Mise à jour cumulative KB4493509 - Windows 10 - version 1809
La mise à jour cumulative KB4493509 est disponible via Windows Update pour Windows 10 - version 1809
Improvements and fixes
Addresses an issue that occurs when you enable per font end-user-defined characters (EUDC). The system will stop working and a blue screen will appear at startup. This is not a common setting in non-Asian regions.
Addresses an issue that may cause applications that use MSXML6 to stop responding if an exception was thrown during node operations.
Addresses an issue that causes the Group Policy editor to stop responding when editing a Group Policy Object (GPO) that contains Group Policy Preferences (GPP) for Internet Explorer 10 Internet settings.
Addresses an issue that may cause authentication issues for Internet Explorer 11 and other applications that use WININET.DLL. This occurs when two or more people use the same user account for multiple, concurrent login sessions on the same Windows Server machine, including Remote Desktop Protocol (RDP) and Terminal Server logons.
Security updates to Windows Datacenter Networking, Windows Server, the Microsoft JET Database Engine, Windows Kernel, Windows Input and Composition, Microsoft Scripting Engine, Windows App Platform and Frameworks, Windows Storage and Filesystems, Microsoft Graphics Component, Windows Virtualization, Windows MSXML, Windows SQL components, and Microsoft Edge.
https://support.microsoft.com/fr-fr/hel ... -kb4493509
KB4493509
Un redémarrage est requis.
La version Windows 10 passe à 7763.437
Symptom
After installing this update, Custom URI Schemes for Application Protocol handlers may not start the corresponding application for local intranet and trusted sites on Internet Explorer.
Workaround
Right-click the URL link to open it in a new window or tab.
Or
Enable Protected Mode in Internet Explorer for local intranet and trusted sites.
Go to Tools > Internet options > Security.
Within Select a zone to view or change security settings, select Local intranet and then select Enable Protected Mode.
Select Trusted sites and then select Enable Protected Mode.
Select OK.
You must restart the browser after making these changes.
Microsoft is working on a resolution and will provide an update in an upcoming release.
Symptom
After installing this update, there may be issues using the Preboot Execution Environment (PXE) to start a device from a Windows Deployment Services (WDS) server configured to use Variable Window Extension. This may cause the connection to the WDS server to terminate prematurely while downloading the image. This issue does not affect clients or devices that are not using Variable Window Extension.
Workaround
To mitigate the issue, disable the Variable Window Extension on WDS server using one of the following options:
Option 1:
Open an Administrator Command prompt and type the following:
Wdsutil /Set-TransportServer /EnableTftpVariableWindowExtension:No
Option 2:
Use the Windows Deployment Services UI.
Open Windows Deployment Services from Windows Administrative Tools.
Expand Servers and right-click a WDS server.
Open its properties and clear the Enable Variable Window Extension box on the TFTP tab.
Option 3:
Set the following registry value to 0:
“HKLM\System\CurrentControlSet\Services\WDSServer\Providers\WDSTFTP\EnableVariableWindowExtension”.
Restart the WDSServer service after disabling the Variable Window Extension.
Autres mises à jour :
- Outil de suppression de logiciels malveillants Windows - Avril 2019 (KB890830)
- Mise à jour de sécurité pour Adobe Flash Player sous Windows 10 Version 1809 sur systèmes x64 ((KB4493478))
greg250
Re: Mise à jour cumulative KB4493509 - Windows 10 - version 1809
Message par greg250 »
Bonjour et merci Chantal. Cette MAJ était plus longue que d'habitude, mais tout c'est bien passé!Greg.
Bonjour Chantal, c'est OK, merci!
Bonjour Chantal,
Effectivement, un peu plus long, mais cool !
Mathusalem
Message par Mathusalem »
Bonjour à tous ,
MàJ effectuée sans problème . Merci ,
Math
micpal
Message par micpal »
Bonjour à tous
Mise à jour effectuée sans problème
