Mise à jour cumulative KB4522355 - Windows 10 - version 1903 - 19H1 - 18362.449
La mise à jour cumulative KB4522355 est disponible via Windows Update pour Windows 10 - version 1903 - 19H1
Highlights
Updates an issue that prevents Microsoft Narrator from working in certain touch mode scenarios.
Updates an issue that starts assistive technology (AT) (such as Microsoft Narrator, Magnifier, or NVDA) after signing in when you've configured it to start before signing in.
Updates an issue that causes Magnifier to stop working in certain scenarios, and you have to restart it manually.
Updates an issue that causes Microsoft Narrator to stop working in the middle of a session in certain scenarios.
Updates an issue that might prevent a scroll bar from being selected.
Updates an issue that allows a device to go to Sleep (S3) even if you configure the device to never sleep.
Updates an issue that prevents you from shrinking a window in some cases.
Updates an issue that prevents you from connecting to a virtual private network (VPN).
Updates an issue that causes screen flickering or is slow to display the screen when you show application thumbnails on a monitor that has high dots per inch (DPI).
Updates an issue that causes the tile for the Photos app to appear larger than expected in the Start menu under certain conditions.
Updates an issue that causes the system to stop responding at the sign-in screen.
Updates an issue that might cause a black screen to appear the first time you sign in after installing a feature or quality update.
Updates an issue that causes the Start menu, the Cortana Search bar, Tray icons, or Microsoft Edge to stop responding in certain scenarios after installing a monthly update.
Improvements and fixes
This security update includes quality improvements. Key changes include:
Addresses an issue with the behavior of the Origin HTTP header when you use Internet Explorer to make cross-origin resource sharing (CORS) requests to redirect resources in internal subnets.
Addresses an issue that prevents Microsoft Narrator from working in certain touch mode scenarios.
Addresses an issue with syncing settings from the Accounts page when the "Continue experiences on this device" Group Policy is disabled.
Addresses an issue that starts assistive technology (AT) (such as Microsoft Narrator, Magnifier, or NVDA) after signing in when the Ease of Access Center setting requires AT to start before signing in.
Addresses an error message that appears when you open an app after enabling NT Virtual DOS Machine (NTVDM) and the legacy console mode. The error message is, "OACClearArry: Cannot connect to Trace32 OLE Automation server. Error code: -2147483645."
Addresses an issue that causes Magnifier to stop working in certain scenarios, and the user must restart it manually.
Updates time zone information for Norfolk Island, Australia.
Updates time zone information for the Fiji Islands.
Addresses an issue that causes Microsoft Narrator to stop working in the middle of a user session in certain scenarios.
Addresses an issue that fails to set the default Command Prompt window color when you use the color command without a parameter.
Addresses an issue that causes the Microsoft Windows Search Indexer (searchindexer.exe) to add or repair required access control lists (ACLs) without checking if ACLs exist.
Addresses an issue in which controls in Win32 applications intermittently fail to render correctly when started from a logoff script using the "Run shutdown scripts visible" policy.
Addresses an issue in which installing many fonts in the system causes applications to stop responding.
Addresses an issue with high CPU usage in Desktop Window Manager (dwm.exe) when you disconnect from a Remote Desktop Protocol (RDP) session.
Addresses an issue that might prevent a scroll bar from being selected when an ActiveX control implements the CScrollView class. This occurs if you move the Internet Explorer window, which then moves the scroll bar to the left.
Addresses an issue that allows the system to go to Sleep (S3) after two minutes of inactivity even if you configure the sleep timer to never sleep.
Addresses an issue that prevents users from reducing the size of a window in some cases.
Addresses an issue that causes Microsoft SharePoint file names to appear incorrectly in the Quick access and Recent items folders.
Addresses an issue that prevents you from establishing virtual private network (VPN) connections.
Addresses an issue that causes screen flickering or is slow to display the screen when you show application thumbnails on high dots per inch (DPI) monitors.
Addresses an issue with incorrect permissions on a user’s class registry keys that prevents users from opening files, links, and applications.
Addresses an issue that causes the tile for the Photos app to appear larger than expected in the Start menu under certain conditions.
Addresses an issue that causes the system to stop responding at the sign-in screen.
Addresses an issue with the multifactor unlock policy of Windows Hello for Business, which fails to show the default sign-in option on Windows 10 devices.
Addresses an issue that causes Windows Search to close unexpectedly when a Group Policy applies sub-groups to the Start menu layout.
