[Info] Acronis True Image 2014 Update 1 build 6614 compatible Windows 8.1
Cette version 2014 vaut-elle le coup de s'y intéresser ?...
En tout cas l'éditeur en propose une mise à jour de maintenance qui a au moins le mérite d'apporter une compatibilité avec Windows 8.1 RTM.
What's New ?
Windows 8.1 support - Acronis True Image 2014 Update 1 is officially certified for Windows 8.1.
• Unified file backup dialog - Now you can back up your files to a local storage and to Acronis Cloud within one window.
• A new wizard for moving product licenses - When you have a 1-PC True Image license and you install the product on the second PC, you will get the "Too many activations" issue. There are different ways to resolve it. The new wizard leads you to the correct decision by asking you a few simple questions
List of known issues (les problèmes non résolus):
• [ATIHXOXIV-3404] Failed to access Acronis Secure Zone located on a USB HDD after reconnecting the HDD.
• [ATIHXOXIV-1998] In scheduler, when you select the "System restart or shutdown" option, disk backup doesn't start at system shutdown.
• [ATIHXOXIV-2452] In scheduler, clearing the "Run at system startup with delay" check box does not take effect.
• [ATIHXOXIV-2659] A network folder is backed up after it was excluded from the backup source.
• [ATIHXOXIV-2645] True Image creates an empty backup of a mapped network share. The "Failed to create snapshot" error occurs.
• [ATIHXOXIV-685] System backup to USB HDD is corrupted if you reconnect the USB HDD during the backup operation.
• [ATIHXOXIV-699] Acronis Startup Recovery Manager becomes deactivated after a full disk recovery.
Je n'influencerai personne sur ce coup là n'étant pas du tout utilisateur.
:fleche: Par contre les alternatives existent: EaseUS Todo Backup, Aomei Backupper, Macrium Reflect, Paragon Image Backup, Nova Backup, etc...
lea640
Re: [Info] Acronis True Image 2014 Update 1 build 6614 compatible Windows 8.1
Message par lea640 »
merci jango
la version 2013 ne fonctionne pas avec W8.1 ?
nardino
Message par nardino »
Il faut noter que les prix de l'upgrade ont été revus à la baisse par rapport à l'an dernier.
lea640 a écrit :la version 2013 ne fonctionne pas avec W8.1 ?
D'après le forum support, la 2013 build 6514 ne semble pas reconnaître les fichiers image *.tib créés antérieurement à l'installation de 8.1, et même avant d'être patchée la version 2014 refusait dans certains cas de s'installer ou avait des problèmes de fonctionnement:
45457: Update for True Image 2013 on Windows 8.1 ?
Peut-être aussi des histoires avec l'UEFI, le Secure Boot, etc...
lea640
merci jango
nardino
Le seul problème rencontré avec 2013 est que je ne pouvais pas sauvegarder sur un disque externe.
Corrigé avec la version 2014.
lea640
nardino a écrit :Bonjour,
ok merci
donc mise à niveau à faire ...
lea640
bonsoir
une petite question
faut il désinstaller la version 2013 d'acronis pour installer la mise à jour 2014 ?
merci
breizhspotlight
Message par breizhspotlight »
bonsoir,
surtout pas si tu la version mise à jour.... Si c'est la version complète à toi de voir.
logique.
lea640
bonjour
oui j'ai la version mise à jour avec une nouvelle clef mais mise à jour payante
donc je l'installe par dessus ?
OK MERCI
