Mise à jour cumulative KB4074588 - Windows 10 - version 1709
La mise à jour cumulative KB4074588 est disponible via Windows Update pour Windows 10 - version 1709
Improvements and fixes
Addresses issue where child accounts are able to access InPrivate mode on ARM devices even though their browsing and search history is sent to their parents. This occurs only on Microsoft accounts belonging to children that are managed using the Microsoft Family service and for which parents have enabled activity reporting. This applies to Microsoft Edge and Internet Explorer.
Addresses issue with docking and undocking Internet Explorer windows.
Addresses issue in Internet Explorer where pressing the delete key inserted a new line in input boxes in an application.
Addresses issue in Internet Explorer where selected elements wouldn't update under certain circumstances.
Addresses issue where some users may have experienced issues logging into some websites when using third-party account credentials in Microsoft Edge.
Updates time zone information.
Addresses issue with browser Compatibility View settings that occurs during updates.
Addresses issue where, in certain hardware configurations, the frame rates of DirectX Games were unintentionally limited to a factor of the display's vertical synchronization.
Addresses issue that causes delays when switching keyboard languages using Alt+Shift.
Addresses issue where surround sound audio endpoints reverted to stereo after restarting.
Improves and reduces conditions where certain Bluetooth keyboards drop keys during reconnection scenarios.
Corrects mouse delays for devices that incorrectly report the battery level status.
Addresses issue where MMC application snap-ins—such as Services, Local Policy Admin, and Printer Management—fail to run when Windows Defender Application Control (Device Guard) is turned on. The error is "Object doesn't support this property or method".
Prevents use of the Pre-production Onesettings endpoint for Windows Setup when test signing is enabled.
Addresses issue where installations of Windows Server, version 1709 are not automatically activated using the Automated Virtual Machine Activation (AVMA) feature on Hyper-V hosts that have been activated.
Addresses issue with the Auto-register Inbox templates feature for UEV where the Scheduled Task didn't have the proper trigger.
Addresses issue where the App-V client didn't read the policy for SyncOnBatteriesEnabled when the policy was set using a Group Policy Object (GPO).
Addresses issue where the Supported On field for the Enable App-V Client policy is blank in the Group Policy editor.
Addresses issue where the user’s hive data in the registry is not maintained correctly when some App-V packages belong to the connection group.
Provides additional logging for administrators to take action, such as picking a proper configuration for their App-V package, when there are multiple configuration files for a single package.
Addresses issue with App-V packages that aren't compatible with registry virtualization using kernel containers. To address the issue, we changed the registry virtualization to use the earlier (non-container) method by default. Customers who would like to use the new (kernel container) method for registry virtualization can still switch to it by setting the following registry value to 1:
Path: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\AppV\Client\Compatibility
Setting: ContainerRegistryEnabled
DataType: DWORD
Security updates to Microsoft Scripting Engine, Microsoft Edge, Internet Explorer, Microsoft Windows Search component, Windows Kernel, Windows Authentication, Device Guard, Common Log File System driver, and the Windows storage and file systems.
https://support.microsoft.com/fr-fr/hel ... -kb4074588
KB4074588
Un redémarrage est requis.
La version Windows 10 passe à 16299.248
Note importante :
Consulter la fiche du support pour cette KB4074588, des problèmes connus y sont listés avec leurs solutions de contournement
Autres Mises à jour :
- Outil de suppression de logiciels malveillants Windows - février 2018 (KB890830)
- KB4087256 Mise à jour de la pile de maintenance (n'apparaît pas dans l'historique Windows Update, mais est listée dans Panneau de configuration > Programmes > Programmes et fonctionnalités > Mise à jour installées
J@M3S
Re: Mise à jour cumulative KB4074588 - Windows 10 - version 1709
Message par J@M3S »
Un peu long chez moi pour l'installation de cette mise à jour.
Par contre pas eu droit à la seconde (KB890830).
Je poste en Fr car le roastbeef j'aime pas trop :mdr:
Cette mise à jour inclut des améliorations de qualité.
Aucune nouvelle fonctionnalité du système d'exploitation n'est introduite dans cette mise à jour.