Addresses an issue that prevents you from retrieving the correct Dynamic Host Configuration Protocol (DHCP) information by setting the DHCP LeaseTerminatesTime and LeaseObatinedTime parameters to the correct format.
Addresses an issue with diagnostic data processing when a device has the Diagnostic data setting enabled and set to Basic.
Addresses an issue that prevents Internet Explorer from opening when Microsoft User Experience Virtualization (UE-V) is being used to roam many favorites.
Addresses an issue that improves the reliability of the UE-V AppMonitor.
Addresses an issue in which Microsoft AppLocker might prevent an application from running or log a false positive error instead of running the application.
Addresses an issue that prevents netdom.exe from displaying the new ticket-granting ticket (TGT) delegation bit for the display or query mode.
Addresses an issue that might cause Direct Access servers to use a large amount of non-paged pool memory (pooltag: NDnd).
Addresses an issue with AppContainer firewall rules that leak when guest users or mandatory user profile users sign in and sign out from Windows Server.
Addresses an issue that prevents the Unified Write Filter (UWF) servicing mode of Windows Update from working with the Windows Server Update Services (WSUS) server.
Addresses an issue that causes all Transmission Control Protocol (TCP) dynamic ports to be consumed. As a result, network communications will fail for any protocol or operation using dynamic ports.
Addresses an issue with applications and scripts that call the NetQueryDisplayInformation API or the WinNT provider equivalent. They might fail to return results after the first page of data, often 50 or 100 entries. When requesting additional pages, you might receive the error, “1359: an internal error occurred.”
Addresses an issue that disrupts window ordering after tooltips appear in the RemoteApp window.
Improves an access control list (ACL) check for Known Folders to prevent a black screen that appears the first time a user signs in after installing a feature or quality update.
Addresses an issue with evaluating the compatibility status of the Windows ecosystem to help ensure application and device compatibility for all updates to Windows.
Addresses issue with Autopilot self-deploying mode and White glove deployments.
Addresses an issue in which the pszTargetName parameter was set incorrectly in the InitializeSecurityContext() API.
Addresses an issue that causes the Start menu, the Cortana Search bar, Tray icons, or Microsoft Edge to stop responding in certain scenarios after installing a monthly update.
https://support.microsoft.com/fr-fr/hel ... -kb4522355
KB4522355
Un redémarrage est requis.
La version Windows 10 passe à 18362.449
J@M3S
Re: Mise à jour cumulative KB4522355 - Windows 10 - version 1903 - 19H1 - 18362.449
Message par J@M3S »
Bonsoir chantal11 ;) ,
Exécuté sans problème chez moi et vite fait. :super:
Points forts
• Met à jour un problème empêchant Microsoft Narrator de fonctionner dans certains scénarios en mode tactile.
• Met à jour un problème qui lance une technologie d'assistance (telle que Microsoft Narrator, Magnifier ou NVDA) après la connexion lorsque vous l'avez configuré pour le démarrage avant la connexion.
• Met à jour un problème qui empêche la Loupe de fonctionner dans certains scénarios et vous devez le redémarrer manuellement.
• Met à jour un problème entraînant l'arrêt de Microsoft Narrator au milieu d'une session dans certains scénarios.
• Met à jour un problème susceptible d'empêcher la sélection d'une barre de défilement.
• Met à jour un problème qui permet à un périphérique de passer en veille (S3) même si vous le configurez pour qu'il ne dorme jamais.
• Met à jour un problème qui vous empêche de réduire une fenêtre dans certains cas.
• Met à jour un problème qui vous empêche de vous connecter à un réseau privé virtuel (VPN).
• Met à jour un problème qui provoque un scintillement de l'écran ou qui tarde à l'afficher lorsque vous affichez des miniatures d'application sur un moniteur dont le nombre de points par pouce (DPI) est élevé.
• Met à jour un problème qui fait que la vignette de l'application Photos apparaît plus grande que prévu dans le menu Démarrer dans certaines conditions.
• Met à jour un problème provoquant l'arrêt du système dans l'écran de connexion.
• Met à jour un problème pouvant entraîner l'affichage d'un écran noir lors de votre première connexion après l'installation d'une mise à jour de fonctionnalité ou de qualité.
• Met à jour un problème entraînant l'arrêt du menu Démarrer, de la barre de recherche Cortana, des icônes de la barre d'état système ou de Microsoft Edge dans certains scénarios après l'installation d'une mise à jour mensuelle.
