Mise à jour cumulative KB4057144 - Windows 10 - version 1703
Une mise à jour cumulative KB4057144 est disponible dans le Catalogue Microsoft Update pour Windows 10 - version 1703
Improvements and fixes
Addresses issue with printing PDFs in Microsoft Edge.
Addresses issue with the App-V package folder access that cause the access control list to be handled incorrectly.
Addresses issue where backwards compatibility for managing Microsoft User Experience Virtualization (UE-V) with group policy is lost. Windows 10 version 1607 group policy isn't compatible with Windows 10 version 1703 or higher group policy. Because of this bug, the new Windows 10 Administrative Templates (.admx) cannot be deployed to the Group Policy Central Store. This means that some of the new, additional settings for Windows 10 aren't available.
Addresses issue where some Microsoft-signed ActiveX controls don't work when Windows Defender Application Control (Device Guard) is enabled. Specifically, class IDs related to XMLHTTP in msxml6.dll don't work.
Addresses issue where, when attempting to change the Smart Card for Windows service start type from Disabled to Manual or Automatic, the system reports an error: “Cannot create a file when that file already exists.”
Addresses issue where some applications are blocked from running by Windows Defender Device Guard or Windows Defender Application Control when the application runs in Audit only enforcement mode.
Addresses issue where the virtual TPM self-test isn't run as part of virtual TPM initialization.
Addresses issue with NoToastApplicationNotificationOnLockScreen GPO that causes Toast notifications to appear on the lock screen.
Addresses issue originally called out in KB4056891 where calling CoInitializeSecurity with the authentication parameter set to RPC_C_AUTHN_LEVEL_NONE resulted in the error STATUS_BAD_IMPERSONATION_LEVEL.
Addresses issue where some customers with AMD devices get into an unbootable state.
https://support.microsoft.com/fr-fr/hel ... -kb4057144
Disponible uniquement dans le Catalogue Microsoft Update
KB4057144
Un redémarrage est requis.
La version Windows 10 passe à 15063.877
Note importante :
Consulter la fiche du support pour cette KB4057144, des problèmes connus y sont listés avec leurs solutions de contournement :
- En raison d'un problème avec certaines versions du logiciel antivirus, ce correctif s'applique uniquement aux ordinateurs sur lesquels l'antivirus ISV a mis à jour ALLOW REGKEY.
