Mise à jour cumulative KB4490481 - Windows 10 - version 1809
La mise à jour cumulative KB4490481 est disponible via Windows Update pour Windows 10 - version 1809
Improvements and fixes
Addresses an issue that occurs on machines that have multiple audio devices. Applications that provide advanced options for internal or external audio output devices may stop working unexpectedly. This issue occurs for users that select an audio output device different from the “Default Audio Device”. Examples of applications that may stop working include Windows Media Player, Realtek HD Audio Manager, and the Sound Blaster Control Panel.
Includes a fix for Game Mode that ensures the feature will no longer impact your experiences when using the industry’s top streaming and recording software.
Enables activation of insider builds of Windows 10 Enterprise for Virtual Desktops in Microsoft Azure. Microsoft Azure is the only tested and supported platform to host Windows 10 Enterprise for Virtual Desktops, which is a key part of Windows Virtual Desktop.
Addresses an issue that may cause the loss of Favorites or the Reading List in Microsoft Edge after updating the operating system.
Addresses an issue that causes Internet Explorer to randomly stop working while browsing.
Addresses an issue with scrolling ActiveX content in a window in Internet Explorer 11 during a user-triggered scroll operation.
Addresses an issue that prevents the operating system from loading new icon files if it encounters a badly formatted icon file.
Updates time zone information for São Tomé and Príncipe.
Updates time zone information for Kazakhstan.
Updates time zone information for Buenos Aires, Argentina.
Addresses an issue that prevents the “Turn off app notifications on the lock screen" policy from working. The path is "Computer Configuration\Administrative Templates\System\Logo".
Addresses an issue in which the graphics device interface (GDI) DeleteObject() may cause the calling process to stop working when both of the following conditions are true:
The calling process is a WOW64 process that handles memory addresses larger than 2 GB.
The DeleteObject() is called with a device context that is compatible with a printer device context.
Addresses an issue that prevents applications and callers from connecting to destination endpoints when they use network interfaces that don’t have a default gateway. This issue affects the following:
Internet access fails on devices with DSL modems and PPPoE dial-up Internet connections (commonly used with DSL modems).
Modern and Microsoft Store apps behave as if there is no Internet access on devices with DSL modems.
Web browsers and Win32 applications that are connected to the Internet are not affected by this issue.
Addresses an issue that causes Windows to reuse an expired Dynamic Host Configuration Protocol (DHCP) lease if the lease expired while the OS was shutdown.
Addresses an issue that causes the RemoteApp window to come to the foreground and to always remain active after closing a window.
Addresses an issue that prevents the authentication credentials dialog from appearing when an enterprise web server attempts to connect to the Internet.
Addresses an issue that may prevent Modern apps icons from appearing in the Taskbar and the Task Switcher during a RemoteApps connection.
Addresses an issue that causes certain Microsoft Store applications to fail to launch or stop working, including WeChat on the Universal Windows Platform (UWP).
Addresses an issue that fails to register USB cameras correctly for Windows Hello after the out of box experience (OOBE) setup.
Adds a new Group Policy setting called “Enable Windows to soft-disconnect a computer from a network”. This determines how Windows will disconnect a computer from a network when it determines that the computer should no longer be connected to the network.
If enabled, Windows will soft-disconnect (disconnection is not immediate or abrupt) a computer from a network.
If disabled, Windows disconnects a computer from a network immediately.
If not configured, the default behavior is soft-disconnect. For more information about soft-disconnect, see Understanding and configuring Windows Connection Manager.
Path: Computer Configuration\Policies\Administrative Templates\Network\Windows Connection Manager
Addresses an issue that prevents a virtual smart card from starting when running in conjunction with Citrix 7.15.2000 Workstation VDA software.
Addresses an issue that prevents users from configuring their screens for high-dynamic-range (HDR) video playback.
Addresses an issue with the Windows lock screen that prevents users from unlocking a device after multiple smart card users have used the same device. This issue occurs when you attempt to use a workstation that another user has locked.
Addresses a memory leak that occurs when a system processes logon sessions.
Addresses an issue that causes Always-On VPN exclusion routes to only work for link-local exclusions.
Addresses an issue that causes certificate renewal to fail when using CERT_RENEWAL_PROP_ID with the ICertPropertyRenewal interface.
Addresses an issue that mutes the sound of single-use applications, typically used in kiosk scenarios, after the system resumes from Sleep.
Addresses an issue to meet GB18030 certificate requirements.
Addresses an issue that slows server performance or causes the server to stop responding because of numerous Windows firewall rules. To enable this solution, use regedit to modify the following and set it to 1:
Type: “DeleteUserAppContainersOnLogoff” (DWORD)
Path: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy
Addresses an issue that prevents the decryption of data using Windows 10, version 1703 or later versions of Windows. This issue occurs if you encrypted that data using DPAPI-NG or a group-protected PFX file on Windows 10, version 1607, Windows Server 2016, or earlier versions of Windows.