Améliorations et corrections
Cette mise à jour non liée à la sécurité inclut des améliorations de la qualité. Les changements clés incluent:
• Résolution d'un problème lié au comportement de l'en-tête HTTP d'origine lorsque vous utilisez Internet Explorer pour effectuer des demandes de partage de ressources inter-origine (CORS) afin de rediriger des ressources dans des sous-réseaux internes.
• Résolution d'un problème empêchant Microsoft Narrator de fonctionner dans certains scénarios en mode tactile.
• Résolution d'un problème de synchronisation des paramètres depuis la page Comptes lorsque la stratégie de groupe "Continuer les expériences sur ce périphérique" est désactivée.
• Résolution d'un problème qui déclenche une technologie d'assistance (AT) (telle que Microsoft Narrator, Magnifier ou NVDA) après la connexion lorsque le paramètre Facilité d'accès est requis pour démarrer AT avant de se connecter.
• Répond à un message d'erreur qui apparaît lorsque vous ouvrez une application après avoir activé NTVDM (NT Virtual DOS Machine) et le mode de console hérité. Le message d'erreur est "OACClearArry: impossible de se connecter au serveur Trace32 OLE Automation. Code d'erreur: -2147483645."
• Résolution d'un problème qui empêche la Loupe de fonctionner dans certains scénarios et que l'utilisateur doit redémarrer manuellement.
• Met à jour les informations de fuseau horaire pour l'île Norfolk, en Australie.
• Met à jour les informations de fuseau horaire pour les îles Fidji.
• Résolution d'un problème qui empêche Microsoft Narrator de fonctionner au milieu d'une session utilisateur dans certains scénarios.
• Résout un problème qui ne permet pas de définir la couleur de la fenêtre d'invite de commandes par défaut lorsque vous utilisez la commande color sans paramètre.
• Résout un problème qui oblige Microsoft Search Indexer (searchindexer.exe) à ajouter ou à réparer des listes de contrôle d'accès requises sans vérifier l'existence de listes de contrôle d'accès.
• Résolution d'un problème empêchant le rendu correct par intermittence des contrôles dans les applications Win32 lorsqu'il est démarré à partir d'un script de déconnexion à l'aide de la stratégie "Exécuter les scripts d'arrêt visibles".
• Résolution d'un problème en raison duquel l'installation de nombreuses polices dans le système entraîne le blocage des applications.
• Résolution d'un problème d'utilisation intensive du processeur dans Desktop Window Manager (dwm.exe) lorsque vous vous déconnectez d'une session RDP (Remote Desktop Protocol).
• Résolution d'un problème susceptible d'empêcher la sélection d'une barre de défilement lorsqu'un contrôle ActiveX implémente la classe CScrollView. Cela se produit si vous déplacez la fenêtre Internet Explorer, qui déplace ensuite la barre de défilement vers la gauche.
• Résolution d'un problème qui permet au système de passer en veille (S3) après deux minutes d'inactivité, même si vous configurez la minuterie de veille pour ne jamais dormir.
• Résolution d'un problème empêchant les utilisateurs de réduire la taille d'une fenêtre dans certains cas.
• Résolution d'un problème qui entraîne une mauvaise représentation des noms de fichiers Microsoft SharePoint dans les dossiers Accès rapide et Éléments récents.
• Résolution d'un problème qui vous empêche d'établir des connexions de réseau privé virtuel (VPN).
• Résout un problème qui provoque un scintillement de l'écran ou qui tarde à l'afficher lorsque vous affichez des vignettes d'applications sur des moniteurs de points par pouce (DPI).
• Résolution d'un problème d'autorisations incorrectes sur les clés de registre de classes d'un utilisateur empêchant les utilisateurs d'ouvrir des fichiers, des liens et des applications.
• Résolution d'un problème en raison duquel la vignette de l'application Photos apparaît plus grande que prévu dans le menu Démarrer dans certaines conditions.
• Résout un problème qui empêche le système de répondre à l'écran de connexion.
• Résolution d'un problème lié à la stratégie de déverrouillage multifacteur de Windows Hello for Business, qui n'indique pas l'option de connexion par défaut sur les périphériques Windows 10.
• Résolution d'un problème entraînant la fermeture inattendue de Windows Search lorsqu'une stratégie de groupe applique des sous-groupes à la présentation du menu Démarrer.
• Résolution d'un problème qui vous empêche de récupérer les informations DHCP correctes en configurant les paramètres DHCP LeaseTerminatesTime et LeaseObatinedTime au format correct.
• Résout un problème de traitement des données de diagnostic lorsqu'un périphérique a le paramètre Données de diagnostic activé et défini sur Basique.
