Mise à jour cumulative KB4343909 - Windows 10 - version 1803
La mise à jour cumulative KB4343909 est disponible via Windows Update pour Windows 10 - version 1803
Improvements and fixes
Provides protections against a new speculative execution side-channel vulnerability known as L1 Terminal Fault (L1TF) that affects Intel® Core® processors and Intel® Xeon® processors (CVE-2018-3620 and CVE-2018-3646). Make sure previous OS protections against Spectre Variant 2 and Meltdown vulnerabilities are enabled using the registry settings outlined in the Windows Client and Windows Server guidance KB articles. (These registry settings are enabled by default for Windows Client OS editions, but disabled by default for Windows Server OS editions.)
Addresses an issue that causes high CPU usage that results in performance degradation on some systems with Family 15h and 16h AMD processors. This issue occurs after installing the June 2018 or July 2018 Windows updates from Microsoft and the AMD microcode updates that address Spectre Variant 2 (CVE-2017-5715 – Branch Target Injection).
Addresses an issue that prevents apps from receiving mesh updates after resuming. This issue occurs for apps that use Spatial Mapping mesh data and participate in the Sleep or Resume cycle.
Ensures that Internet Explorer and Microsoft Edge support the preload="none" tag.
Addresses an issue that prevents some applications running on HoloLens, such as Remote Assistance, from authenticating after upgrading from Windows 10, version 1607, to Windows 10, version 1803.
Addresses an issue that significantly reduced battery life after upgrading to Windows 10, version 1803.
Addresses an issue that causes Device Guard to block some ieframe.dll class IDs after installing the May 2018 Cumulative Update.
Addresses a vulnerability related to the Export-Modulemember() function when used with a wildcard (*) and a dot-sourcing script. After installing this update, existing modules on devices that have Device Guard enabled will intentionally fail. The exception error is “This module uses the dot-source operator while exporting functions using wildcard characters, and this is disallowed when the system is under application verification enforcement.” For more information, see https://portal.msrc.microsoft.com/en-US ... -2018-8200 and https://aka.ms/PSModuleFunctionExport.
Addresses an issue that was introduced in the July 2018 .NET Framework update. Applications that rely on COM components were failing to load or run correctly because of “access denied,” “class not registered,” or “internal failure occurred for unknown reasons” errors.
Security updates to Windows Server.
https://support.microsoft.com/fr-fr/hel ... -kb4343909
KB4343909
Un redémarrage est requis.
La version Windows 10 passe à 17134.228
Autres mises à jour :
- Mise à jour de sécurité pour Adobe Flash Player sous Windows 10 Version 1803 sur systèmes x64 (KB4343902)
- Outil de suppression de logiciels malveillants Windows x64 - août 2018 (KB890830)
greg250
Re: Mise à jour cumulative KB4343909 - Windows 10 - version 1803
Message par greg250 »
Voila qui est fait, j'avais la MAJ d'Adobe en attente d'installation! Merci Chantal!
Bizarrement, après Maj de Flas Player, le test de Adobe Flash Player dans Edge et IE me renvoie "Update now" au lieu de l'habituel
"You have the last version installed"
https://get.adobe.com/fr/flashplayer/about/
Mathusalem
Message par Mathusalem »
Bonjour ,
Encore une fois c' est tout bon .
Cdt ,
Math