Les principaux changements comprennent:
• Résout le problème où les comptes enfants peuvent accéder au mode InPrivate sur les périphériques ARM, même si leur historique de navigation et de recherche est envoyé à leurs parents. Cela se produit uniquement sur les comptes Microsoft appartenant à des enfants qui sont gérés à l'aide du service Microsoft Family et pour lesquels les parents ont activé le rapport d'activité. Cela s'applique à Microsoft Edge et Internet Explorer.
• Résout le problème d'ancrage et de désancrage des fenêtres Internet Explorer.
• Résout le problème dans Internet Explorer en appuyant sur la touche de suppression insérée une nouvelle ligne dans les zones de saisie d'une application.
• Adresse problème dans Internet Explorer où les éléments sélectionnés ne seraient pas mis à jour dans certaines circonstances.
• Résout le problème où certains utilisateurs peuvent avoir rencontré des problèmes de connexion à certains sites Web lors de l'utilisation d'informations d'identification de compte tiers dans Microsoft Edge.
• Met à jour les informations de fuseau horaire.
• Résout le problème avec les paramètres d'affichage de compatibilité du navigateur qui se produisent lors des mises à jour.
• Résout le problème où, dans certaines configurations matérielles, les fréquences d'images de DirectX Games étaient involontairement limitées à un facteur de synchronisation verticale de l'affichage.
• Résout le problème qui provoque des retards lors de la commutation des langues du clavier à l'aide de Alt + Maj.
• Résout le problème où les points d'extrémité audio surround sont restitués en stéréo après le redémarrage.
• Améliore et réduit les conditions dans lesquelles certains claviers Bluetooth abandonnent les clés lors des scénarios de reconnexion.
• Corrige les délais de la souris pour les périphériques qui signalent de manière incorrecte l'état du niveau de la batterie.
• Résout le problème de non-exécution des composants logiciels enfichables d'application MMC, tels que les services, l'administration des stratégies locales et la gestion des imprimantes, lorsque le contrôle des applications Windows Defender (Device Guard) est activé. L'erreur est "L'objet ne prend pas en charge cette propriété ou cette méthode".
• Empêche l'utilisation du point de terminaison Pre-production Onesettings pour le programme d'installation de Windows lorsque la signature de test est activée.
• Résout le problème où les installations de Windows Server, version 1709, ne sont pas activées automatiquement à l'aide de la fonction AVMA (Automated Virtual Machine Activation) sur les hôtes Hyper-V qui ont été activés.
• Résout le problème lié à la fonctionnalité de modèles de boîte de réception automatique d'enregistrement pour l'UEV dans laquelle la tâche planifiée n'avait pas le bon déclencheur.
• Résout le problème où le client App-V n'a pas lu la stratégie pour SyncOnBatteriesEnabled lorsque la stratégie a été définie à l'aide d'un objet de stratégie de groupe (GPO).
• Adresse le problème dans lequel le champ pris en charge pour la stratégie Activer le client App-V est vide dans l'éditeur de stratégie de groupe.
• Résout le problème où les données de la ruche de l'utilisateur dans le registre ne sont pas gérées correctement lorsque certains packages App-V appartiennent au groupe de connexions.
• Fournit une journalisation supplémentaire permettant aux administrateurs de prendre des mesures, telles que la sélection d'une configuration appropriée pour leur package App-V, lorsqu'il existe plusieurs fichiers de configuration pour un seul package.
• Résout le problème avec les packages App-V qui ne sont pas compatibles avec la virtualisation du registre à l'aide de conteneurs de noyau. Pour résoudre le problème, nous avons modifié la virtualisation du registre pour utiliser la méthode antérieure (non-conteneur) par défaut. Les clients qui souhaitent utiliser la nouvelle méthode (conteneur de noyau) pour la virtualisation de registre peuvent toujours basculer en définissant la valeur de Registre suivante à 1:
Chemin d'accès: HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ AppV \ Client \ Compatibilité
• Paramètre: ContainerRegistryEnabled
• DataType: DWORD
• Mises à jour de sécurité pour Microsoft Scripting Engine, Microsoft Edge, Internet Explorer, le composant Microsoft Windows Search, le noyau Windows, l'authentification Windows, Device Guard, le pilote Common Log File System et les systèmes de stockage et de fichiers Windows.
