Mise à jour cumulative KB4494441 - Windows 10 - version 1809
La mise à jour cumulative KB4494441 est disponible via Windows Update pour Windows 10 - version 1809
Improvements and fixes
Enables “Retpoline” by default if Spectre Variant 2 (CVE-2017-5715) is enabled. Make sure previous OS protections against the Spectre Variant 2 vulnerability are enabled using the registry settings described in the Windows Client and Windows Server articles. (These registry settings are enabled by default for Windows Client OS editions, but disabled by default for Windows Server OS editions). For more information about “Retpoline”, see Mitigating Spectre variant 2 with Retpoline on Windows.
Provides protections against a new subclass of speculative execution side-channel vulnerabilities, known as Microarchitectural Data Sampling, for 64-Bit (x64) versions of Windows (CVE-2018-11091, CVE-2018-12126, CVE-2018-12127, CVE-2018-12130). Use the registry settings as described in the Windows Client and Windows Server articles. (These registry settings are enabled by default for Windows Client OS editions and Windows Server OS editions).
Adds "uk.gov" into the HTTP Strict Transport Security Top Level Domains (HSTS TLD) for Internet Explorer and Microsoft Edge.
Addresses an issue that may cause “Error 1309” while installing or uninstalling certain types of .msi and .msp files on a virtual drive.
Addresses an issue that prevents the Microsoft Visual Studio Simulator from starting.
Addresses an issue that may cause zone transfers between primary and secondary DNS servers over the Transmission Control Protocol (TCP) to fail.
Addresses an issue that causes Simple Network Management Protocol (SNMP) Management Information Base registration to fail when the Windows Management Instrumentation (WMI) provider uses the Windows tool SMI2SMIR.exe.
Addresses an issue that may cause the text, layout, or cell size to become narrower or wider than expected in Microsoft Excel when using the MS UI Gothic or MS PGothic fonts.
Security updates to Microsoft Edge, Internet Explorer, Microsoft Scripting Engine, Windows App Platform and Frameworks, Windows Graphics, Windows Storage and Filesystems, Windows Cryptography, the Microsoft JET Database Engine, Windows Kernel, Windows Virtualization, and Windows Server .
https://support.microsoft.com/fr-fr/hel ... -kb4494441
KB4494441
Un redémarrage est requis.
La version Windows 10 passe à 17763.503
Known issues in this update
Symptom
After installing this update, there may be issues using the Preboot Execution Environment (PXE) to start a device from a Windows Deployment Services (WDS) server configured to use Variable Window Extension. This may cause the connection to the WDS server to terminate prematurely while downloading the image. This issue does not affect clients or devices that are not using Variable Window Extension.
Workaround
To mitigate the issue, disable the Variable Window Extension on WDS server using one of the following options:
Option 1:
Open an Administrator Command prompt and type the following:
Wdsutil /Set-TransportServer /EnableTftpVariableWindowExtension:No
Option 2:
Use the Windows Deployment Services UI.
Open Windows Deployment Services from Windows Administrative Tools.
Expand Servers and right-click a WDS server.
Open its properties and clear the Enable Variable Window Extension box on the TFTP tab.
Option 3:
Set the following registry value to 0:
“HKLM\System\CurrentControlSet\Services\WDSServer\Providers\WDSTFTP\EnableVariableWindowExtension”.
Restart the WDSServer service after disabling the Variable Window Extension.
Microsoft is working on a resolution and will provide an update in an upcoming release.
Symptom
Certain operations, such as rename, that you perform on files or folders that are on a Cluster Shared Volume (CSV) may fail with the error, “STATUS_BAD_IMPERSONATION_LEVEL (0xC00000A5)”. This occurs when you perform the operation on a CSV owner node from a process that doesn’t have administrator privilege.
Workaround
Do one of the following:
Perform the operation from a process that has administrator privilege.
Perform the operation from a node that doesn’t have CSV ownership.
Symptom
When attempting to print from Microsoft Edge or other Universal Windows Platform (UWP) applications, you may receive the error, "Your printer has experienced an unexpected configuration problem. 0x80070007e."
Workaround
You can use another browser, such as Internet Explorer to print your documents.
Symptom
After installing KB4493509, devices with some Asian language packs installed may receive the error, "0x800f0982 - PSFX_E_MATCHING_COMPONENT_NOT_FOUND."
Workaround
Uninstall and reinstall any recently added language packs. For instructions, see Manage the input and display language settings in Windows 10.
Select Check for Updates and install the April 2019 Cumulative Update. For instructions, see Update Windows 10.
Note If reinstalling the language pack does not mitigate the issue, reset your PC as follows:
Go to the Settings app > Recovery.
Select Get Started under the Reset this PC recovery option.
Select Keep my Files.
greg250
Re: Mise à jour cumulative KB4494441 - Windows 10 - version 1809
Message par greg250 »
Merci Chantal :super:
Mathusalem
Message par Mathusalem »
Bonjour ,
Mise à jour installée sans problème . Merci .
Cdt ,
Math
roballary
Message par roballary »
Installation faite automatiquement ce matin.
Fait ce matin. RAS ! :super:
Ce matin j'ai dit que c'était fait, mais à l'instant, je viens de lancer winver, et la version du système est affichée 17763.475 ?
Sur l'historique des mises à jour, tout est noté comme réussi !
Cela a été signalé sur plusieurs cas.
Il faut installer cette KB une deuxième fois depuis le Catalogue Microsoft Update
KB4494441
OK, merci Chantal :super:
greg250
Re
Merci àTony37 qui m'a mis la puce à l'oreille car, j'ai eu le mème problème et qui est résolu grâce à Chantal! Encore merci à vous deux!Greg.
Même chose que Tony37:
J'ai relancé la mise à jour malgré la réussite de celle-ci (je mets à jour à chaque fois), et redémarré 2 fois:
Capture-WS-update 16052019.PNG (41.8 Kio) Consulté 3369 fois
On peut voir que la KB4494441 n'y est pas :mrgreen:
