Mise à jour cumulative KB3194798 - Windows 10 version 1607
Une nouvelle mise à jour cumulative KB3194798 pour Windows 10 est disponible via Windows Update.
October 11, 2016—KB3194798 (OS Build 14393.321)
Improved reliability of Bluetooth and storage file system.
Addressed issue causing printer drivers to not install correctly after installing security update KB317005.
Addressed issue causing sign-in errors if a password is entered incorrectly or a new password doesn’t meet password complexity requirements after installing security update KB3167679.
Addressed issue that required users to log out and log back in before using the application they installed using the Windows installer (MSI).
Improved support for networks by adding new entries to the Access Point Name (APN) database.
Addressed issue that was causing excessive battery drain on Windows 10 Mobile when connected to Wi-Fi.
Addressed issue in which setting up both fingerprint and iris recognition sometimes causes the sign-in to fail on Windows 10 Mobile.
Addressed issue that was causing high CPU usage on Windows 10 Mobile.
Addressed additional issues with multimedia playback, revised daylight saving time, authentication, Internet Explorer 11, and Windows Shell.
Security updates to Microsoft Edge, Internet Explorer 11, Windows registry, and diagnostics hub.
For more information about the complete list of affected files, see KB3194798.
https://support.microsoft.com/en-us/hel ... te-history
La KB3194798 est aussi disponible dans le Catalogue Microsoft Update (à ouvrir avec Internet Explorer)
https://catalog.update.microsoft.com/v7 ... =kb3194798
La version Windows 10 - 1607 devient 14393.321
Re: Mise à jour cumulative KB3194798 - Windows 10 version 1607
Message par LolYangccool »
Tiens c'est curieux, je suis en 14393.322 sur mon fixe, et je suis pas en insider preview pourtant...
Mise à jour en cours de téléchargement sur le portable Asus.
Windows 11 Pro 24H2
Site perso
Mes services
LolYangccool a écrit :Tiens c'est curieux, je suis en 14393.322 sur mon fixe
Met les lunettes sur le nez .... moi je lis 14393.222 :lol:
Arf, effectivement... La mise à jour n'est pas faites alors du coup. ^^
Edit : Mise à jour faites sur le fixe cette fois, c'est bon. :p
Sur le portable avec les coupures de connexion j'ai eu du mal à la télécharger mais elle est en cours d'installation là.
J'espère que la mise à jour va corriger les problème de Wi-Fi, en espérant que ces derniers soient logiciel.
Windows 11 Pro 24H2
Site perso
Mes services
J'ai également installé cette mise à jour sur trois pc sans problème particulier, après un temps de téléchargement assez long.
Des améliorations de Microsoft Edge sont mentionnées dans la description de cette KB, comme à chaque mise à jour cumulative.
On verra bien...
La page descriptive de la mise à jour cumulative KB3194798 évoque également des améliorations pour "authentification" et "diagostics hub" et je me demande de quoi il s'agit précisément.
