Mise à jour cumulative KB4517211 - Windows 10 - version 1903 - 19H1 - 18362.387
La mise à jour cumulative KB4517211 est disponible via Windows Update pour Windows 10 - version 1903 - 19H1
Highlights
Updates an issue that causes vertical fonts to be larger when printing to a PostScript printer.
Updates an issue that may cause you to disconnect from a virtual private network (VPN) on cellular networks.
Updates an issue that may cause audio playback and recording to fail when connecting to a remote virtual machine.
Updates an issue that may prevent older systems from upgrading to the latest operating systems because a display driver error on older versions.
Updates an issue that may cause the screen color to turn white on laptops that have built-in, high-dynamic-range (HDR) screens.
Updates an issue that causes audio in certain games to be quieter or different than expected.
Improvements and fixes
Addresses an issue that causes vertical fonts to be larger when printing to a PostScript printer.
Addresses an issue that causes printing from 32-bit applications to fail with an “Access is denied” error when you select Run as different user for the application.
Addresses an issue that may give write access to a removable USB disk when a user switches from a privileged user to an unprivileged user.
Addresses an issue that causes the lsass.exe service to stop working, which causes the system to shut down. This occurs when migrating Data Protection API (DPAPI) credentials using dpapimig.exe with the -domain option.
Addresses an issue that gives a Windows Hello for Business user two certificates for authentication during certificate renewal instead of one certificate.
Addresses an issue that prevents a web browser from connecting securely to Windows Server. This occurs when using a client authentication certificate, such as a SHA512-based certificate, and the web browser does not support a signature algorithm that matches the certificate.
Addresses an issue that may cause authentication to fail for certificate-based authentication when the certificate authentication includes a cname as part of the pre-authentication request.
Addresses an issue that prevents a Microsoft App-V application from opening and displays a network failure error. This issue occurs under certain circumstances, such as when a system's battery is low or there is an unexpected power failure.
Addresses an issue that causes a query request of the Win32_LogonSession class for the StartTime to display the value of the epoch (for example, 1-1-1601 1:00:00) instead of the actual logon time. This occurs when a user who isn’t an administrator creates the query request.
Addresses an issue that causes File Explorer to show a regular file icon for files marked with FILE_ATTRIBUTE_OFFLINE instead of the expected placeholder icon.
Addresses an issue with intermittent virtual private network (VPN) disconnections on cellular networks.
Addresses an issue that may cause audio playback and recording to fail when connecting to a remote virtual machine.
Addresses an issue with MSCTF.dll that causes an application to stop working.
Addresses an issue with the input and display of special characters that occurs when an app uses imm32.dll.
Addresses an issue with resizing Windows Presentation Foundation (WPF) applications; they may not respond to being resized using the mouse until you release the mouse button.
Addresses an issue that may prevent older systems from upgrading to the latest operating systems because of an error in the display driver of older versions.
Addresses an issue that may cause the screen color to turn white on laptops that have built-in, high-dynamic-range (HDR) screens.
Addresses an issue with converting an application from 32-bit to 64-bit architecture.
Addresses an issue that prevents you from running the Active Directory Diagnostics Data Collector Set from the Performance Monitor for Domain Controllers. This causes the Data Collector Set name to appear empty. Running the Active Directory Diagnostics Data Collector Set returns the error, “The system cannot find the file specified.” Event ID 1023 is logged with the source as Perflib and the following messages:
“Windows cannot load the extensible counter DLL “C:\Windows\system32\ntdsperf.dll.”
“The specified module could not be found.”
Addresses an issue that causes audio in certain games to be quieter or different than expected.
Addresses an issue that prevents Microsoft App-V from handling a parameter of the CreateProcess API properly, which prevents the virtual process from opening.
Addresses an issue in which the maximum central processing unit (CPU) performance is not enabled when you select the High Performance power plan.
Provides a way to configure the read buffer size. This allows you to address an issue with slow upload times when uploading a file to a Universal Naming Convention (UNC) share using the Internet Information Services (IIS) Web Distributed Authoring and Versioning (WebDAV) feature.
Addresses an issue that causes a device to stop working when opening files from a network drive that has client-side caching enabled. This issue may occur when the device has certain third-party antivirus products installed and the drive is backed by a server that is not a Microsoft Server Message Block (SMB) server. The error code is, “0x27 RDR_FILE_SYSTEM.”
Facilitates the configuration of devices that are managed by mobile device management (MDM) settings, which are created by ADMX ingestion. You can update a previously ingested ADMX file with a newer version, and you are not required to delete the previous ADMX file. This solution applies to all applications that use ADMX ingestion.
https://support.microsoft.com/fr-fr/hel ... -kb4517211
KB4517211
Un redémarrage est requis.
La version Windows 10 passe à 18362.387
Re: Mise à jour cumulative KB4517211 - Windows 10 - version 1903 - 19H1 - 18362.387
Curieusement cette KB4517211 est proposée chez moi en Mise à Jour facultative ????
Chez vous aussi ?
Pourquoi facultative ?
Sur mon lenovo, je n'ai pas cette indication, la maj se fait en ce moment.
En revanche sur mon HP, impossible d'accéder à l'update. Les petits points en haut avancent, avancent, moulinent, mais écran interminablement noir.
J'ai redémarré 2 fois, j'ai arrêté le modem, mais rien n'y fait.
Etrange !
Capture update.JPG (30.04 Kio) Vu 2354 fois
Pour le moment je n'ai que:
2019-09 Mise à jour cumulative pour .NET Framework 3.5 pour et 4.8 pour Windows 10 Version 1903 pour les systèmes x64 (KB4522738)
redémarrage requis
Tant sur Asus que sur le vieil Acer :hein:
La mise à jour cumulative n'est proposée qu'après ce redémarrage:
2019-09 Mise à jour cumulative pour Windows 10 Version 1903 pour les systèmes x64 (KB4517211)Préparation - 100%
Et elle est rapide...
J'ai finalement opté pour le Catalogue Microsoft Update, et tout s'est bien passé. La maj s'est bien déroulée, assez rapidement, et j'ai de nouveau accès à l'update dans paramètres.
mwonex a écrit : Pour le moment je n'ai que:
Bonjour mwonex,
Après installation de la KB4517211, j'ai relancé une recherche et j'ai aussi cette KB4522738, qui s'est installée aussi rapidement.
Bonjour Tony37,
Merci de cette info, sur un seul des 3 appareils, la mise à jour n'a pas nécessité de redémarrage après le Net Framework.
Tout est OK pour moi.
greg250
Message par greg250 »
Bonjour à tous, la MAJ Windows faite par le catalogue à été très loonnnnngue à l'inverse du Net Framework, mais pas de problème! J'ai lu dans la semaine que cette mise à jour était effectivement facultative! Curieux quand mème. Bon Week à tous et toutes, Greg.
Mathusalem
Message par Mathusalem »
Bonjour à tous ,
Mise à jour effectuée sans aucune anicroche . Merci ,
Cdt ,
Math
J@M3S
Message par J@M3S »
chantal11 a écrit :Curieusement cette KB4517211 est proposée chez moi en Mise à Jour facultative ????
J'ai eu de mon côté la même chose que chantal11 par windows update avec auparavant 2019-09 Mise à jour cumulative pour .NET Framework 3.5 pour et 4.8 pour Windows 10 Version 1903 pour les systèmes x64 (KB4522738).