Si vous avez installé des mises à jour antérieures, seules les nouvelles corrections contenues dans ce package seront téléchargées et installées sur votre appareil.
Cette mise à jour de sécurité remplace pour x64:
2017-10 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x64 (KB4043961)
2017-11 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x64 (KB4048955)
2017-11 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x64 (KB4051963)
2017-12 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x64 (KB4054517)
2018-01 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x64 (KB4056892)
2018-01 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x64 (KB4058258)
2018-01 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x64 (KB4073290)
Et pour x86:
2017-10 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x86 (KB4043961)
2017-11 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x86 (KB4048955)
2017-11 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x86 (KB4051963)
2017-12 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x86 (KB4054517)
2018-01 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x86 (KB4056892)
2018-01 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x86 (KB4058258)
2018-01 Mise à jour cumulative pour Windows 10 Version 1709 pour les systèmes x86 (KB4073291)
La KB4087256 Mise à jour de la pile de maintenance est aussi installée.
Elle n'apparaît pas dans l'historique Windows Update, mais est listée dans Panneau de configuration > Programmes > Programmes et fonctionnalités > Mise à jour installées
Cette mise à jour s'est installée rapidement mais de façon étrange sur mon pc.
Après le redémarrage requis, la KB4074588 apparaissait toujours en attente de redémarrage dans l'historique de Windows Update alors que les deux autres mises à jour, KB890830 et KB408725 étaient installées.
De plus, je n'avais plus du tout de son.
J'ai redémarré le pc manuellement et la mise à jour KB4074588 s'est alors correctement installée.
J'ai eu besoin aussi d'un 2nd démarrage, pour faire disparaître le message dans Windows Update.
C'est d'ailleurs comme cela que j'ai découvert l'installation de la KB4087256.
Je suppose qu'il fallait un redémarrage pour la KB4074588 et un autre redémarrage pour la KB4087256, mais ce n'est qu'une supposition.
Cette mise à jour s'est bien passée ( sur 3 PC), un peu longue quand même, mais avec un seul redémarrage (je ne compte pas le démarrage de ce matin).
j'ai vérifié, la KB4087256 est bien dans le panneau de configuration (=> "désinstaller" dans WIndows update)
Merci chantal11.
Bonjour Chantal,
Merci pour le partage de ton hypothèse.
C'est aussi ce que j'avais supposé, vu le séquencement des mises à jour.
Mais c'est un loupé de la part de Microsoft, car le deuxième redémarrage aurait dû être automatique.
Lors des patchs mensuels avec une mise à jour de la pile de maintenance, d'habitude, les deux redémarrages s'enchaînent sans mon intervention.
Edit
mwonex a écrit :Cette mise à jour s'est bien passée ( sur 3 PC), un peu longue quand même, mais avec un seul redémarrage (je ne compte pas le démarrage de ce matin).
As-tu regardé l'historique de Windows Update après le premier redémarrage ?
En effet, j'ai constaté le phénomène dcrit plus haut sur deux autres pc ce matin.
Non, je n'avais aucune raison de le faire, mises à jour hier des 3 PC vers 20h, 1 seul redémarrage et fermeture des PC pour la nuit :hein:
Modifié en dernier par mwonex le mer. 14 févr. 2018 08:58, modifié 1 fois.
Hier soir, la mise à jour a commencé, et en cours d'installation, j'ai eu un écran bleu de la mort. Au redémarrage, la KB4074588 était signalée en échec !
Ce matin, le téléchargement a redémarré seul, et la MAJ s'est installée correctement et rapidement.
Capture MAJ.JPG (30.43 Kio) Vu 2682 fois
Le reste sans problèmes.
greg250
Message par greg250 »
Bonjour à tous, cette MAJ à été un poil un peu longue, mais j'ai le temps! Cependant, je n'ai pas comme vous cette KB4087256 d'installée ni dans Windows update ni dans le panneau de configuration des 2 pcs en ma possession, curieux!
