Mise à jour cumulative KB4458469 - Windows 10 - version 1803
La mise à jour cumulative KB4458469 est disponible via Windows Update pour Windows 10 - version 1803
Improvements and fixes
Addresses an issue that causes the prompt “You'll need a new app to open" to appear. This occurs when reloading a website on a non-standard port by pressing Enter .
Addresses an issue that causes downloads to fail because Mark of the Web (MOTW) isn't supported at the download location.
Addresses an issue that prevents the DefaultSearchProvider policy from working when the FirstRunPage policy is in use.
Addresses issue that causes the address bar to lose focus when a new tab is opened and the Allow web content on New Tab page policy is off.
Addresses an issue that prevents the Microsoft Edge Configure Password Manager policy from suppressing the Save password prompt when the policy is disabled.
Addresses an issue that causes downloads to WebDAV locations to fail.
Addresses an issue with the file previewer for .html, .mht, and email (MIME) attachments in Microsoft Outlook.
Addresses an issue that causes Internet Explorer security and certificate dialogs to display prompts in the background instead of the foreground in certain circumstances.
Addresses an issue that may cause the system to become unresponsive when applications call the EnableEUDC API.
Addresses an issue in multi-monitor scenarios that causes a spell checker context menu to appear on the wrong monitor. This issue occurs when the customer right-clicks a misspelled word in Internet Explorer.
Addresses an issue that occurs when entering Japanese characters in a remote desktop session (mstsc.exe).
Addresses an issue that occurs when using low-level mouse hooks with high integrity-level processes.
Addresses an issue that prevents custom keyboard layouts from working correctly.
Makes the visibility policy for the Settings Page available under User Configuration. The GPO is at the following path: User Configuration/Administrative Template/Control Panel/Settings Page Visibility
Addresses an issue that prevents some Bluetooth devices from pairing with Windows.
Addresses an issue in the Universal CRT that returns the expected output or a null character when calling _getch().
Addresses an issue in the Universal CRT that returns unexpected characters when calling the _findfirst() or _findnext() functions.
Addresses an issue in the Universal CRT that prevents some functions from accepting narrow input or producing proper output with certain ANSI Code Pages. This issue affects setargv.obj when using wildcard parsing and calls to get the current module name for debug windows. The issue also affects the following functions:
_chdir()
_exec()
_fullpath()
_loaddll
_popen()
_system()
_spawn() (and variants)
Addresses an issue with evaluating the compatibility status of the Windows ecosystem to help ensure application and device compatibility for all updates to Windows.
Addresses an issue with the diagnostic pipeline for devices enrolled in Windows Analytics when the CommercialID registry key, "HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\DataCollection" is present.
Addresses an issue that prevents the App-V client’s scheduled task from syncing if the Device Guard lockdown policy is enabled.
Addresses an issue that may cause the Local Security Authority Subsystem Service (LSASS) process to stop working when attempting to process a malformed security identifier (SID).
Addresses an issue that causes a delay in unlocking or signing in to a computer that was moved to a different network. For example, a delay occurs when moving from a corporate LAN or WLAN to a home LAN where domain controllers can't be reached.
Addresses an issue on some laptops that prevents sign-out from completing. The issue occurs when a customer signs out and immediately closes the laptop. As a result, when the laptop is reopened, the device must be restarted.
Addresses an issue that occurs when enabling BitLocker from a local administrator account.
Addresses an issue on devices with fingerprint sensors that were upgraded from Windows 10, version 1709. After the upgrade, users can't use the fingerprint sensor to log in.
Addresses an issue that causes some systems to take as much as 60 seconds longer to start. This occurs on systems that don't have a smart card reader installed.
Addresses an issue that prevents customers from logging in to a Windows 10S device with a PIN after upgrading to Windows 10, version 1803. Customers see the error “Your PIN is no longer available due to a change to the security settings on this device.”
Addresses an issue that causes a Direct Access connection to fail when the client authentication certificate is stored in the TPM device.
Addresses an issue that causes the system to log negative events for drivers that are valid and should be trusted. The issue occurs when running Windows Defender Application Control (Device Guard) in audit mode.
Addresses an issue that causes a third-party VPN provider's user interface to stop working after dynamically unloading Cryptui.dll.
Addresses an issue that causes logging on to a Remote Desktop Session Host Server to occasionally stop responding.
Addresses an issue that causes printing to an open or existing file to fail without displaying an error. This issue occurs when using Microsoft Print to PDF or XPS Document Writer.
Addresses an issue where a daily, repetitive task starts unexpectedly when the task is first created or starts when the task is updated.
Addresses an issue that prevents running subsequent actions when you create multiple actions in a task using Task Scheduler and the task is scheduled under the Stop the existing instance rule.
Addresses an issue with a task that has a repetition setting. The task fails to be scheduled and doesn't start after disabling and re-enabling the task. The Next Run Time in Task Scheduler displays the correct time, but the task doesn't start at that time.
