Mise à jour cumulative KB4013429 - Windows 10
Une mise à jour cumulative KB4013429 pour Windows 10 est distribuée via Windows Update.
March 14, 2017—KB4013429 (OS Build 14393.953)
Improvements and fixes
Addressed known issue called out in KB3213986. Users may experience delays while running 3D rendering apps with multiple monitors.
Addressed issue in KB3213986 where the Cluster Service may not start automatically on the first reboot after applying the update.
Addressed issue where the Active Directory Administrative Center (ADAC) crashes when attempting to modify any attribute of any user account in Active Directory.
Addressed issue where the Japanese Input Method Editor is leaking graphics device interface resources, which causes windows to disappear or only partially render after typing approximately 100 sentences.
Addressed an issue which improves the reliability of Enable-ClusterS2D PowerShell cmdlet.
Addressed an issue where the Virtual Machine Management Service (Vmms.exe) may crash during a live migration of virtual machines.
Improved the bandwidth of SSD/NVMe drives available to application workloads during S2D rebuild operations.
Addressed issue where Work Folders clients get duplicate files (sync conflict files) when Work Folders is configured using Group Policy.
Addressed an issue where Remote Desktop Servers crash with a Stop 0x27 in RxSelectAndSwitchPagingFileObject when RDP clients connect and utilize redirected drives, printers, or removable USB drives.
Addressed issue where adjusting the Windows Server Update Services settings using the Group Policy feature causes downloads to fail.
Addressed issue to hard code Microsoft's first-party provider registry key values.
Addressed issue that causes the System Preparation (Sysprep) tool to fail.
Addressed issue that causes Office 2016 profile corruption when used with User Experience Virtualization (UE-V) roaming.
Addressed issue that causes the Local Security Authority Subsystem Service to become unresponsive after upgrading the OS.
Addressed issue that causes the Local Security Authority Subsystem Service to fail when a SAP® application uses Transport Layer Security authentication.
Addressed issue where sequencing large registries using the Application Virtualization 5.1 Sequencer results in missing registry keys in the final package.
Addressed issue that fails to retain the sort order of names in a contact list after a device restarts when using the Japanese language.
Addressed issue that causes transactions to fail because of a memory shortage.
Addressed issue that allows files that are forbidden by the security zone setting to be opened in Internet Explorer.
Addressed issue that causes Internet Explorer 11 to fail after installing KB3175443.
Addressed issue that causes applications that use the VBScript engine to fail after applying KB3185319.
Addressed issue that occurs in Internet Explorer when the CSS float style is set to "center" in a webpage.
Addressed issue that occurs whenever the multipath IO attempts to log I/O statistics with no paths present.
Addressed issue that causes a 32-bit static route added by a VPN solution to fail, which prevents users from establishing a connection through the VPN.
Addressed issue that may decrease performance by up to 50% when Ethernet adapters that support receive side scaling (RSS) fail to re-enable RSS after a fault or system upgrade.
Addressed issue to allow wildcards in the Allowed list field for the Point and Print Restrictions Group Policy.
Addressed issue with multipath I/O failure that can lead to data corruption or application failures.
Addressed issue that can lead to system failure when removing a multipath IO ID_ENTRY.
Addressed issue that occurs when a Network Driver Interface Specification function NdisMFreeSharedMemory() is not called at the correct Interrupt Request Level.
Addressed issue to utilize the proper service vault for Azure Backup integration.
Addressed issue where SQL server takes 30 minutes to shut down on machines with a lot of RAM (>2TB).
Addressed additional issues with updated time zone information, Internet Explorer, file server and clustering, wireless networking, Map apps, mobile upgrades for IoT, display rendering, USB 2.0 safe removal, multimedia, Direct3D, Microsoft Edge, enterprise security, Windows Server Update Services, storage networking, Remote Desktop, clustering, Windows Hyper-V, and Credential Guard.
Security updates to Microsoft Edge, Internet Explorer, Microsoft Graphics Component, Internet Information Services, Windows SMB Server, Microsoft Windows PDF Library, Windows kernel-mode drivers, Microsoft Uniscribe, the Windows kernel, DirectShow, the Windows OS, and Windows Hyper-V.
This update replaces the previously released update KB4010672.
For a list of the files that are provided in this update, download the file information for cumulative update KB4013429. If you're installing a Windows 10 update for the first time, the package size for the X86 version is 579 MB and the package size for the x64 version is 1,105 MB.
https://support.microsoft.com/fr-fr/help/4013429/windows-10-update-kb4013429
Windows 10 - 1607 passe à la version 14393.953
https://www.catalog.update.microsoft.com/Search.aspx?q=KB4013429
Pour info, d'autres mises à jour sont installées :
Re: Mise à jour cumulative KB4013429 - Windows 10
Après installation de ce Patch Tuesday de mars 2017, une information apparaît dans Windows Update
Le lien Oui, montrez moi comment faire ouvre cette page Windows 10 Creators Update bientôt disponible - Windows Help
Nous vous remercions d'avoir exprimé votre intérêt en vue de devenir l'une des premières personnes à découvrir Windows 10 Creators Update !
Nous finalisons la mise à jour et nous serons très bientôt en mesure de la partager avec vous. Une fois que la mise à jour est prête pour votre appareil, vous recevrez une notification vous demandant de vérifier vos paramètres de confidentialité avant de télécharger la mise à jour.
Vous souhaitez obtenir un aperçu en avant-première des prochaines innovations Windows ? Devenez un Windows Insider. Grâce au Programme Windows Insider, vous avez accès à des aperçus, vous fournissez des commentaires et vous nous aidez à façonner l’avenir de Windows.
Pour en savoir plus sur les nouvelles fonctionnalités et les technologies de sécurité, consultez notre page des fonctionnalités à venir.
Bientôt disponibles dans Windows 10
Cette mise à jour cumulative m'a semblé encore plus longue à installer que d'habitude, en particulier au redémarrage le temps d'attente sur écran bleu avant affichage du pourcentage de progression.
Le nombre de corrections est vraiment important : c'est à se demander comment notre système parvenait à fonctionner avant l'installation de la KB401329. :mdr:
Je n'ai pas vu mention spécifique de correction pour le bug concernant le dossier WindowsApps et empêchant la restauration du système.
Je crains donc qu'il ne soit pas résolu par cette mise à jour.
Ce matin, en ouvrant ma machine, je trouvais qu'elle ramait, jusqu'à ce que je lise cette info. Un saut sur UPDATE, et j'ai vite compris.
20 minutes après, tout a été terminé.
Merci et @+
Merci chantal11 pour cette info,
Je n'ai pas "encore" reçu la mise à jour, au vu des réponses, je ne suis pas pressé.
"PatriciaG a dit:
Merci d'y penser, dommage :?
greg250
Message par greg250 »
Pfuiii! Anxieux moi, jamais ? J'ai cru encore une fois que c'était tout planté, mais non! C'est pas un café que vous avez le temps de boire, mais une bassine! Je vais soigner mon ulcère! :lol:
Pour préserver ton estomac, tu peux lancer la mise à jour et partir dans le jardin planter quelques fleurs et désherber ...... et si tu n'as pas de jardin, faire une grande balade à pieds, au moins 10 tours de quartier :bubulle:
La mise à jour a duré 2 bonnes heures, mais c'est fait.
Vu aussi cette possibilité de télécharger l'outil RefreshWindowsTool ici, lien depuis paramètres de sécurité > voir "comment recommencer à zéro avec une nouvelle install Windows" qui mène ici:
https://www.microsoft.com/fr-fr/softwar ... startfresh
Sans doute ce me sera utile pour le PC de bureau qui...s'abandonne à sa nature mauvaise :D
Il est clair que c'était annoncé depuis un moment.
RAS pour le reste, à découvrir
mwonex a écrit :
"PatriciaG a dit:
De rien.
Je n'ai pas de mérite, je m'intéresse de près à ce sujet.
mwonex a écrit :[Vu aussi cette possibilité de télécharger l'outil RefreshWindowsTool ici, lien depuis paramètres de sécurité > voir "comment recommencer à zéro avec une nouvelle install Windows" qui mène ici:
Merci d'avoir souligné ce point.
C'est une fonctionnalité bien utile.
mwonex a écrit :[Sans doute ce me sera utile pour le PC de bureau qui...s'abandonne à sa nature mauvaise :D
Ne le cherche pas trop, sous peine qu'il se venge. :mrgreen: :geek:
greg250
A Chantal11: Héhé!J'habite un petit village de montagne et je fait tous les jours le tour du "quartier" en prévision des maux d'estomac que me donnent les MAJ Windows : :lol: Plus sérieusement, c'est incroyable que des éléments nouveaux qui somme toute ne pèsent pas si lourd, soient une torture pour l'installation de ces mèmes éléments!
