Mise à jour cumulative KB4541335 - Windows 10 - version 1903 et 1909 - 18362.752 et 18363.752
La mise à jour cumulative KB4541335 est disponible via Windows Update pour Windows 10 - version 1903 (19H1) - 18362.752 et version 1909 (19H2) - 18363.752
Highlights
Updates an issue that causes an error when printing to a document share.
Updates a performance issue in applications that occurs when content that is protected by digital rights management (DRM) plays or is paused in the background.
Updates an issue that prevents the mute button from working on certain devices with the Microsoft Your Phone app.
Updates an issue that prevents applications from closing.
Updates an issue that causes calendar dates to appear on the wrong day of the week in the clock and date region of the notification area when you select the Samoa time zone.
Updates an issue that causes applications to close unexpectedly when a user enters East Asian characters after changing the keyboard layout.
Improvements and fixes
Windows 10, version 1909
This build includes all the improvements from Windows 10, version 1903.
Addresses an issue that fails to retain the locale language setting in an OS image that is customized during system preparation (Sysprep).
Addresses an issue that causes an error when printing to a document repository.
Addresses an issue that displays a misleading reset message for Win32 apps that are converted to Universal Windows Platform (UWP) apps, such as Microsoft Sticky Notes, Microsoft OneNote, and so on.
Addresses a drawing issue with the Microsoft Foundation Class (MFC) toolbar that occurs when dragging in a multi-monitor environment.
Addresses an issue that prevents the first key stroke from being recognized correctly in the DataGridView cell.
Addresses a performance issue in applications that occurs when content that is protected by digital rights management (DRM) plays or is paused in the background.
Addresses an issue that causes attempts to take a screenshot of a window using the PrintWindow API to fail.
Addresses an issue that causes File Explorer to close unexpectedly when using roaming profiles between different versions of Windows 10.
Addresses an issue that fails to return search results in the Start menu Search box for users that have no local profile.
Addresses an issue that causes applications to close unexpectedly when a user enters East Asian characters after changing the keyboard layout.
Addresses an issue that prevents the mute button from working on certain devices with the Microsoft Your Phone app.
Addresses an issue that causes calendar dates to appear on the wrong day of the week in the clock and date region of the notification area when you select the Samoa time zone.
Addresses an issue in which table formatting fails in the PowerShell Integrated Scripting Environment (ISE) during a remote session. The error message is, "Remote host method get_WindowsSize is not implemented".
Addresses an issue with reading logs using the OpenEventLogA() function.
Addresses an issue that might cause domain controllers (DC) to register a lowercase and a mixed or all uppercase Domain Name System (DNS) service (SRV) record in the _MSDCS.<forest root domain> DNS zone. This occurs when DC computer names contain one or more uppercase characters.
Addresses an issue that might cause a delay of up to two minutes when signing in or unlocking a session on Hybrid Azure Active Directory-joined machines.
Addresses an issue that causes authentication in an Azure Active Directory environment to fail and no error appears.
Addresses an issue that prevents machines that have enabled Credential Guard from joining a domain. The error message is "The server's clock is not synchronized with the primary domain controller's clock."
Addresses an issue that causes authentication to fail when using Azure Active Directory and the user’s security identifier (SID) has changed.
Addresses an issue that prevents some machines from automatically going into Sleep mode under certain circumstances because of Microsoft Defender Advanced Threat Protection (ATP) Auto Incident Response (IR).
Addresses an issue that prevents some machines from running Microsoft Defender ATP Threat & Vulnerability Management successfully.
Improves support for non-ASCII file paths for Microsoft Defender ATP Auto IR.
Addresses a performance issue with the Windows Runtime (WinRT) API that sends specific absorption rate (SAR) back-off values.
Addresses an issue in which a Windows.admx template is missing one of the SupportedOn tags.
Addresses an issue that prevents applications from closing.
Addresses an issue that creates the Storage Replica administrator group with the incorrect SAM-Account-Type and Group-Type. This makes the Storage Replica administrator group unusable when moving the primary domain controller (PDC) emulator.
Restores the constructed attribute in Active Directory and Active Directory Lightweight Directory Services (AD LDS) for msDS-parentdistname.
Addresses an issue with evaluating the compatibility status of the Windows ecosystem to help ensure application and device compatibility for all updates to Windows.
Addresses an issue that prevents Microsoft User Experience Virtualization (UE-V) settings from roaming to enable the signature files that are used for new messages, forwarded messages, and replies.
Addresses an issue that prevents the Network Policy Server (NPS) accounting feature from functioning. This occurs when NPS is configured to use SQL for accounting with the new OLE (compound document) database driver (MSOLEDBSQL.dll) after switching to Transport Layer Security (TLS) 1.2.
Addresses an issue that prevents standard user accounts that are configured with the maximum User Account Control (UAC) settings from installing Language Features On Demand (FOD) using the System settings.
Addresses an issue that causes attempts to complete the connection to a virtual private network (VPN) to fail; instead, the status remains at “Connecting.”
https://support.microsoft.com/fr-fr/hel ... -kb4541335
KB4541335
Un redémarrage est requis.
La version Windows 10 passe à 18362.752 pour la version 1903 et 18363.752 pour la version 1909
micpal
Re: Mise à jour cumulative KB4541335 - Windows 10 - version 1903 et 1909 - 18362.752 et 18363.752
Message par micpal »
Bonjour chantal11
Installation sur mes deux PC sans soucis (et bug de defender corrigé)
Message par BORTA77 »
Tu as du pot micpal
Moi ça ne passe toujours pas sur ma tour ..... malgré l'aide de jjcojax . Il semble que je ne sois pas le seul à rencontrer des problèmes .
https://www.clubic.com/windows-os/actua ... gifQ%3D%3D
Heureusement que ça fonctionne sur mes 2 autres portables
Michel
Merci chantal11, les 4 PC OK, pour un d'eux il a fallu vider le dossier "C:\Windows\SoftwareDistribution\Download" qui bloquait la mise à jour.
Autrement RAS.
En attendant un autres sytème d'exploitation, j'ai même mis à jour la vieille mini tour issue de Windows 7 (1,3 Ghz) branchée sur le port Ethernet du répéteur Wifi (oui, je sais, c'est assez curieux), ça fonctionne lentement, mais pas moins qu'avant en Ethernet direct!
Sans doute y a t il des PC qui rencontrent des problèmes, la solution est de revenir à la version antérieure, ou vérifier si il n'y a pas de logiciel antivirus tiers à désinstaller, si la place est suffisante etc :hein:
greg250
Message par greg250 »
Merci Chantal!
mwonex a écrit :Bonjour,
Autrement RAS.
Bonjour Michel
Tu supprimes directement tous les fichiers dans "C:\Windows\SoftwareDistribution\Download" qui bloquait la mise à jour ou bien tu passes par un autre procédé ?
Sur un de mes PC qui pose problème , la mise à jour est désinstallé après les 3 reboot ( écran bleu , tentatives de réparation...etc.) et passage en mode sans échec . Je vois le message de désinstallation apparaître et windows redémarre normalement .
Mais malgré ce message, je vois encore dans "C:\Windows\SoftwareDistribution\Download 3 dossiers et 1 fichier . Est ce normal ?
Michel
Bonjour Michel,
Aucun risque a supprimer le contenu de:
"C:\Windows\SoftwareDistribution\Download:
Après je n'en sais pas plus
. Si tu as un message d'erreur voir alors sur le net bien sûr.
