Windows 10 Insider Preview Build 17763 via Windows Update – canal Rapide
Windows 10 Insider Preview, une nouvelle Build 17763 pour PC est disponible pour les Insiders, via Windows Update – canal Rapide
https://blogs.windows.com/windowsexperi ... ild-17763/
Re: Windows 10 Insider Preview Build 17763 via Windows Update – canal Rapide
La Build 17763.1 est disponible en canal Lent
UPDATE 9/20: We have released Windows 10 Insider Preview Build 17763 to Windows Insiders in the Slow ring.
La Build 17763.1 est disponible en canal Release Preview
Cette Build 17763.1 est la version finale 1809 publique et commence à être déployée.
UPDATE 10/2: We have released the Windows 10 October 2018 Update (Build 17763) to the Release Preview ring. Today also marks general availability of the October 2018 Update which is rolling out in a phased and controlled rollout.
Mise à jour cumulative pour la Build 17763 vers 17763.104 pour les canaux Lent et Release Preview (KB4464455)
UPDATE 10/16: We have released the Windows 10 October 2018 Update Build 17763.104 (KB4464455) to Windows Insiders in the Slow and Release Preview rings. This Cumulative Update contains the following fixes:
We have fixed the issue where the incorrect details were being shown in Task Manager under the “Processes” tab.
We fixed an issue where in certain cases IME would not work in the first process of a Microsoft Edge user session.
We fixed an issue where in some cases applications would become unresponsive after resuming from Connected Standby.
We fixed several issues causing application compatibility problems with 3rd-party antivirus and virtualization products.
We fixed several issues with driver compatibility.
Nous avons résolu le problème d'affichage avec des détails incorrects dans le Gestionnaire des tâches sous l'onglet «Processus».
Nous avons corrigé un problème qui empêchait parfois l'IME de fonctionner dans le premier processus d'une session d'utilisateur Microsoft Edge.
Nous avons corrigé un problème où, dans certains cas, les applicationsne répondaient plus après avoir quitté l'état de Veille Connectée (Connected Standby).
Nous avons résolu plusieurs problèmes posant des problèmes de compatibilité des applications avec des produits antivirus et de virtualisation tiers.
Nous avons corrigé plusieurs problèmes de compatibilité avec des pilotes.
Mise à jour cumulative pour la Build 17763 vers 17763.107 pour les canaux Lent et Release Preview (KB4464455)
UPDATE 10/30: We have released the Windows 10 October 2018 Update Build 17763.107 (KB4464455) to Windows Insiders in the Slow and Release Preview rings. This Cumulative Update contains the same fixes as Build 17763.104 plus these two additional fixes:
We fixed the issue where dragging (extracting) files from a .zip file in File Explorer to a write-protected location you don’t get a “Do you want to replace these files” prompt and the copy action fails silently.
We fixed an issue causing roaming profiles to not work correctly.
MISE À JOUR 30/10 : Nous avons publié la mise à jour 17763.107 (KB4464455) de Windows 10 octobre 2018 pour Windows Insiders dans les anneaux Lent et Release Preview. Cette mise à jour cumulative contient les mêmes corrections que la version 17763.104 plus ces deux corrections supplémentaires :
Nous avons corrigé le problème de glisser (extraire) des fichiers d'un fichier.zip dans l'Explorateur de fichiers vers un emplacement protégé en écriture, vous n'obtenez pas d'invite "Voulez-vous remplacer ces fichiers" et l'action de copie échoue en silence.
Nous avons corrigé un problème qui empêchait le bon fonctionnement des profils d'itinérance.
Mise à jour cumulative KB4467708 pour la Build 17763 vers 17763.134 pour les canaux Lent et Release Preview
https://support.microsoft.com/en-us/hel ... -kb4467708
Mise à jour cumulative KB4469342 pour la Build 17763 vers 17763.165 pour le canal Release Preview
Mise à jour cumulative KB4469342 pour la Build 17763 vers 17763.167 pour le canal Release Preview
Addresses an issue in Microsoft Edge with using the drag-and-drop feature to upload folders from the Windows desktop to a file hosting service website, such as Microsoft OneDrive. In some scenarios, files contained in the folders fail to upload, with possibly no error reported on the web page to the user.
Addresses an issue that degrades Internet Explorer performance when you use roaming profiles or you don’t use the Microsoft Compatibility List.
Addresses updated time zone information for Fiji.
Addresses time zone changes for Moroccan daylight standard time.
Addresses time zone changes for Russian daylight standard time.
Addresses an issue that causes display settings to stop working when changing a multi-monitor configuration.
Addresses an issue that displays a black screen on some servers when waking a display from sleep.
Addresses an issue with long delays in taking a photo when using the Camera app in certain lighting conditions.
Addresses an issue that prevents live Hulu TV content from playing in Microsoft Edge; instead, a black screen appears.
Addresses an issue that stops Bluetooth® headsets from receiving audio input after several minutes of listening.
Addresses an issue that causes the Brightness slider preference to be reset to 50% when the device restarts.
Addresses an issue with the OEM manufacturing processes when running sysprep /generalize.
Addresses an issue with Microsoft Intune that causes devices to be incorrectly marked as not compliant because a firewall incorrectly returns a ‘Poor’ status. As a result, the affected devices will not receive conditional access compliance approval and may be blocked from access to corporate resources such as email.
Addresses a performance issue with vSwitch on network interface cards (NIC) that do not support Large Send Offload (LSO) and Checksum Offload (CSO).
Updates the Wi-Fi policy for service set identifier (SSID) filtering to avoid filtering out Wi-Fi Direct devices.
Addresses an issue that causes rasman.exe to stop responding.
Addresses an issue in which regedit.exe fails to add double null terminator to REG_MULTI_SZ values in the Windows registry. The missing terminator may prevent services and applications from reading REG_MULTI_SZ values that regedit.exe adds after installing the operating system.
Addresses an issue with RemoteApp visibility that may cause the main window to disappear until the user clicks the screen.
Addresses an issue that prevents some users from setting Win32 program defaults for certain app and file type combinations using the Open with… command or Settings > Apps > Default apps.
Addresses an issue that may cause mapped drives to fail to reconnect after starting and logging onto a Windows device.
