Mise à jour cumulative KB4015217 - Windows 10 - version 1607
La mise à jour cumulative KB4015217 est disponible via Windows Update pour Windows 10 - version 1607
Improvements and fixes
This security update includes quality improvements. No new operating system features are being introduced in this update. Key changes include:
Addressed issue that was preventing the Camera application from saving a captured image when "Show recently opened items in Jump Lists on Start or the taskbar" settings is enabled.
Improved the Host Network Service (HNS) to support an overlay network driver for use on Windows Server 2016 to connect containers across hosts using Docker Engine in Swarm Mode.
Addressed issue that was not allowing users to access online help content when clicking the help icon in various Windows applications, such as File Explorer.
Addressed issue where displays turn off unexpectedly even when Turn off display and Screen saver are disabled in the power profile.
Addressed an issue where CredentialGuard-enabled computers joined to Active Directory domains submit two bad logon attempts each time a bad password is provided during a Kerberos-based logon. Logons to Active Directory domains with arbitrarily low account lockout thresholds may be subject to unexpected account lockouts. For example, 2 logons with a bad password could result in an account being locked out if the account lockout threshold is set to 3 or 4.
Addressed issue that increases CPU usage when IP forwarding or weak host is enabled.
Addressed issue where some of the VPN drivers do not get migrated when upgrading the OS to Windows 10, version 1607.
Addressed issue that causes virtual machines to fail during high I/O scenarios where the user may log in multiple times.
Addressed issue that was causing connections (after the 1st connection request) from a Remote Desktop Client to a Remote Desktop session to fail after upgrading from Windows 10, version 1511, to Windows 10, version 1607.
Addressed issue that was causing the Command prompt to be not displayed properly through the serial console on headless systems.
Addressed issue that was causing MDM enrollment failtures on devices using Kerberos authentication.
Addressed issue with rendering when a webpage contains a DIV element that has the contenteditable attribute.
Addressed issue that causes text to disappear when you resize an Internet Explorer window when the encoding is Hebrew and any text ends with an underscore character.
Addressed issue that was causing headless machines to not go into S3 sleep mode sometimes.
Enabled warning message in Group Policy Management Console (GPMC) to alert administrators of a design change that may prevent the processing of a User Group after installing security update MS16-072 (KB3163622).
Addressed an issue that was causing Windows Explorer to perform an endless, rapid refresh of a network drive that is mapped to a share, preventing users from performing tasks such as rename object.
Addressed a memory leak in Internet Explorer when hosting a page that contains nested framesets, which load cross-domain content.
Addressed an issue that was causing the print spooler service to hang instead of showing a timeout error when a connection between a bluetooth printer and the machine is lost during printing.
Addressed an issue that was preventing installation of a new printer driver that uses v3 printer drivers.
Improved the reliability of Load Balancing/Failover (LBFO) whenever there is a resource rebalance, a device failure, or a surprise removal of a device.
Addressed additional issues with updated time zone information, Internet Explorer, and Microsoft Edge.
Security updates to Scripting Engine, libjpeg image-processing library, Hyper-V, Win32k, Adobe Type Manager Font Driver, Internet Explorer, Microsoft Edge, Graphics component, Active Directory Federation Services, .NET Framework, Active Directory, Lightweight Directory Access Protocol, Windows Kernel model drivers and Windows OLE.
This update replaces the previously released update KB4016635
https://support.microsoft.com/en-us/hel ... -kb4015217
KB4015217
Un redémarrage est requis.
La version Windows 10 passe à 14393.1066 et 14393.1083
Chino
Re: Mise à jour cumulative KB4015217 - Windows 10 - version 1607
Message par Chino »
J'avais commencé a télécharger ,mais cette KB est pour Windows 10 Version 1607 , mais j'allais encore faire une bêtise :o , j'ai Windows 10 Version 1703 , donc ce n'est pas pour le système a bibi :)
Oui, attention, pendant quelques temps nous allons suivre les mises à jour cumulatives pour les 2 versions 1607 et 1703.
En effet, ce n'est qu'une minorité qui a migré vers la Creators Update 1703, la très grande majorité des utilisateurs vont rester sous la version 1607 jusqu'à ce que la 1703 leur soit proposée.
Cela peut prendre quelques semaines, voire plusieurs mois ;)
