Mise à jour cumulative KB4015438 - Windows 10
Une mise à jour cumulative KB4015438 pour Windows 10 est distribuée via Windows Update.
March 20, 2017—KB4015438 (OS Build 14393.969)
Improvements and fixes
Addressed a known issue with KB4013429 that caused Windows DVD Player (and 3rd party apps that use Microsoft MPEG-2 handling libraries) to crash.
Addressed a known issue with KB4013429, that some customers using Windows Server 2016 and Windows 10 1607 Client with Switch Embedded Teaming (SET) enabled might experience a deadlock or when changing the physical adapter’s link speed property. This issue is most commonly seen as a DPC_WATCHDOG_VIOLATION or when verifier is enabled a VRF_STACKPTR_ERROR is seen in the Memory dump.
Known issues in this update
Microsoft is not currently aware of any issues with this update.
How to get this update
This update can be downloaded and installed from Windows Update. To get the stand-alone package for this update, go to the Microsoft Update Catalog website.
Update replacement information
This update replaces the previously released update KB4013429.
File information
For a list of the files that are provided in this update, download the file information for cumulative update KB4015438. If you're installing a Windows 10 update for the first time, the package size for the X86 version is 566 MB and the package size for the x64 version is 1,106 MB.
https://support.microsoft.com/en-au/help/4015438/windows-10-update-kb4015438
Windows 10 - 1607 passe à la version 14393.969
Build 2014393.969.png (81.87 Kio) Consulté 3401 fois
http://www.catalog.update.microsoft.com/Search.aspx?q=KB4015438
greg250
Re: Mise à jour cumulative KB4015438 - Windows 10
Message par greg250 »
c'est fait, avec le Maalox à portée de main! :mrgreen:
Bonjour greg250,
Cette mise à jour m'a aussi causé des frayeurs, avec trois redémarrages au total entrecoupés par un écran noir !
Cela sur le premier pc, depuis je l'ai installée sur trois autres machines avec sérénité. :mrgreen:
C'est fait pour moi aussi. Pas de frayeur, pas d'écran noir, 2 redémarrages, le 2ème étant le bon, mais long. 1 heure montre en main !
greg250
Bonjour Patriciag, je n'ai pas eu droit comme vous aux plusieurs redémarrages (Microsoft doit connaitre mes blèmes d'estomac :mrgreen: ) et j'installe à l'instant cette kb sur le portable et nous verrons bien! Je reste persuadé que certains doivent avoir le mauvais reflex de faire un reset devant un écran bleu et qui de surcroit dure très longtemps, avec pour toute indication:" Windows installe la mise à jour, n’éteignez pas votre ordinateur". Je ne me souvient pas avec Windows seven si nous étions aussi stressés à chaque MAJ! Tout cela manque d'indications sous forme de messages sur le déroulement de cette install, ce qui pourrait éviter le pire comme évoqué plus haut! Ceci n'engage que moi bien sûr! A Plus tard, Greg.
Re greg250,
En fait, le nombre de redémarrages et d'écrans noirs dépend vraiment des configurations.
Entre temps, je viens d'installer cette mise à jour sur un autre pc et un seul redémarrage sans écran noir a été effectué.
Eteindre le pc pendant l'installation d'une maj cumulative est une très mauvaise idée, souvent génératrice de bugs sévères.
greg250
** je te cite : Éteindre le pc pendant l'installation d'une maj cumulative est une très mauvaise idée, souvent génératrice de bugs sévères. Hélas c'est malheureusement ce qui arrive de temps en temps, et c'est pour cela que je préconiserai une indication sur le déroulement de l'installation. Mon portable est mis à jour très rapidement avec un seul redémarrage avec un ssd tout neuf que je lui ai installé hier! Comme quoi effectivement cela dépend du matériel! :super:
Pourquoi est-ce ce qui arrive ?
Il suffit de ne pas éteindre le pc et de patienter !
Je ne suis pas un grand spécialiste de l'informatique, j'ai appris avec des tiers petit à petit, depuis 1991, je me suis renseigné à droite à gauche, j'ai cherché et cherché encore tout seul, et j'arrive à me débrouiller.
En ce qui concerne les MAJ, comme dit Patricia, j'ai vite compris qu'il ne fallait pas faire de reset ou forcer l'arrêt, et je pense que l'inscription : "Windows installe la mise à jour, n’éteignez pas votre ordinateur" est tout à fait claire, et il faut la respecter.
Si après 5 ou 6 heures (Je dis au hasard) il n'y a rien de nouveau, là c'est que c'est flou, et quand c'est flou, il y a un loup :)
greg250
Salut Tony37, je suis comme toi quelqu’un qui à appris seul et depuis de nombreuses années. Je croit être plutôt débrouillard et il m'est arrivé par le passé de choisir les éléments des pcs que j'ai construit, de les installer et aussi les Os du moment Win 95, 98, xp....etc..Donc je sait que je connais rien ou tout du moins pas grand chose et j'ai surtout appris en faisant des grosses co......! Ce que je veux dire c'est que y compris des geeks,certains sont tentés d'appuyer sur ce bouton pensant bien faire! je l'ai vu de mes yeux! De plus le message mème si il est explicite, mais que celui-ci ,ne bouge pas d'un iota pendant d'interminable minutes et bien ils considèrent que leur pc est bien "planté" (nous nous le savons qu'il ne l'est pas, eux peut être pas)!Greg. :super:
