Mise à jour cumulative KB4041676 - Windows 10 - version 1703
La mise à jour cumulative KB4041676 est disponible via Windows Update pour Windows 10 - version 1703
Improvements and fixes
Addressed issue where some UWP and Centennial apps show a gray icon and display the error message "This app can't open" on launch.
Addressed reliability issue that causes the AppReadiness service to stop working.
Addressed issue where applications that use the Silverlight map stack stop working.
Addressed issue where VSync prevents devices from entering Panel Self Refresh mode, which can lead to reduced battery life.
Addressed issue where user customizations (like pinned tiles) made to an enforced partial Start layout are lost when upgrading to Windows 10 1703.
Addressed issue where the Universal CRT caused the linker (link.exe) to stop working for large projects.
Addressed issue that prevents Windows Error Reporting from saving error reports in a temporary folder that is recreated with incorrect permissions. Instead, the temporary folder is inadvertently deleted.
Addressed issue where the MSMQ performance counter (MSMQ Queue) may not populate queue instances when the server hosts a clustered MSMQ role.
Addressed issue with the token broker where it was leaking a token that caused sessions to remain allocated after logoff.
Addressed issue where Personal Identity Verification (PIV) smart card PINs are not cached on a per-application basis. This caused users to see the PIN prompt multiple times in a short time period; normally, the PIN prompt only displays once.
Addressed issue where using the Cipher.exe /u tool to update Data Recovery Agent (DRA) encryption keys fails unless user certification encryption already exists on the machine.
Addressed issue where using AppLocker to block a Modern app fails. This issue occurs only with Modern apps that come pre-installed with Windows.
Addressed issue with form submissions in Internet Explorer.
Addressed issue with the rendering of a graphics element in Internet Explorer.
Addressed issue that prevents an element from receiving focus in Internet Explorer.
Addressed issue with the docking and undocking of Internet Explorer windows.
Addressed issue caused by a pop-up window in Internet Explorer.
Addressed issue where a Vendor API deleted data unexpectedly.
Addressed issue where using the Robocopy utility to copy a SharePoint document library, which is mounted as a drive letter, fails to copy files. However, in this scenario, Robocopy will copy folders successfully.
Addressed issue where MDM USB restrictions did not disable the USB port as expected.
Addressed issue where creating an iSCSI session on a new OS installation may result in the "Initiator instance does not exist" error when attempting to connect to a target.
Addressed issue where connecting to RDS applications published using Azure App Proxy fails. The error message is, “Your computer can’t connect to the Remote Desktop Gateway server. Contact your network administrator for assistance”. The error can occur when the RDP cookie size limit is exceeded. This update increased the size of the RDP cookie limit.
Addressed issue where USBHUB.SYS randomly causes memory corruption that results in random system crashes that are extremely difficult to diagnose.
Addressed issue that affects the download of some games from the Microsoft Store during the pre-order phase. Download fails with the error code 0x80070005, and the device attempts to restart the download from the beginning.
Addressed issue where the ServerSecurityDescriptor registry value does not migrate when you upgrade to Windows 10 1703. As a result, users might not be able to add a printer using the Citrix Print Manager service. Additionally, they might not be able to print to a client redirected printer, a Citrix universal print driver, or a network printer driver using the Citrix universal print driver.
Security updates to Microsoft Windows Search Component, Windows kernel-mode drivers, Microsoft Graphics Component, Internet Explorer, Windows kernel, Microsoft Edge, Windows Authentication, Windows TPM, Device Guard, Windows Wireless Networking, Windows Storage and Filesystems, Microsoft Windows DNS, Microsoft Scripting Engine, Windows Server, Windows Subsystem for Linux, Microsoft JET Database Engine, and the Windows SMB Server.
https://support.microsoft.com/fr-fr/hel ... -kb4041676
KB4041676
Un redémarrage est requis.
La version Windows 10 passe à 15063.674
Autre mise à jour :
- Outil de suppression de logiciels malveillants - octobre 2017
Re: Mise à jour cumulative KB4041676 - Windows 10 - version 1703
Le téléchargement se fait depuis une heure, bloqué à 3% pendant 40 mn et maintenant bloqué à 22% depuis 15 mn !
Je dois aller dormir, alors on va laisser faire cette nuit et on verra demain matin.
C'est pareil pour moi, gros blocage pendant 1h30, puis installation en mode autonome.
Il n'y a pas de MAJ de Flash Player pour Edge et IE cette fois-ci.
Pour ces navigateurs sous W10, Flash Player reste à la version 27.0.0.130.
En revanche, des mises à jour sont disponibles pour Mozilla Firefox (plugin NPAPI), Google Chrome (plugin PPAPI) et Internet Explorer (Active X pour W7) et Flash Player passe alors à la version 27.0.0.159.
Finalement, je suis resté jusqu'à la fin hier soir, et tout s'est bien passé. 1 h 40 au total.
greg250
Message par greg250 »
Bonjour, cette MAJ c'est faite relativement vite pour moi (une vingtaine de minutes) sur le PC fixe et je suis en train de faire celle du portable!Greg.
Chino
Message par Chino »
N'ayant pas un débit internet des plus extraordinaires , a peine 30 minutes pour cette mise a jour
