Mise à jour cumulative KB4048955 - Windows 10 - version 1709
La mise à jour cumulative KB4048955 est disponible via Windows Update pour Windows 10 - version 1709
Improvements and fixes
Addressed issue that causes the Mixed Reality Portal to stop responding on launch.
Addressed issue that causes a black screen to appear when you switch between windowed and full-screen modes when playing some Microsoft DirectX games.
Addressed a compatibility issue that occurs when you play back a Game DVR PC recording using Android or iOS devices.
Addressed issue where the functional keys stop working on Microsoft Designer Keyboards.
Addressed issue to ensure that certain USB devices and head-mounted displays (HMD) are enumerated properly after the system wakes up from Connected Standby.
Addressed issue where the virtual smart card doesn't assess the Trusted Platform Module (TPM) vulnerability correctly.
Addressed issue where Get-StorageJob returns nothing when there are storage jobs running on the machine.
Addressed issue where applications based on the Microsoft JET Database Engine (Microsoft Access 2007 and older or non-Microsoft applications) fail when creating or opening Microsoft Excel .xls files. The error message is: “Unexpected error from external database driver (1). (Microsoft JET Database Engine)".
Addressed issue where application tiles are missing from the Start menu. Additionally, applications that the Store app show as installed don't appear on the application list of the Start menu. Computers that have Internet connectivity and upgrade on or after November 14, 2017 will receive this preventative solution and avoid this issue. Machines that lack network connectivity or have already encountered this issue should follow the steps in the Microsoft Answers thread “Missing apps after installing Windows 10 Fall Creators Update”. Microsoft will release and document an additional solution in a future release.
Addressed issue where Microsoft Edge cannot create a WARP support process and appears to stop responding for up to 3 seconds during a wait timeout. During the timeout period, users cannot navigate or interact with the requested page.
Security updates to Microsoft Scripting Engine, Microsoft Edge, Microsoft Graphics Component, Windows kernel, Internet Explorer, and Windows Media Player.
https://support.microsoft.com/fr-fr/hel ... -kb4048955
KB4048955
Un redémarrage est requis.
La version Windows 10 passe à 16299.64
Autres mises à jour :
- KB4048951 - Mise à jour de sécurité pour Adobe Flash Player
- Outil de suppression de logiciels malveillants - novembre 2017
Re: Mise à jour cumulative KB4048955 - Windows 10 - version 1709
Merci pour l'information.
Cette mise à jour s'installe rapidement malgré le redémarrage.
J'ai constaté une différence avec les autres maj cumulatives : à la fin de l'installation, je dois me connecter, alors que d'habitude, le bureau s'affiche directement après la mise à jour.
J'ai vérifié ce phénomène sur deux PC.
C'est surprenant, car le paramètre Utilisez mes informations de connexion pour terminer automatiquement la configuration de mon appareil après une mise à jour ou un redémarrage obtenu par le chemin
Menu Paramètres > Comptes > Options de connexion > Confidentialité
est activé sur les deux machines.
Patriciag a écrit : à la fin de l'installation, je dois me connecter, alors que d'habitude, le bureau s'affiche directement après la mise à jour.
Je n'ai pas eu à me connecter, sur aucun de mes PC, après cette mise à jour.
Tout s'est déroulé comme d'habitude.
Bonjour Chantal,
C'est donc curieux pour les deux pc que j'ai mis à jour, mais pas grave.
Edit à 5h45 le 15/11/2017J
Sur un des deux PC mis à jour, J'ai dû désinstaller/réinstaller la KB4048955 pour faire un test sur des mises à jour de pilotes.
J'en ai profité pour réaliser un autre test : j'ai désactivé la demande de mot de passe avant de réinstaller la KB4048955.
Cette fois, après installation, le bureau s'est affiché directement sans passer par l'écran de connexion.
Je vérfierai cela sur d'autres installations dans les jours à venir.
Dans les versions précédentes, même avec un compte muni d'une connexion par mot de passe, après redémarrage suite à l'installation d'une mise à jour cumulative, le bureau s'affichait directement sans passer par l'écran de connexion.
