Improved zero-hour detection – pinpoints new threats as they arise and before they can wreak havoc on your device
Expanded malware detection – blocks even more malware for improved protection
Signature-less behavioral detection – identifies the latest variants of dangerous malware families that attempt to evade traditional signatures through runtime packing, obfuscation and encryption, offering instant protection against new threats that traditional AV has a hard time detecting
Faster threat definition process – streamlines the publishing of new definitions, reducing the time it takes to protect you from new threats
Revamped user interface – Completely redesigned user interface that is intuitive, more informative and simple to use
Threat statistics – allows you to see what Malwarebytes is doing for you in real-time and get a first-hand view of what threats are coming at you (and being blocked)
Cybersecurity news – dynamic feed keeps you informed of the latest threats and other security topics
Easier updates – more automation means you receive the latest protection with less effort
Malwarebytes annonce qu'au vu des améliorations apportées à la version 4, le programme remplacera Windows Defender par défaut et qu'il faudra modifier ce paramètre dans le centre de sécurité si cela ne convient pas : (ce scénario ne se présentera pas dans le cadre d'une mise à niveau de la version 3 vers la 4, uniquement pour une nouvelle installation de Malwarebytes 4)
Is Malwarebytes 4.0 Premium an anti-virus replacement?
With Malwarebytes 4.0 we are releasing brand new detection technology as part of our Anti-Malware protection. This detection technology further bridges the gap between Malwarebytes and traditional anti-virus, and allows Malwarebytes to now not only detect more zero-hour malware immediately upon seeing it, but also lets us catch more legacy-style malware. Based on our testing, Malwarebytes 4.0 Premium alone provides excellent protection against today’s threat landscape. We believe in layered defense and built Malwarebytes 4.0 Premium to provide the right mix of proactive and signature-less technologies to combat modern threats and zero-day malware. The combination of our Anti-Malware, Anti-Exploit, Anti-Ransomware, Website Protection, and Remediation technologies provides better coverage against modern and zero-day threats than the traditional antivirus companies that charge more for less effective protection.
Since Malwarebytes 4.0 Premium is an anti-virus replacement, will it register itself in Windows Security Center in order for Windows to recognize it as security software?
With any new install Malwarebytes 4.0’s new default behavior is to register in Windows Defender Security Center (also known as Windows Security Center, Windows Action Center) as a primary line of defense. Due to Microsoft’s implementation of Windows Defender Security Center, this means that Windows Defender will disable itself as a result (depending on your operating system). However, if you prefer to run Malwarebytes alongside any other traditional antivirus (including Windows Defender, Symantec or McAfee) you can disable the Windows Security Center setting in Security Settings within Malwarebytes 4.0. This will prevent Malwarebytes from registering in Windows Security Center and either your secondary antivirus or Windows Defender will show as registered. Malwarebytes 4.0 will continue to run seamlessly alongside these other solutions in compatibility mode.
Breizh
Dans mon cas j'ai ceci après mise à jour vers la V4 (premium):
Capture-ajouter malwarebytes dans le centre de sécurité Windows.JPG (24.73 Kio) Consulté 55363 fois
Dois-je "ajouter" malwarebytes ou le laisser ainsi en démarrage différé dans Windows?
Capture-malwarebytes retardé de 15 scondes.JPG (28.96 Kio) Consulté 55363 fois
Malwarebytes 4.0.4.49
Nouvelle mise à jour du pack de composants version 1.0.764 .
Après un scanne récent avec l'outil.
Dans l'interface de Malwarebytes Cliquer sur la roue crantée.
Puis sur sur l'onglet à propos et sur Rechercher les mises à jour.
Malwarebytes 4.0.4.49 - Nouvelle version du pack de composants 1.0.770
La mise à jour se fait normalement automatiquement mais vous pouvez aussi la faire manuellement en lançant Malwarebytes et via Paramètres > Application > Mises à jour d'application > Installer les mises à jour d'application
Nouvelle mise à jour du pack de composants version 1.0.781 .
La mise à jour se fait normalement automatiquement mais vous pouvez aussi la faire manuellement.
