Windows 10 Insider Preview Build 14393 via Windows Update – canal Rapide
Windows 10 Insider Preview, une nouvelle Build 14393 est disponible pour les Insiders, via Windows Update – canal Rapide
https://blogs.windows.com/windowsexperi ... uild14393/
Re: Windows 10 Insider Preview Build 14393 via Windows Update – canal Rapide
La Build 14393 est aussi disponible pour le canal Lent.
UPDATE 7/20: We have released Windows 10 Insider Preview Build 14393 to Windows Insiders in the Slow ring.
Read more at https://blogs.windows.com/windowsexperi ... 1OERaOF.99
Mise à jour cumulative KB3176925 pour la Build 14393 (canal rapide)
Après redémarrage et installation, la version Windows 10 devient 1607 - 14393.3
We have released a Cumulative Update (KB3176925) to Windows 10 Insider Preview Build 14393 on PCs and Mobile devices which will bring the build number to 14393.3. This Cumulative Update includes a handful of fixes:
We have fixed an issue where keyboard input on some Windows tablet devices would not rotate to landscape normally.
We have fixed an issue that results in Windows Updates being delayed on systems with Connected Standby.
We have fixed a problem with text input with Korean Input Method Editor (IME) in some Store apps.
We fixed an issue causing Store apps to stop launching due to a licensing issue.
We have fixed an issue with apps that synchronize using DDE for inter-process communication.
Nouvelle mise à jour cumulative KB3176927 pour la Build 14393 (canal rapide)
Après redémarrage et installation, la version Windows 10 devient 1607 - 14393.5
We have released a Cumulative Update (KB3176927) to Windows 10 Insider Preview Build 14393 on PCs and Mobile devices which will bring the build number to 14393.5. This Cumulative Update includes a handful of fixes:
•We have improved reliability and performance of Microsoft Edge with AdBlock and LastPass extensions enabled. These extensions should continue to work after installing other extension updates from the Store.
•We fixed an issue causing battery to drain due to runaway CPU processes while a device is idle. We also fixed a battery life issue due to the proximity sensor always running on some devices.
•We fixed an issue causing Store apps to stop launching due to a licensing issue.
•We have fixed an issue that results in Windows Updates being delayed on systems with Connected Standby.
•We fixed an issue where the Korean IME would not have the correct composition on some custom TSF3 edit controls on PC.
•We fixed an issue where you might not be able to type in text into Search or some Store apps without having to restart the process.
•We have fixed an issue where keyboard input on some Windows tablet devices would not rotate to landscape normally.
Nouvelle mise à jour cumulative KB3176929 pour la Build 14393 (canal rapide)
Après redémarrage et installation, la version Windows 10 devient 1607 - 14393.10
