Mise à jour cumulative KB4051963 - Windows 10 - version 1709
La mise à jour cumulative KB4051963 est disponible via Windows Update pour Windows 10 - version 1709
Improvements and fixes
Addressed a script-related issue that caused Internet Explorer to stop working in some cases.
Addressed issue with the Input Method Editor’s (IME) text input window for Internet Explorer.
Addressed issue with rendering a graphics element in Internet Explorer.
Addressed issue with form submissions in Internet Explorer.
Addressed issue where the Location-hash is lost when navigating back if you previously navigated to an invalid URL.
Addressed issue where applications may stop responding for customers who have internet or web proxies enabled using PAC script configurations. This is a result of a reentrancy deadlock in WinHTTP.dll. This can result in the following:
Microsoft Outlook cannot connect to Microsoft Office365.
Internet Explorer and Microsoft Edge cannot successfully render any content (including local computer content, local network content, or web content).
Cisco Jabber stops responding, which blocks messaging and telephony features.
Any application or service that relies on WinHTTP is impacted.
Addressed a performance regression when users run full-screen Microsoft DirectX 9 games and applications.
Addressed issue that prevents Forza Motorsport 7 and Forza Horizon 3 from running on some high-end gaming laptop configurations.
Addressed issue where user selections for Feedback Frequency in Settings > Privacy > Feedback & diagnostics aren't saved.
Addressed issue where RNDIS5 networking devices don't get a valid IP address or don't show network connectivity. If the issue continues after installing the update, you may need to uninstall and reinstall your Remote NDIS network adapter using Device Manager.
Addressed issue where if a user manually changes the system's time zone and doesn't log off or restart, the new time doesn't display on the Lockscreen clock.
Addressed issue that impacted some Epson SIDM (Dot Matrix) and TM (POS) printers, which were failing to print on x86 and x64-based systems. This issue affects KB4048955.
https://support.microsoft.com/fr-fr/hel ... -kb4051963
KB4051963
Un redémarrage est requis.
La version Windows 10 passe à 16299.98
Edit :
Autre Mise à jour :
- KB4054022 - Mise à jour de la pile de maintenance
Installation silencieuse en parallèle de la MaJ cumulative - Vérifier dans Panneau de configuration -> Programmes et fonctionnalités -> Mises à Jour installées
Re: Mise à jour cumulative KB4051963 - Windows 10 - version 1709
L'écran noir après redémarrage est assez long pour être flippant, puis il laisse place à l'affichage du pourcentage d'avancement, à partir de 90%.
Quand le bureau d'affiche, on retrouve le cartouche "Paramètres personnalisés" affuch brièvement et désormais familier.
Mathusalem
Message par Mathusalem »
Bonjour ,
Chargement rapide et installation sans problème .
Cdt ,
Math
Une autre mise à jour KB4054022 pour Windows 10 - version 1709
Mise à jour de la pile de maintenance pour Windows 10 Version 1709 : le 30 novembre 2017
https://support.microsoft.com/fr-fr/hel ... er-30-2017
Cette mise à jour apporte des améliorations de stabilité de la pile de maintenance Windows 10 Version 1709.
KB4054022
Je n'ai que cette dernière qui s'affiche, l'autre parait zappée, est-ce cumulatif?
Capture-MAJ 4051963.JPG (16.02 Kio) Vu 2532 fois
Non, la mise à jour de la pile KB4054022 est indépendante.
Elle figure peut-être dans ton historique de Windows Update, si elle est installée avant la Mise à jour cumulative KB4051963.
Sinon, regarde si elle est dans les maj installées du panneau de configuration.
Je l'avais signalé en Edit dans mon 1er message, se référer à cette note ajoutée.
Mise à jour réalisée sans difficulté, et rapidement.
Pour la KB4054022, je ne l'avais pas dans les paramètres, et j'ai essayé de la télécharger comme indiqué par Chantal ici
mais il était indiqué que cette maj ne s'appliquait pas à ma machine.
Et j'ai eu l'explication par Patricia, en allant sur le panneau de configuration, où j'ai effectivement cette KB installée.
Merci pour l'info
Ah oui, vu en effet indépendante OK
Je note que cette mise à jour apparait dans paramètres -désinstaller, mais pas dans l'historique (après essai en mode autonome ne voyant pas cette Mise à jour:
Capture-mode autonome-KB4054022 est déjà installé.JPG (52.21 Kio) Vu 2502 fois
greg250
Message par greg250 »
MAJ faite mais, avec une curiosité , à savoir que Windows update me signale un"échec de l'installation de la kb4051963 avec comme erreur le 0x80070643 (pare feu de défender?). En allant voir dans l'historique du panneau de config, la kb 4051963 et aussi la kb 4054022 sont bien installées! Windows est bien à la version 16299.98. Curieux, non? NB: Le pare feu de défender est bien activé et tout fonctionne, donc...
Autre curiosité, sur mon portable, la MAJ commence (installation à 0%) et au bout d'un moment, Windows me dit qu'il n'y a pas de MAJ de disponible et circulez il n'y a rien à voir! :mrgreen: Greg.
