Mise à jour cumulative KB4532695 - Windows 10 - version 1903 et 1909 - 18362.628 et 18363.628
La mise à jour cumulative KB4532695 est disponible via Windows Update pour Windows 10 - version 1903 (19H1) - 18362.628 et version 1909 (19H2) - 18363.628
Highlights
Improves the accuracy of Windows Hello face authentication.
Updates an issue that changes the user-customized order of tiles in the Start menu even though the layout is locked or partially locked.
Updates an issue that causes a grey box to appear when you search within Control Panel and File Explorer.
Updates an issue that prevents File Explorer's Search Bar from pasting clipboard content using the right mouse button (right-click).
Updates an issue that prevents File Explorer's Search Bar from receiving user input.
Updates an issue that causes the touch keyboard to close when you select any key.
Updates an issue that, in certain cases, causes multiplayer PC games to drop the invitation to play the game in multiplayer mode.
Updates an issue that sometimes causes an error when you unplug a USB type C hub flash drive.
Updates an issue that displays incorrect indicators for offline and online files.
Improvements and fixes
Windows 10, version 1909
This build includes all the improvements from Windows 10, version 1903.
Addresses an issue that prevents File Explorer's Search Bar from pasting clipboard content using the right mouse button (right-click).
Addresses an issue that prevents File Explorer's Search Bar from receiving user input.
Addresses an issue with Windows Mixed Reality that occurs after upgrading to a new version of Microsoft Edge.
Addresses an issue with download notifications that have multiple short-duration tabs and redirects.
Addresses an issue that changes the user-customized order of tiles in the Start menu even though the layout is locked or partially locked.
Addresses an issue that causes a grey box to appear when you search within Control Panel and File Explorer.
Addresses an issue with a memory leak in ctfmon.exe that occurs when you refresh an application that has an editable box.
Addresses a keyboard reliability issue for classic apps in the Windows Mixed Reality home.
Addresses an issue that, in some instances, prevents the Language Bar from appearing when the user signs in to a new session. This occurs even though the Language Bar is configured properly.
Addresses an issue that causes the touch keyboard to close when you select any key.
Addresses an issue that prevents software Indirect Display drivers from being signed with more than one certificate.
Addresses an issue that, in certain cases, causes multiplayer PC games to drop the invitation to play the game in multiplayer mode.
Addresses an issue with unsigned program files that will not run when Windows Defender Application Control is in Audit Mode, but will allow unsigned images to run.
Addresses an issue that causes the Local Security Authority Subsystem Service (LSASS) process to stop working when you sign in using an updated user principal name (UPN) (for example, changing UserN@contoso.com to User.Name@contoso.com). The error code is, “0xc0000005 (STATUS_ACCESS_VIOLATION).”
Addresses an issue that sometimes causes an error when you unplug a USB type C hub flash drive.
Addresses an issue with the Always On Virtual Private Network (VPN) that fails to remove the Name Resolution Policy Table (NRPT) rules after you disconnect.
Addresses an issue that might cause the Print Management console to display script errors when you enable the Extended View option.
Addresses an issue that causes the Windows firewall to drop network traffic from Modern apps, such as Microsoft Edge, when you connect to a corporate network using a virtual private network (VPN).
Addresses an issue that displays incorrect indicators for offline and online files.
Addresses an issue with ntdsutil.exe that prevents you from moving Active Directory database files. The error is, “Move file failed with source <original_full_db_path> and Destination <new_full_db_path> with error 5 (Access is denied.)”
Addresses an issue in which netdom.exe fails to correctly identify trust relationships when an unconstrained delegation is explicitly enabled by adding bitmask 0x800 to the trust object. The bitmask setting is required because of security changes to the default behavior of unconstrained delegations in Windows updates released on or after July 8, 2019. For more information, see KB4490425 and 6.1.6.7.9 trustAttributes.
Addresses an issue with evaluating the compatibility status of the Windows ecosystem to help ensure application and device compatibility for all updates to Windows.
Addresses an issue that might cause the Application Virtualization (App-V) Streaming Driver (appvstr.sys) to leak memory when you enable Shared Content Store (SCS) mode.
Addresses an issue that corrupts a log file when a storage volume is full and data is still being written to the Extensible Storage Engine Technology (ESENT) database.
Addresses an issue in which code refactoring breaks optimization for writing metadata, which increases Logical Volume Integrity Descriptors (LVID).
https://support.microsoft.com/fr-fr/hel ... -kb4532695
KB4532695
Un redémarrage est requis.
La version Windows 10 passe à 18362.628 pour la version 1903 et 18363.628 pour la version 1909
greg250
Re: Mise à jour cumulative KB4532695 - Windows 10 - version 1903 et 1909 - 18362.628 et 18363.628
Message par greg250 »
Merci Chantal, installation faite sur le Pc fixe et se faisant sur le portable sans accroc! Greg. :super:
Mathusalem
Message par Mathusalem »
Bonjour ,
Merci pour l' information . Chargement et installation très rapide . RAS .
Math
Merci pour l'info.
Opération réussie rapidement sans difficultés. :super:
Message par BORTA77 »
Merci Chantal :)
Fait également sur mes 2 PC , sans problème pour le portable et quelques soucis sur la tour avec un retour à un point de restauration antérieur , désactivation de mon anti virus tiers ( Norton ) et réinstallation par Windows update . J'avais également eu les mêmes soucis pour la dernière maj .
micpal
Message par micpal »
Merci chantal
installation faite sur mes 2 PC sans problème particulier
Tout est bien à jour, malheureusement il manque le menu contextuel de Windows Defender sur la tour ou j'ai réinstallé Windows 10 laborieusement, alors, reste la "mise à niveau sans perte de données" avec L'ISO de MediaCreationTool??
Télécharger la dernière mise à jour ici première ligne 64 bits et la réinstaller suffirait il?
http://www.catalog.update.microsoft.com ... =KB4532695
Je télécharge toujours la dernière version (que je dois avoir en triple* :( )
Tout le reste est OK
Edité 18:50:
Pas de changement pas de menu contextuel pour Windows defender sous compte Microsoft également
Capture-manque menu contextuel de Windows defender.PNG (29.18 Kio) Vu 1579 fois
RÉSOLU ici:
discussions-generales-f21/topic6082.html#p34611
