Mise à jour cumulative KB4093112 - Windows 10 - version 1709
La mise à jour cumulative KB4093112 est disponible via Windows Update pour Windows 10 - version 1709
Improvements and fixes
Provides support to control usage of Indirect Branch Prediction Barrier (IBPB) within some AMD processors (CPUs) for mitigating CVE-2017-5715, Spectre Variant 2 when switching from user context to kernel context (See AMD Architecture Guidelines around Indirect Branch Control and AMD Security Updates for more details). Follow instructions outlined in KB4073119 for Windows Client (IT Pro) guidance to enable usage of IBPB within some AMD processors (CPUs) for mitigating Spectre Variant 2 when switching from user context to kernel context.
Addresses an issue that causes an access violation in Internet Explorer when it runs on the Microsoft Application Virtualization platform.
Addresses an issue in Enterprise Mode related to redirects in Internet Explorer and Microsoft Edge.
Addresses an issue that generates an access violation on certain pages in Internet Explorer when it renders SVGs under a high load.
Addresses additional issues with updated time zone information.
Addresses an issue that might cause the App-V service to stop working on an RDS server that hosts many users.
Addresses an issue where user accounts are locked when applications are moved to a shared platform using App-V (e.g., XenApp 7.15+ with Windows Server 2016, where Kerberos authentication isn't available).
Addresses an issue with printing content generated by ActiveX in Internet Explorer.
Addresses an issue that causes document.execCommand("copy") to always return False in Internet Explorer.
Addresses an issue that, in some instances, prevents Internet Explorer from identifying custom controls.
Security updates to Internet Explorer, Microsoft Edge, Windows kpp platform and frameworks, Microsoft scripting engine, Windows graphics, Windows Server, Windows kernel, Windows datacenter networking, Windows wireless networking, Windows virtualization and Kernel, and Windows Hyper-V.
If you installed earlier updates, only the new fixes in this package will be downloaded and installed on your device.
https://support.microsoft.com/fr-fr/hel ... -kb4093112
KB4093112
Un redémarrage est requis.
La version Windows 10 passe à 16299.371
Note importante :
Consulter la fiche du support pour cette KB4093112, des problèmes connus y sont listés avec leurs solutions de contournement
Autres Mises à jour :
- Outil de suppression de logiciels malveillants Windows - avril 2018 (KB890830)
- Mise à jour de sécurité pour Adobe Flash Player sous Windows 10 Version 1709 - KB4093110
Re: Mise à jour cumulative KB4093112 - Windows 10 - version 1709
Merci Chantal pour cette information. :super:
Je guettais la mise à jour 1803 et finalement, on reçoit une cumulative.
J'ai installé celle-ci facilement sur 3 PC.
As-tu des infos sur la diffusion de la version 1803 ?
greg250
Message par greg250 »
Très très rapide, merci Chantal!
Fait sans difficultés !
Merci Chantal !
Merci chantal11, effectivement la mise à jour est nettement plus rapide que les précédentes, pari tenu donc.
Sauf que la Spring Creator Update est repoussée semble t il:
https://www.touslesdrivers.com/index.ph ... _code=7051
Plein d'autres infos hors de ce sujet ;)
La version 1803 serait effectivement repoussée et peut-être pour plusieurs semaines, nous verrons bien.
http://www.clubic.com/windows-os/window ... e-bug.html
Je profite de ce sujet pour poser une question technique sur les téléchargements dans le catalogue Microsoft Update.
Je choisis toujours le fichier complet, mais peut-on utiliser en toute sécurité le fichier delta, si le système est à jour avec la mise à jour cumulative précédente ?
Alors pour info .... il n'a jamais jamais été question de libérer la version 1803 pour le 10 avril, jour du Patch Tuesday, techniquement c'est impossible .... et le bug bloquant est connu depuis longtemps, l'équipe de développement en avait connaissance et y travaille.
Je le répète encore une fois, c'est Microsoft qui décide et sans aucun communiqué officiel, il est inutile d'avancer une date pour cette version 1803.
Nous sommes encore dans les tests dans les canaux Insider, nous avons reçu une première MaJ cumulative Insider et nous allons en recevoir une autre, peut-être même deux.
Donc patience ..... la version 1803 sera publiée publiquement quand elle sera prête.
Patriciag a écrit :Je choisis toujours le fichier complet, mais peut-on utiliser en toute sécurité le fichier delta, si le système est à jour avec la mise à jour cumulative précédente ?
J'ai déjà répondu à cette question.
La mise à jour Delta ne comporte que les modifications et correctifs apportées depuis la MaJ cumulative précédente, ce qui répond à ta question.
Merci de ta réponse.
Il me semblait qu'il était déconseillé d'utiliser le fichier Delta, j'ai donc dû me tromper. :?:
