[Info] MemTest86 5.0 : support natif 64-bit + UEFI/Secure Boot
La nouvelle version 5.0 est arrivé avec quelques nouveautés, dont notamment le support du double boot UEFI/BIOS.
-> attention... pour les PC sous BIOS classique c'est la version 4.3 qui sera automatiquement chargée par défaut.
changelog (extrait):
• Native 64-bit support,
• No longer requires the use of the PAE workaround to access more than 4GB of memory. (PAE = Physical Address Extension),
• Mouse support, where supported by the underlying UEFI system. On older systems a keyboard is still required,
• Improved USB keyboard support. The keyboard now works on systems that fail to emulate IO Port 64/60 correctly.
• Improved multi-threading support, where supported by the underlying UEFI system,
• Reporting of detailed RAM SPD information. Timings, clock speeds, vendor names and much more,
• Support to writing to the USB drive that MemTest86 is running from for logging and report generation. In all prior MemTest86 releases, there was no disk support,
• Use of GPT (GUID Partition Table),
• Option to disable CPU caching for all tests,
• Support for Secure Boot.
Images de boot CD et USB à télécharger sur le site de l'éditeur:
MemTest86 Version 5.0.0 Free Edition