Addresses an issue with evaluating the compatibility status of the Windows ecosystem to help ensure application and device compatibility for all updates to Windows.
Addresses minor issues with unknown options (unknown OPT) in the Extension Mechanisms for DNS (EDNS) for the Windows DNS Server role.
Addresses a timing issue that may result in an access violation when configuring Switch Embedded Teaming (SET).
Addresses an issue with the Remove-StoragePool PowerShell cmdlet that fails to clear pool metadata on NVDIMM physical disks.
Enables X2APIC support for AMD platforms to support 256 or more logical processors on Windows Server 2019.
Addresses an issue that prevents date parsers from converting future and past dates (Gregorian and Japanese) in compound documents (formerly OLE) to a relevant Japanese Era date. For more information, see KB4469068.
Addresses an issue that prevents users from enabling gan-nen support for the Japanese Era. For more information, see KB4469068.
https://support.microsoft.com/fr-fr/hel ... -kb4490481
KB4490481
Un redémarrage est requis.
La version Windows 10 passe à 17763.404
Symptom
After installing this update, Internet Explorer 11 and other applications that use WININET.DLL may have authentication issues. This occurs when two or more people use the same user account for multiple, concurrent login sessions on the same Windows Server machine, including Remote Desktop Protocol (RDP) and Terminal Server logons. Symptoms reported by customers include, but may not be limited to:
Cache size and location show zero or empty.
Keyboard shortcuts may not work properly.
Webpages may intermittently fail to load or render correctly.
Issues with credential prompts.
Issues when downloading files.
Workaround
Create unique user accounts so that two people don’t share the same user account when logging on to a Windows Server machine. Additionally, disable multiple RDP sessions for a single user account for a specific Windows Server.
Microsoft is working on a resolution and will provide an update in an upcoming release.
Symptom
After installing this update, MSXML6 causes applications to stop responding if an exception was thrown during node operations, such as appendChild(), insertBefore(), and moveNode().
The Group Policy editor may stop responding when editing a Group Policy Object (GPO) that contains Group Policy Preferences (GPP) for Internet Explorer 10 settings.
Workaround
Symptom
After installing this update, Custom URI Schemes for Application Protocol handlers may not start the corresponding application for local intranet and trusted sites on Internet Explorer.
Workaround
Right-click the URL link to open it in a new window or tab.
Or
Enable Protected Mode in Internet Explorer for local intranet and trusted sites.
Go to Tools > Internet options > Security.
Within Select a zone to view or change security settings, select Local intranet and then select Enable Protected Mode.
Select Trusted sites and then select Enable Protected Mode.
Select OK.
You must restart the browser after making these changes.
Symptom
After installing this update, there may be issues using the Preboot Execution Environment (PXE) to start a device from a Windows Deployment Services (WDS) server configured to use Variable Window Extension. This may cause the connection to the WDS server to terminate prematurely while downloading the image. This issue does not affect clients or devices that are not using Variable Window Extension.
Workaround
To mitigate the issue, disable the Variable Window Extension on WDS server using one of the following options:
Option 1:
Open an Administrator Command prompt and type the following:
Wdsutil /Set-TransportServer /EnableTftpVariableWindowExtension:No
Option 2:
Use the Windows Deployment Services UI.
Open Windows Deployment Services from Windows Administrative Tools.
Expand Servers and right-click a WDS server.
Open its properties and clear the Enable Variable Window Extension box on the TFTP tab.
Option 3:
Set the following registry value to 0:
“HKLM\System\CurrentControlSet\Services\WDSServer\Providers\WDSTFTP\EnableVariableWindowExtension”.
Restart the WDSServer service after disabling the Variable Window Extension.
Symptom
If you enable per font end-user-defined characters (EUDC), the system will stop working and a blue screen will appear at startup. This is not a common setting in non-Asian regions.
Workaround
To avoid this issue, don’t enable per font EUDC. As an alternative, you can edit the registry to mitigate this issue; for more information, see KB4496149.
Chino
Re: Mise à jour cumulative KB4490481 - Windows 10 - version 1809
Message par Chino »
Bonjour a toutes et tous
Cette mise a jour c'est installée deux fois , une fois le 02/04 a environ 20 H et une fois le 03/04 a 7 H , et a chaque fois sans soucis , entre les deux installations est qu'il y a eu un correctif de Microsoft ????
Merci !
RAS ! :D
greg250
Message par greg250 »
Bonjour et merci Chantal! :super:
