Mise à jour cumulative KB4565503 - Windows 10 - version 2004 - 19041.388
La mise à jour cumulative KB4565503 est disponible via Windows Update pour Windows 10 - version 2004 (20H1) - 19041.388
Highlights
Improves security in the Microsoft Store.
Updates to improve security when using input devices (such as a mouse, keyboard, or stylus).
Updates to improve security when Windows performs basic operations.
Updates for storing and managing files.
Updates an issue that might cause certain games and applications to have visual distortion when resizing in windowed mode or switching from full screen to window mode.
Updates to improve security when using Internet Explorer and Microsoft Edge Legacy.
Updates an issue that might prevent some applications from printing documents that contain graphics or large files.
Updates an issue that might prevent you from connecting to OneDrive using the OneDrive app.
Improvements and fixes
Addresses an issue in certain apps that use the ImeMode property to control Input Method Editor (IME) mode in Windows 10, version 2004 (the May 2020 Update). For example, this issue prevents input mode from automatically switching to Kanji or Hiragana. For more information, see KB4564002 and the blog post, Getting the May 2020 Update Ready for Release - UPDATED.
Addresses an issue that might prevent you from using PowerShell to change the system locale on Server Core platforms.
Addresses an issue that might cause certain games and applications to have visual distortion when resizing in windowed mode or switching from full screen to window mode.
Addresses an issue that might cause lsass.exe to fail with the error message, “A critical system process, C:\WINDOWS\system32\lsass.exe, failed with status code c0000008. The machine must now be restarted."
Addresses an issue that might prevent some applications from printing documents that contain graphics or large files after installing Windows Updates released June 9, 2020.
Addresses an issue that might prevent you from connecting to OneDrive using the OneDrive app. This issue occurs on some older devices or on devices that have older apps, which use legacy file system filter drivers. As a result, this might prevent these devices from downloading new files or opening previously synced or downloaded files.
Security updates to the Microsoft Scripting Engine, Windows App Platform and Frameworks, the Microsoft Store, Windows Graphics, Windows Input and Composition, Windows Media, Windows Shell, Windows Fundamentals, Windows Management, Windows Kernel, Windows Hybrid Cloud Networking, Windows Storage and Filesystems, Windows Update Stack, Windows MSXML, Windows File Server and Clustering, Windows Remote Desktop, Internet Explorer, Microsoft Edge Legacy, and the Microsoft JET Database Engine.
This security update includes quality improvements. Key changes include:
https://support.microsoft.com/fr-fr/hel ... -kb4565503
KB4565503
Un redémarrage est requis.
La version Windows 10 passe à 19041.388
Mathusalem
Re: Mise à jour cumulative KB4565503 - Windows 10 - version 2004 - 19041.388
Message par Mathusalem »
Bonjour ,
Mise à jour proposée , puis installée sans problème . R.A.S , merci .
Cdt ,
Math
De mon côté la KB4565503 s'est installée sans souci, mais auparavant, la Mise à jour cumulative pour .NET Framework 3.5 and 4.8 (KB4565627) a été très récalcitrante, le redémarrage ne se faisait pas.
greg250
Message par greg250 »
Merci Chantal! 2 petites remarques sur cette KB, sur mon pc portable j'ai remarqué, alors que j'attendais l'installation de la Kb et celle du Framework, qu'il y avait un "bouton" Installer maintenant! Que j'ai "pressé" aussitôt. Sur le fixe, à la fin de l'installation, j'ai eu droit à un "nettoyage", de quoi? Sinon parfaitement installée et rapidement! Greg. :super:
Message par BORTA77 »
J'ai été averti ce matin et l'installation s'est faite sans souci .
Merci Chantal
