Mise à jour cumulative facultative KB4568831 - Windows 10 - version 2004- 19041.423
La mise à jour cumulative KB4568831 facultative est disponible via Windows Update pour Windows 10 - version 2004 (19H2) - 19041.423
Paramètres > Mise à jour et sécurité> Windows Update > Mises à jour facultatives > Autres Mises à jour > Cocher la case pour Télécharger et installer
Highlights
Updates an issue with pasting mixed content of images and text from Microsoft Word into Internet Explorer.
Updates an issue that might cause the Magnifier to stop working in Microsoft Excel in certain scenarios. As a result, Microsoft Excel might also stop working.
Updates an issue that might display 4K high dynamic range (HDR) content darker than expected when you configure certain non-HDR systems for HDR Streaming.
Updates an issue that causes the Settings page to close unexpectedly, which prevents default applications from being set up properly.
Updates an issue that prevents some applications from printing to network printers.
Updates an issue that might prevent internet connectivity on some cellular modems after upgrading to Windows 10, version 2004.
Updates an issue that prevents family safety features, such as time limits and activity reporting, from working on ARM64 devices.
Improvements and fixes
Addresses an issue that prevents you from using sharing functionality in Microsoft Office. This occurs when Conditional Access is enabled.
Addresses an issue that occurs when a third-party application loads hidden tabs into Internet Options.
Addresses an issue in Microsoft Edge IE mode that occurs when you open multiple documents from a SharePoint site.
Addresses an issue in Microsoft Edge IE mode that occurs when you browse using anchor links.
Addresses an issue with pasting mixed content of images and text from Microsoft Word into Internet Explorer.
Addresses an issue that might cause Microsoft browsers to incorrectly bypass proxy servers.
Addresses an issue in the Windows Push Notification (WNS) service that prevents you from selecting a virtual private network (VPN) interface to make outbound connections. As a result, you lose connectivity with the WNS service when forced tunneling is used.
Addresses an issue that might cause the Magnifier to stop working in Microsoft Excel in certain scenarios. As a result, Microsoft Excel might also stop working.
Addresses an issue that prevents you from installing some .msi apps. This occurs when a device is managed by a Group Policy that redirects the AppData folder to a network folder.
Addresses an issue that might display 4K high dynamic range (HDR) content darker than expected when you configure certain non-HDR systems for HDR Streaming.
Addresses an issue that causes new child windows to flicker and appear as white squares on server devices that are configured for stark visual contrast.
Addresses an issue that causes the Settings page to close unexpectedly, which prevents default applications from being set up properly.
Addresses an issue that causes all open Universal Windows Platform (UWP) apps to close unexpectedly. This occurs when their installer calls the Restart Manager to restart File Explorer (explorer.exe).
Addresses an issue that prevents Windows 8.1 apps from projecting to a secondary display when those apps use the StartProjectingAsync API.
Addresses an issue that prevents family safety features, such as time limits and activity reporting, from working on ARM64 devices.
Addresses an issue with File Explorer’s preview of .msg files when Microsoft Outlook 64-bit is installed.
Addresses an issue that causes a KERNEL_SECURITY_CHECK_FAILURE (139) stop error when Windows resumes from Sleep and turns on certain Bluetooth headsets.
Addresses an issue that might prevent certain display driver reset utilities from properly reinstalling the same driver on the system.
Addresses a reliability issue in WDF01000.sys.
Addresses an issue that causes memory leaks when an application calls the CryptCATAdminCalcHashFromFileHandle() function. The leaked memory is reclaimed when the application closes.
Improves support for non-ASCII file paths for Microsoft Defender Advanced Threat Protection (ATP) Auto Incident Response (IR).
Addresses an issue that prevents some machines from automatically going into Sleep mode under certain circumstances because of Microsoft Defender ATP Auto IR.
Addresses an issue that prevents some machines from running Microsoft Defender ATP Threat & Vulnerability Management successfully.
Addresses an issue that prevents Microsoft Defender ATP from applying file exclusions in some cases, which leads to application compatibility issues.
Addresses an issue in Microsoft Defender ATP that prevents some machines from reporting the installed applications to Threat & Vulnerability Management.
Addresses an issue that causes automatic investigations to fail in Microsoft Defender ATP.
Improves Microsoft Defender ATP's ability to identify malicious code injection activities.
Addresses an issue that prevents some applications from printing to network printers.
Addresses an issue that might cause a printer to be a hidden device in Device Manager after a restart.
Addresses an issue that might cause the Print Management console to display script errors when you enable the Extended View option.
Addresses an issue that causes printing to fail in certain scenarios.
Addresses an issue that might prevent a Windows 10 device from reaching the internet when using a wireless wide area network (WWAN) LTE modem. However, the Network Connectivity Status Indicator (NCSI) in the notification area might still indicate that you are connected to the internet.
Addresses an issue that might prevent internet connectivity on some cellular modems after upgrading to Windows 10, version 2004.
Addresses an issue that causes telephony applications to lose the first four digits.
Addresses an issue with in-memory parity bitmaps that can cause data integrity issues on Parity Storage Spaces.
