Windows 10 Insider Preview Build 14361 via Windows Update – canal Rapide
Windows 10 Insider Preview, une nouvelle Build 14361 est disponible pour les Insiders, via Windows Update – canal Rapide
https://blogs.windows.com/windowsexperi ... ild-14361/
...... sauf pour les Insiders francophones :
If you have a French Windows 10 Insider Preview build installed on your PC, you will not receive Build 14361. There is an issue with the French translation process in this build that would revert a lot of text that was used to be shown in French back to English. So we have chosen not to release this build to Insiders whose base build is French. If your base build is not French and you have a French Language Pack installed – you will still be able to install the new French language pack on top of this build, but this issue will also impact you.
Re: Windows 10 Insider Preview Build 14361 via Windows Update – canal Rapide
Z'ont pas dû bien regarder...
Bonjour Jango,
Une installation FR-Ca sans doute ..... et il faut donc une clé valide Windows 7 ou 8 ou 10 pour activer cette nouvelle installation !
papous80
Message par papous80 »
J'ai passé ma version 14352 en Anglais depuis 2 jours pour voir mais la 14361 ne m'est pas proposée.
