La mise à jour cumulative KB4048954 est disponible via Windows Update pour Windows 10 - version 1703
https://support.microsoft.com/fr-fr/help/4048954Improvements and fixes
Addressed issue where applications based on the Microsoft JET Database Engine (Microsoft Access 2007 and older or non-Microsoft applications) fail when creating or opening Microsoft Excel .xls files. The error message is: “Unexpected error from external database driver (1). (Microsoft JET Database Engine)".
Addressed issue where the RDP Connection from a Windows 10 1703 client to Windows Server 2008 R2 fails with the error: "An internal error occurred". This problem occurs when the server is configured in RemoteFX mode. You may also see a black or incorrectly painted screen.
Addressed issue where, after an OS upgrade, setting an offline schedule in the Sync Center applet of Control Panel fails. The error message that appears is: "Sync Center Error. An error occurred displaying sync schedules. Error: 0x80070005. Access Denied."
Addressed issue where RemoteApp and Desktop Connection settings fail to apply when you set them using Group Policy or a script.
Addressed issue where the virtual smart card doesn't assess the Trusted Platform Module (TPM) vulnerability correctly.
Addressed issue where opening Microsoft Office files from a file server that has Windows Information Protection enabled fails with the error: “Sorry we couldn't open document xxxx”.
Addressed issue where, when using the FDVDenyWriteAccess policy, Windows will continue to prevent a drive from being made writable even after BitLocker encryption completes.
Addressed issue where Surface Hub devices cannot connect to Azure Active Directory to log on when they are behind a proxy server.
Addressed issue where attempting to clean temporary files on the Windows Phone results in the error code “E_FAIL”.
Addressed issue where the functional keys stop working on Microsoft Designer Keyboards.
Addressed issue where modern applications built using JavaScript may fail to initialize.
Addressed issue where GetWindowLong may fail when called on a window whose thread isn't processing Windows messages.
Addressed issue where, after installing KB4038788 and rebooting, a black screen appears with only a cursor, and you must reboot in order to log in successfully.
Addressed issue in Internet Explorer where an intranet site was being treated as an internet site.
Addressed a memory leak in Microsoft Edge caused by the startup of an internal process.
Addressed issue with the launch of HTML dialogs in Windows PE systems.
Addressed issue with scrolling that sometimes causes Microsoft Edge to stop responding.
Addressed a crash in Internet Explorer that was seen in machines that used large font-size settings.
Addressed issue where the PDF download progress bar stops when opening a PDF file from a cloud-backed web services site.
Security updates to Internet Explorer, Microsoft Scripting Engine, Microsoft Edge, Windows kernel, Windows kernel-mode drivers, Microsoft Graphics Component, the Microsoft Windows Search Component, and Windows Media Player.
KB4048954
Un redémarrage est requis.
La version Windows 10 passe à 15063.726 ou 15063.728
Autres mises à jour :
- KB4048951 - Mise à jour de sécurité pour Adobe Flash Player
- Outil de suppression de logiciels malveillants - novembre 2017