Addresses an issue that prevents the debugging of minimized UWP applications.
Addresses an issue with Visual Studio UWP Deployments that displays the error "The operation could not be completed because an unexpected host ID was encountered".
Addresses an issue that ignores the MM_DONT_ZERO_ALLOCATION flag. This issue leads to degraded performance, and, occasionally, error 0x139 appears.
Addresses an issue that causes NTLTEST, DCLOCATOR, or joining an Active Directory and SAMBA domain to fail when using the NetBIOS domain name. The error is “An Active Directory domain Controller (AD DC) for the domain %domain% could not be contacted”.
Addresses an issue that occurs when using encrypted email. If the customer selects Cancel when first asked for a PIN, multiple PIN prompts appear before the prompt finally goes away.
Addresses an issue that prevents the Microsoft Help Viewer from rendering HTML content inside a Windows Help .chm file when the .chm file is stored on a network location.
Addresses an issue in which the lock screen shows a solid color instead of an image specified by a policy before a customer signs in for the first time.
Addresses an issue that causes Microsoft Edge to stop working when printing a PDF in a size 0 window.
Addresses an issue that causes Microsoft Edge to stop working and to close associated webpage tabs. This occurs when certain PDF documents have timing issues when loading.
Addresses an issue with a scheduled task that has an indefinite duration. The task starts immediately after it is created instead of starting at the time specified in the Triggers tab.
Addresses an issue where GetSystemTime() may sometimes return an invalid value after using SetSystemTime() immediately before.
Addresses an issue that occurs when using the “X509HintsNeeded” group policy to prepopulate the Username hint field. The Username hint field is unexpectedly empty when unlocking a machine after a successful logon. Username hint caching is expected to only work for lock and unlock scenarios and is not designed for logoff and logon scenarios.
Addresses an issue that fails to maintain the tile layout after upgrading to Windows 10, version 1803 from Windows 10, versions 1703 and 1607.
Addresses an issue that returns temporary values for the new Japanese Calendar Era.
Addresses an issue in which Background Apps settings the user configured are lost when the device restarts because of incorrect registry ACLs.
Addresses an issue that prevents Microsoft Centennial apps and some OS apps from displaying toast notifications.
Addresses an issue in which all Guest Virtual Machines running Unicast dual NIC NLB fail to respond to NLB requests after the Virtual Machines restart.
If you installed earlier updates, only the new fixes in this package will be downloaded and installed on your device.
https://support.microsoft.com/fr-fr/hel ... -kb4458469
KB4458469
Un redémarrage est requis.
La version Windows 10 passe à 17134.319
Re: Mise à jour cumulative KB4458469 - Windows 10 - version 1803
Téléchargement et installation assez rapide malgré la tartine de correctifs ;)
Hello,
Merci pour l'info.
Ce fut rapide aussi pour moi, après un petit temps d'attente sur "Préparation de l'installation".
Comme je le pressentais, je conserve mes bugs … intacts malgré la palanquée de correctifs annoncés. :mrgreen: :geek:
greg250
Message par greg250 »
Initialisation éclair et installation un peu longue pour moi. Chaque PC réagit différemment, le mien commence à avoir de la bouteille! Merci Chantal de nous tenir informés!Greg.
greg250 a écrit :Chaque PC réagit différemment,!
Effectivement, et sur le mien, pas de maj via Windows Update, donc j'ai utilisé le Catalogue Microsoft Update, et tout s'est bien passé.
Merci Chantal.
Moi itou, comme Tony37, mise à jour sollicitée sans réponse 3 fois, alors téléchargement pour Maj en mode autonome réussi.
Merci chantal11 pour cette info toujours pertinente.
greg250
J'ai oublié de signaler que je fait les MAJ en autonome avec le catalogue Windows par le lien que nous donne Chantal à chaque fois! Pas de patience à attendre les "officielles"update et j'avoue être à chaque fois satisfait! :super: Greg.
J@M3S
Message par J@M3S »
Moi j'attends que windows update me les proposes, rien ne presse.
Par contre je regarde souvent si je suis bien à jour à l'aide d'ici -> https://support.microsoft.com/fr-fr/help/4099479.
Pas pratique à retrouver ici car les infos de mise à jour cumulative sont mélangées avec les autres sujets dans discussions générales.
Il faudrait une page unique dédiée au mise à jour cumulative sur le site et idem pour insider (pour pas se mélanger les pinceaux)
Mathusalem
Message par Mathusalem »
Bonjour ,
Pour cette KB , je n' ai toujours aucune proposition venant de Windows Update........
Cdt ,
Math
Tu peux l'installer en mode autonome comme je le fais lorsque des maj tardent à arriver
https://www.catalog.update.microsoft.co ... =KB4458469