• Résolution d'un problème empêchant Internet Explorer de s'ouvrir lorsque Microsoft User Experience Virtualization (UE-V) est utilisé pour parcourir de nombreux favoris.
• Résolution d'un problème qui améliore la fiabilité du UE-V AppMonitor.
• Résout un problème pour lequel Microsoft AppLocker pourrait empêcher une application de s'exécuter ou consigner une erreur fausse positive au lieu de l'exécuter.
• Résolution d'un problème empêchant netdom.exe d'afficher le nouveau bit de délégation TGT (Ticket-Grant Ticket) pour le mode d'affichage ou le mode de requête.
• Résolution d'un problème pouvant amener les serveurs à accès direct à utiliser une grande quantité de mémoire de réserve non paginée (pooltag: NDnd).
• Résolution d'un problème lié aux règles de pare-feu AppContainer qui fuient lorsque des utilisateurs invités ou des utilisateurs de profil utilisateur obligatoires se connectent et se déconnectent de Windows Server.
• Résolution d'un problème empêchant le mode de maintenance du filtre d'écriture unifié (UWF) de Windows Update de fonctionner avec le serveur Windows Server Update Services (WSUS).
• Résout un problème qui cause tous les problèmes de contrôle de transmission.
Mathusalem
Message par Mathusalem »
Bonjour ,
Mise à jour installée sans problème . Merci ,
Math
Pour moi échec de la mise à jour !
J'ai essayé de nouveau, re échec.
J'ai tenté la mise à jour par le Catalogue Microsoft Update, et là également, toutes les mises à jour n'ont pas été effectuées.
Capture MAJ KB4522355.JPG (40.36 Kio) Vu 2402 fois
J'y retournerai plus tard.
Essaie les solutions d' Aski:
https://answers.microsoft.com/fr-fr/win ... 2e7c7cce8e
greg250
Message par greg250 »
Bonjour,mon dieu que ça devient long! Il faudra d’ailleurs qu'un jour on m'explique pourquoi j'ai droit à 2 installations quasiment à chaque fois de la Kb , alors qu'elle arrive à 100% a chaque fois! M'enfin c'est installé aprés de très longues minutes, Greg! :oops:
J'ai aussi constaté parfois ce doublon il n'y a rien d'anormal.
Le téléchargement et installation des mises à jour de certaine KB (MJC) importante se font parfois en plusieurs fois.
Une partie pour mettre à jour, l'autre pour la correction, c'est la même MAJ, mais elle se déroule en deux fois.
Pour ton erreur je te conseille de faire une réparation des composants du magasin de Windows
En ligne de commande avec Windows PowerShell (admin)
Puis copier/coller la commande suivante:
Dism /Online /Cleanup-Image /RestoreHealth >> valide avec la touche Entrée
Cette opération peut prendre plusieurs minutes.
Il faut attendre le message 100% (La restauration a été effectuée. L’opération a réussi)
Puis faire aussi pour les erreurs du système de faire une réparation.
Même procédure Windows PowerShell (admin) avec la commande sfc /scannow
greg250
Salut tomtom95! Ce qui m’interpelle c’est que pour moi 100% c’est 100%! Qu’ils mettent 100% part 1 et 2 par exemple, je comprendrait. C’est comme lors d’une installation logiciels où on te dis « fin de l’installation dans 1minute », installation qui prend fin plutôt 10 minutes après ! Je chipote un peu mais ils prennent tout de même beaucoup de liberté ! :lol: J’en connais d’ailleurs,(moins qu’avant), qui interrompaient le processus pensant à tort que c’était buggé ! :D
Merci Mwonex pour ta réponse. J'ai essayé la méthode d'Aski, mais rien n'a changé.
J'ai ensuite fait une restauration à partir d'un point que j'avais créé début octobre, et il a fallu 5 heures pour finaliser cette restauration, 4 heures pour l'initialisation de la restauration des fichiers système, et une heure pour la restauration du registre ..... OUF !!!
La récompense est que cela a bien fonctionné, que j'ai installé les mises à jour précédentes, et enfin la dernière, la KB45222355.
Le seul souci a été le temps d'exécution de cette fichue restauration.
Merci et @+
Bonjour Tony,
Désolé que ça n'ai pas fonctionné, le mieux pour restaurer, je crée un point tous les 2/3 jours et je supprime les plus anciens.
Garder 5 ou 7 points est suffisant. Plus tu remontes dans le temps, plus c'est long.
Merci du retour, il y a sans doute d'autres moyens...peut être la solution de TomTom ?
