[Info] Nouvelle version Malwarebytes 3.0
Une nouvelle version Malwarebytes 3.0 est disponible.
Lien de téléchargement de la version actuelle -> mb3-setup-consumer-3.0.6.1469-1075.exe
[Tutoriel] Malwarebytes Anti-Malware
MALWAREBYTES 3.0 : Plus fort, plus intelligent Rend les antivirus obsolètes
Quatre couches de protection contre les malwares. Une détection plus intelligente. Une protection spécialement conçue contre les ransomwares. C'est la sécurité que vous recherchiez.
https://fr.malwarebytes.com/
L'annonce sur le Blog Malwarebytes
https://blog.malwarebytes.com/malwareby ... placement/
Malwarebytes 3.0.4
Performance / Protective Capability:
• Added signature-less anti-exploit and anti-ransomware protection (Premium only)
• Up to 4x faster scan speeds, including even quicker Hyper Scans
• Removed non-essential reboots after certain malware removal events
• Advanced Heuristic Engine (Shuriken) now enabled by default
• Self-Protection now enabled by default (Premium only)
Usability:
• Redesigned user interface for improved usability
• Now configurable to integrate with Windows Action Center / Windows Security Center (Premium only)
• Update checks are done automatically so they do not need to be scheduled
• Improved support for keyboard navigation and screen readers
Stability / Issues Fixed:
• Added ability to lock down My Account screen via User Access Policy
• Added ability to collect enhanced logs when directed to do so by Support
• Fixed issue where Scheduler did not adjust for Daylight Saving Time changes
• Fixed issue where Scheduler defaulted to hourly Threat Scan instead of Daily
• Fixed issue where Chameleon reported error messages numerous times to Windows Event Viewer
• Changed 'Recover if missed by' setting in Scheduler to Off by default
• Prevented rootkit scanning in Custom Scans if full system drive is not selected
• Updated to latest version of 7-Zip DLL
• Addressed many other miscellaneous defects
Patch du 20/12/2016 -> Malwarebytes 3.0.5
] This release resolves a number of items that have been reported since the initial launch of Malwarebytes 3.0:
Fixed installer error that displayed 'External exception E06D7363'
Fixed issue where updates would get stuck in 'Checking' state
Fixed issue where “Real-Time Protection disabled” notifications would display throughout the day (NOTE: this notification may still be seen on reboot on some systems, but we’re working on another longer-term fix to address that separately)
Fixed slow shutdown issue that could occur in Windows 7 with real-time Malware Protection enabled (NOTE: a corresponding fix for Ransomware Protection is still pending)
Fixed conflict with Kaspersky that would not allow browsers to open properly
Improved upgrade experience when installing over a previous version of the Malwarebytes anti-exploit technology
25/01/2017 -> Malwarebytes 3.0.6
Performance/protective capability
• Several improvements to malware detection and remediation capabilities
• Several performance improvements, including improving startup time, addressing memory leaks and reducing CPU usage after a scan has completed
• Added MS Publisher as a default Protected Application for anti-exploit protection
Usability
• Fixed issue where a previously activated Premium license could be dropped incorrectly
• Fixed issue where Malwarebytes version information would revert to default values of 3.0.0 in certain cases, such as when coming back from minimal safe mode
• Fixed issue where ‘Real-Time Protection turned off’ notifications would display incorrectly on initial startup
• Fixed problem where the 'Check for updates every' setting would get stuck at 14 days after changing frequency to ‘Days’
• Fixed Help question marks throughout the main user interface so that they work when clicked
Stability/issues fixed
• Addressed several crashes and blue screens, including the BSOD that could occur with Web Protection on Windows Insider Previews
• Fixed the issue with Exploit Protection that caused Edge to crash/hang on Windows Insider Previews
• Fixed issue when Exploit Protection was enabled that caused PowerPoint to not load
• Fixed conditions that could lead to an ‘Unable to connect to service’ error
• Fixed issue where exclusions did not work properly when there were associated threat traces detected
• Fixed issue where Web Protection would not start up properly
• Fixed numerous scan hangs or crashes, including one that could occur during heuristics phase
• Numerous other fixes to improve overall program stability and usability
Re: [Info] Nouvelle version Malwarebytes 3.0
Merci chantal11 pour cette info, je le télécharge maintenant...
C'est gratuit encore? Incroyable! MalwareBytes ne le propose pas au moment de la mise à jour.
Je vois que ce n'est qu'un essai, puis on repasse sur la version de base sauf erreur
Ce n'est pas la première fois.
En général, MBAM ne propose pas les nouvelles versions dans le logiciel.
L'incitation à passer en payant est pressante.
Il n'y a plus de choix sur la durée après laquelle MBAM doit indiquer que la base de données est obsolète.
Patriciag a écrit :L'incitation à passer en payant est pressante.
Absolument pas !
Il n'y a aucune sollicitation de la part de Malwarebytes pour inciter l'utilisateur, ni le harceler pour qu'il reste sous la version Premium payante ou pour acheter la version Premium quand il est sous la version gratuite.
Le tableau des fonctionnalités entre la version gratuite et la version payante, est parlant de lui-même
https://fr.malwarebytes.com/trial/#trial
roballar
Message par roballar »
Merci Chantal !
Cette nouvelle version s'est bien installée chez moi en version Premium et en conservant ma clé de licence.
lea640
Message par lea640 »
roballar a écrit :Merci Chantal !
tu l as installée sans desinstaller? sur l ancienne version payante ?
lea640 a écrit :tu l as installée sans desinstaller? sur l ancienne version payante ?
Oui en effet, l'assistant se charge de tout, le transfert de tes paramètres et de ta licence :D
lea640
merci Chantal
Absolument pas !
Il n'y a aucune sollicitation de la part de Malwarebytes pour inciter l'utilisateur, ni le harceler pour qu'il reste sous la version Premium payante ou pour acheter la version Premium quand il est sous la version gratuite.[/quote]
Tu as raison, il n'y a pas de sollicitation de passer à la version payante, ce qui est très louable, parce que c'est un bel outil, même en version gratuite.
Les analyses se font à plus grande vitesse qu'avant et il y a plusieurs petites modifications fonctionnelles, comme la gestion des comptes-rendus, le lancement direct sans élévation de privilèges, la disparition du paramétrage sur l'obsolescence de la base de données, l'export du résumé d'analyse dans le presse-papier, etc.
breizhspotlight
Message par breizhspotlight »
le seul point que je regrette c'est que contrairement à avant, la licence premium est à l'année et non plus à vie... si j'avais su j'en aurais acheté deux....
