Mise à jour cumulative KB4482887 - Windows 10 - version 1809
La mise à jour cumulative KB4482887 est disponible via Windows Update pour Windows 10 - version 1809
Improvements and fixes
Enables “Retpoline" for Windows on certain devices, which may improve performance of Spectre variant 2 mitigations (CVE-2017-5715). For more information, see our blog post, "Mitigating Spectre variant 2 with Retpoline on Windows".
Addresses an issue that may cause the Action Center to suddenly appear on the wrong side of the screen before appearing on the correct side.
Addresses an issue that may fail to save some inked content in a PDF in Microsoft Edge. This occurs if you erased some ink quickly after starting the inking session and then added more ink.
Addresses an issue that displays the media type as “Unknown” in the Server Manager for storage class memory (SCM) disks.
Addresses an issue with Remote Desktop access to Hyper-V Server 2019.
Addresses an issue that causes the republication BranchCache to take more space than it’s been assigned.
Addresses a performance issue when establishing a Remote Desktop connection from a web Remote Desktop client to Windows Server 2019.
Addresses a reliability issue that may cause the screen to remain black after resuming from Sleep if you close a laptop lid while disconnecting the laptop from a docking station.
Addresses an issue that causes the overwriting of file on a shared folder to fail because of an Access Denied error. This issue occurs when a filter driver is installed.
Enables peripheral role support for some Bluetooth radios.
Addresses an issue that may cause printing to PDF to fail during a Remote Desktop session. This issue occurs while attempting to save the file and redirect drives from the client system.
Addresses a reliability issue that may cause the main laptop screen to flash when resuming from Sleep. This issue occurs if the laptop is connected to a docking station that has an indirect display.
Addresses an issue that displays a black screen and causes a Remote Desktop session to stop responding when using certain VPN connections.
Updates time zone information for Chile.
Addresses an issue that fails to register USB cameras correctly for Windows Hello after the out of box experience (OOBE) setup.
Addresses an issue that prevents the Microsoft enhanced Point and Print compatibility driver from installing on Windows 7 clients.
Addresses an issue that causes Termservice to stop working when Remote Desktop is configured to use a hardware encoder for Advanced Video Coding (AVC).
Addresses an issue that locks a user account when you move applications to a shared platform using App-V.
Improves the reliability of the UE-VAppmonitor.
Addresses an issue that prevents App-V applications from starting and generates error 0xc0000225 in the log. Set the following DWORD to customize the maximum time for the driver to wait for a volume to be available:”HKLM\Software\Microsoft\AppV\MAV\Configuration\MaxAttachWaitTimeInMilliseconds”.
Addresses an issue with evaluating the compatibility status of the Windows ecosystem to help ensure application and device compatibility for all updates to Windows.
Addresses an issue that may prevent some applications from displaying the Help (F1) window correctly.
Addresses an issue that causes flickering of the desktop and taskbar on Windows Server 2019 Terminal Server after using the User Profile Disk setup.
Addresses an issue that fails to update a user hive when you publish an optional package in a Connection Group after the Connection Group was previously published.
Improves performance related to case-insensitive string comparison functions such as _stricmp() in the Universal C Runtime.
Addresses a compatibility issue with parsing and playback of certain MP4 content.
Addresses an issue that occurs with the Internet Explorer proxy setting and the out of box experience (OOBE) setup. The initial logon stops responding after Sysprep.
Addresses an issue in which the desktop lock screen image set by a Group Policy will not update if the image is older than or has the same name as the previous image.
Addresses an issue in which the desktop wallpaper image set by a Group Policy will not update if the image has the same name as the previous image.
Addresses an issue that causes the TabTip.exe touchscreen keyboard to stop working in certain conditions. This issue occurs when you use the keyboard in a kiosk scenario after replacing the default shell.
Addresses an issue that may cause the new Miracast connection banner to remain open after a connection is closed.
Addresses an issue that may cause virtual disks to go offline when upgrading a 2-node Storage Space Direct (S2D) cluster from Windows Server 2016 to Windows Server 2019.
Addresses an issue that fails to recognize the first character of the Japanese Era name as an abbreviation and may cause date parsing issues.
Addresses an issue that may prevent Internet Explorer from loading images that have a backslash (\) in their relative source path.
Addresses an issue that may cause applications that use a Microsoft Jet database with the Microsoft Access 95 file format to randomly stop working.
Addresses an issue in Windows Server 2019 that causes input and output timeouts when querying for SMART Data using Get-StorageReliabilityCounter().
https://support.microsoft.com/fr-fr/hel ... -kb4482887
KB4482887
Un redémarrage est requis.
La version Windows 10 passe à 17763.348
Symptom
After installing this update, Internet Explorer 11 may have authentication issues. This occurs when two or more people use the same user account for multiple, concurrent login sessions on the same Windows Server machine, including Remote Desktop Protocol (RDP) and Terminal Server logons. Symptoms reported by customers include, but may not be limited to:
Cache size and location show zero or empty.
Keyboard shortcuts may not work properly.
Webpages may intermittently fail to load or render correctly.
Issues with credential prompts.
Issues when downloading files.
Workaround
Create unique user accounts so that two people don’t share the same user account when logging on to a Windows Server machine. Additionally, disable multiple RDP sessions for a single user account for a specific Windows Server.
Microsoft is working on a resolution and will provide an update in an upcoming release.
Autres mises à jour :
- Mise à jour cumulative pour .NET Framework 3.5 pour et 4.7.2 pour Windows 10 Version 1809 pour les systèmes x64 (KB4486553)
greg250
Re: Mise à jour cumulative KB4482887 - Windows 10 - version 1809
Message par greg250 »
Merci Chantal! :super:
Merci Chantal, comme une lettre à la poste ............ Quoi que !!! (Peut-être même mieux !) :mdr: :lol: :mdr:
