Mise à jour cumulative KB4550945 - Windows 10 - version 1903 et 1909 - 18362.815 et 18363.815
La mise à jour cumulative KB4550945 est disponible via Windows Update pour Windows 10 - version 1903 (19H1) - 18362.815 et version 1909 (19H2) - 18363.815
Highlights
Updates an issue that prevents certain apps from opening after you upgrade from a previous version of Windows, and a Bad Image error message appears.
Updates in an issue that turns off notifications for devices that use a virtual private network (VPN) on a cellular network.
Updates an issue that prevents you from resuming a Microsoft Xbox game on a Windows device after upgrading from a previous version of Windows.
Updates an issue that causes a text box that contains multiple lines of text to stop responding in certain scenarios.
Updates an issue that generates unexpected notifications when you change the default application settings.
Updates an issue that causes Windows Update to stop responding when you check for updates.
Updates an issue that fails to print content that is outside of the margins of a document.
Improvements and fixes
Windows 10, version 1909
This build includes all the improvements from Windows 10, version 1903.
No additional issues were documented for this release.
Addresses an issue that prevents certain apps from opening after you upgrade from a previous version of Windows, and a Bad Image exception dialog box appears.
Addresses in an issue that turns off notifications for devices that use a virtual private network (VPN) on a cellular network.
Addresses an issue that prevents you from resuming a Microsoft Xbox game on a Windows device after upgrading from a previous version of Windows.
Addresses an issue that causes a box that contains multiple lines of text to stop responding in certain scenarios.
Addresses an issue that prevents the touch keyboard from appearing during sign in when the user is prompted for the password.
Addresses an issue that prevents the touch keyboard from opening in Universal Windows Platform (UWP) apps when USB devices are connected.
Addresses an issue that displays incorrect folder properties in File Explorer when the path is longer than MAX_PATH.
Addresses an issue that prevents the correct lock screen from appearing when all of the following are true:
The Group Policy Object (GPO) policy "Computer Configuration\Windows Settings\Security Settings\Local Policies\Security Options\Interactive Logon: Do not require Ctrl+Alt+Del Computer" is disabled.
The GPO policy “Computer Configuration\Administrative Templates\System\Logon\Turn off app notifications on the lock screen” is enabled.
The registry key HKLM\SOFTWARE\Policies\Microsoft\Windows\System\DisableLogonBackgroundImage is set to 1.
Addresses an issue that generates unexpected notifications related to changing the default application settings.
Addresses an issue that causes the sign in screen to be blurry.
Addresses an issue that causes Windows Update to stop responding when you check for updates.
Addresses an issue that prevents the Sign in options page from opening using the ms-settings:signinoptions-launchfingerprintenrollment Uniform Resource Identifier (URI).
Addresses an issue with Bluetooth group policy settings on Microsoft Surface Pro X devices.
Addresses an issue that causes a KERNEL_SECURITY_CHECK_FAILURE (139) stop error when Windows resumes from Sleep and turns on certain Bluetooth headsets.
Addresses a reliability issue in WDF01000.sys.
Addresses an issue that causes an error in logman.exe. The error is, "A user account is required in order to commit the current Data collector Set properties."
Addresses an issue that prevents users from setting the REG_EXPAND_SZ keys in some automated scenarios.
Addresses an issue that causes a memory leak in the LsaIso.exe process when the server is under a heavy authentication load and Credential Guard is enabled.
Addresses an issue that causes the Trusted Platform Module (TPM) initialization to fail with system event error 14 and prevents Windows from accessing the TPM.
Addresses an issue that causes communication with the TPM to time out and fail.
Addresses an issue that prevents hash signing using the Microsoft Platform Crypto Provider for TPMs from working correctly. This issue might also affect networking software, such as VPN applications.
Addresses an issue that prevents applications running in an Azure Active Directory environment from receiving account change notifications. This occurs when using the Web Account Manager (WAM) and the WebAccountMonitor API.
Addresses an issue that causes systems to stop working with a 0x3B stop code when running a binary that is signed by a revoked certificate.
Addresses an issue with merging Windows Defender Application Control policies that sometimes generates a duplicate rule ID error and causes the Merge-CIPolicy PowerShell command to fail.
Addresses an issue that prevents a user’s PIN from being changed after connecting the device to Microsoft Workplace Join.
Addresses an issue that fails to print content that is outside of the margins of a document.
Addresses an issue that prevents Microsoft Internet Information Services (IIS) management tools, such as IIS Manager, from managing an ASP.NET application that has configured SameSite cookie settings in web.config.
Addresses an issue that causes Microsoft Edge to stop working if you attempt to use paste functionality on webpages when cut-and-paste functionality has been disabled using a policy and Windows Defender Application Guard is active.
Addresses an issue that causes the Clipboard service to unexpectedly stop working.
https://support.microsoft.com/fr-fr/hel ... -kb4550945
KB4550945
Un redémarrage est requis.
La version Windows 10 passe à 18362.815 pour la version 1903 et 18363.815 pour la version 1909
greg250
Re: Mise à jour cumulative KB4550945 - Windows 10 - version 1903 et 1909 - 18362.815 et 18363.815
Message par greg250 »
Bonjour Chantal, MAJ faite sur le portable sans problème, un peu long mais tout est OK! Greg.
micpal
Message par micpal »
Bonjour à tous
Mise à jour faite sur mes deux PC sans soucis
Merci chantal11
Idem pour moi sur mes 2 machines.
Un peu long, mais RAS ! :super:
Merci Chantal11
greg250
Re, idem pour le fixe et no problème!Greg. :super:
J'ai aussi installé les updates sur mes machines ...
5 x PC réel = ok
I5 6600 Win10-64 UEFI
AMD A9 Win10-64 UEFI
AMD A10 Win10-64 UEFI
Intel dualcore E4400 Win10-32 BIOS
Intel core2 6600 Win10-64 BIOS
4 x PC virtuel OK (Virtualbox)
Win10-32 UEFI
Win10-64 UEFI
Win10-32 BIOS
Win10-64 BIOS
Le 5ème (Virtualbox) est OK, mais un truc bizarre dans les dates :bizar:
Win10-64 BIOS en Néerlandais
Win10-64 NL.png (85.94 Kio) Vu 1407 fois
Cela reste après redémarrage en indiquant que le PC est à jour.
C'est franchement super d'avoir en 2020 des mises à jour installées pour 2194 :mdr:
