Mise à jour cumulative KB4469342 - Windows 10 - version 1809
La mise à jour cumulative KB4469342 est disponible via Windows Update pour Windows 10 - version 1809
Improvements and fixes
Addresses an issue in Microsoft Edge with using the drag-and-drop feature to upload folders from the Windows desktop to a file hosting service website, such as Microsoft OneDrive. In some scenarios, files contained in the folders fail to upload, with possibly no error reported on the web page to the user.
Addresses an issue that degrades Internet Explorer performance when you use roaming profiles or you don't use the Microsoft Compatibility List.
Addresses updated time zone information for Fiji.
Addresses time zone changes for Moroccan daylight standard time.
Addresses time zone changes for Russian daylight standard time.
Addresses an issue that causes display settings to stop working when changing a multi-monitor configuration.
Addresses an issue that displays a black screen on some servers when waking a display from sleep.
Addresses an issue with long delays in taking a photo when using the Camera app in certain lighting conditions.
Addresses an issue that prevents live TV Hulu content from playing in Microsoft Edge; instead, a black screen appears.
Addresses an issue that stops Bluetooth® headsets from receiving audio input after several minutes of listening.
Addresses an issue that causes the Brightness slider preference to be reset to 50% when the device restarts.
Addresses an issue with the OEM manufacturing processes when running sysprep /generalize.
Addresses an issue with Microsoft Intune that causes devices to be incorrectly marked as not compliant because a firewall incorrectly returns a 'Poor' status. As a result, the affected devices will not receive conditional access compliance approval and may be blocked from access to corporate resources such as email.
Addresses a performance issue with vSwitch on network interface cards (NIC) that do not support Large Send Offload (LSO) and Checksum Offload (CSO).
Updates the Wi-Fi policy for service set identifier (SSID) filtering to avoid filtering out Wi-Fi Direct devices.
Addresses an issue that causes rasman.exe to stop responding.
Addresses an issue in which regedit.exe fails to add double null terminator to REG_MULTI_SZ values in the Windows registry. The missing terminator may prevent services and applications from reading REG_MULTI_SZ values that regedit.exe adds after installing the operating system.
Addresses an issue with RemoteApp visibility that may cause the main window to disappear until the user clicks the screen.
Addresses an issue that prevents some users from setting Win32 program defaults for certain app and file type combinations using the Open with… command or Settings > Apps > Default apps.
Addresses an issue that may cause mapped drives to fail to reconnect after starting and logging onto a Windows device.
https://support.microsoft.com/fr-fr/hel ... ld17763167
KB4469342
Un redémarrage est requis.
La version Windows 10 passe à 17763.168
Autres mises à jour :
- Mise à jour Cumulative pour.NET Framework 3.5 et 4.7.2 pour Windows 10 version 1809 et Windows Server 2019 (KB4469041)
- Mise à jour de sécurité pour Adobe Flash Player (KB4471331)
Re: Mise à jour cumulative KB4469342 - Windows 10 - version 1809
Merci chantal11, mise à jour en cours avec les NET Framework 3.5 et 4.7.2 (KB4469041)
Pour le PC de bureau minitour Acer, erreur 0x8024200d pour le Net Framework non répertorié ici:
https://support.microsoft.com/fr-ma/hel ... 0x800f0907
Je réessaierai bien sur après la mise à jour de Windows..
Si pas de résultat je verrai le lien:
https://forum.malekal.com/viewtopic.php ... 8&start=15
Commencer par vider le catalogue :bizar: (1Go de données)
Finalement sans rien faire, redémarrage en attente pour Net Framework :?
greg250
Message par greg250 »
Bonjour, pour ma part la MAJ est installée avec en premier échec de la kb 4469342 puis installation de cette mème kb! Donc c'est tout OK! Merci Chantal! Greg.
Bonjour, :coucou:
Fait de manière très fluide et rapidement. :super:
Merci pour l'info, Chantal.
micpal
Message par micpal »
Bonjour à tous
installation faite rapidement, mais idem la remarque de greg250 comme d'habitude lorsque plusieurs mise à jour s'installent en même temps échec à la première tentative avec le code 0x8024200d, puis lorsque les autres mise à jour sont installées, installation automatique dans la foulée.
Micpal a raison :
J@M3S
Message par J@M3S »
Toujours aussi logique chez Microsoft, d'un côté on me dit que cette MAJ ne s'installe pas alors qu'elle est en pleine installation dans WU :bizar:
:mdr: :mdr: de mieux en mieux
Je crois que pratiquement tout le monde a eu le droit à un échec suivi d'une réussite d'installation de cette KB.
L'essentiel, c'est bien que la MaJ soit au final installée .... :bubulle:
greg250
Cela ne m'arrive pas très souvent d'avoir ce petit désagrément (par Windows update s'entend) contrairement à la MAJ de façon autonome! Comme tu dis, l'important est que ce soit installé! Bonne journée, Greg.
Chino
Message par Chino »
Pour ma part installation de cette mise a jour KB 4469342 hier matin jeudi sans problème et de nouveau ce matin vendredi installation de cette KB 4469342 toujours sans problème , aucune des deux n'est signalée en échec , jamais deux sans trois :D :D :D
