sons, endroit de sauvegarde
Quand au dysfonctionnement signalé par mwonex, il suffit d'attendre la disparition du fichier .lrd ( qui peut prendre 1 à 2 mn) pour pouvoir fermer money, je n'ai quasiment plus ce défaut.
Cordialement à tous