Addresses an issue that prevents the creation of a storage pool using Manage Storage Spaces in Control panel.
Addresses an issue that might cause the Microsoft Remote Assistance process (msra.exe) to stop working when a user is receiving assistance during a computer session. The error is 0xc0000005 or 0xc0000409.
https://support.microsoft.com/fr-fr/hel ... -kb4568831
KB4568831
Un redémarrage est requis.
La version Windows 10 passe à 19041.423
J@M3S
Re: Mise à jour cumulative facultative KB4568831 - Windows 10 - version 2004- 19041.423
Message par J@M3S »
Bonjour chantal11, :coucou:
Mise à jour sans problème et je mets en Fr car j'aime pas le rosbif (sauf dans l'assiette) :mdr:
Points forts
Met à jour un problème de collage de contenu mixte d'images et de texte de Microsoft Word dans Internet Explorer.
Met à jour un problème qui pourrait empêcher la loupe de fonctionner dans Microsoft Excel dans certains scénarios. Par conséquent, Microsoft Excel peut également cesser de fonctionner.
Met à jour un problème qui peut afficher le contenu 4K à plage dynamique élevée (HDR) plus sombre que prévu lorsque vous configurez certains systèmes non HDR pour la diffusion HDR.
Met à jour un problème qui entraîne la fermeture inattendue de la page Paramètres, ce qui empêche la configuration correcte des applications par défaut.
Met à jour un problème qui empêche certaines applications d'imprimer sur des imprimantes réseau.
Met à jour un problème qui pourrait empêcher la connectivité Internet sur certains modems cellulaires après la mise à niveau vers Windows 10, version 2004.
Met à jour un problème qui empêche les fonctionnalités de sécurité familiale, telles que les limites de temps et les rapports d'activité, de fonctionner sur les appareils ARM64.
Améliorations et corrections
Cette mise à jour non liée à la sécurité comprend des améliorations de qualité. Les principaux changements comprennent:
Résout un problème qui vous empêche d'utiliser la fonctionnalité de partage dans Microsoft Office. Cela se produit lorsque l'accès conditionnel est activé.
Résout un problème qui se produit lorsqu'une application tierce charge des onglets masqués dans les Options Internet.
Résout un problème en mode Microsoft Edge IE qui se produit lorsque vous ouvrez plusieurs documents à partir d'un site SharePoint.
Résout un problème en mode Microsoft Edge IE qui se produit lorsque vous naviguez à l'aide de liens d'ancrage.
Résout un problème lié au collage de contenu mixte d'images et de texte de Microsoft Word dans Internet Explorer.
Résout un problème qui pourrait amener les navigateurs Microsoft à contourner de manière incorrecte les serveurs proxy.
Résout un problème dans le service Windows Push Notification (WNS) qui vous empêche de sélectionner une interface de réseau privé virtuel (VPN) pour établir des connexions sortantes. Par conséquent, vous perdez la connectivité avec le
service WNS lorsque le tunneling forcé est utilisé.
Résout un problème qui pouvait empêcher la loupe de fonctionner dans Microsoft Excel dans certains scénarios. Par conséquent, Microsoft Excel peut également cesser de fonctionner.
Résout un problème qui vous empêche d'installer certaines applications .msi. Cela se produit lorsqu'un appareil est géré par une stratégie de groupe qui redirige le dossier AppData vers un dossier réseau.
Résout un problème qui peut afficher le contenu 4K à plage dynamique élevée (HDR) plus sombre que prévu lorsque vous configurez certains systèmes non HDR pour la diffusion HDR.
Résout un problème qui provoque le scintillement des nouvelles fenêtres enfants et leur affichage sous forme de carrés blancs sur les périphériques serveur configurés pour un contraste visuel saisissant.
Résout un problème qui entraîne la fermeture inattendue de la page Paramètres, ce qui empêche la configuration correcte des applications par défaut.
Résout un problème qui entraîne la fermeture inattendue de toutes les applications de la plateforme Windows universelle (UWP) ouvertes. Cela se produit lorsque leur programme d'installation appelle le gestionnaire de redémarrage pour
redémarrer l'Explorateur de fichiers (explorer.exe).
Résout un problème qui empêche les applications Windows 8.1 de se projeter sur un affichage secondaire lorsque ces applications utilisent l'API StartProjectingAsync.
Résout un problème qui empêche les fonctionnalités de sécurité familiale, telles que les limites de temps et les rapports d'activité, de fonctionner sur les appareils ARM64.
Résolution d'un problème lié à l'aperçu des fichiers .msg par l'Explorateur de fichiers lorsque Microsoft Outlook 64 bits est installé.
Résout un problème qui provoque une erreur d'arrêt KERNEL_SECURITY_CHECK_FAILURE (139) lorsque Windows sort du mode veille et active certains casques Bluetooth.
Résout un problème qui pourrait empêcher certains utilitaires de réinitialisation du pilote d'affichage de réinstaller correctement le même pilote sur le système.
Résout un problème de fiabilité dans WDF01000.sys.
Résout un problème qui provoque des fuites de mémoire lorsqu'une application appelle la fonction CryptCATAdminCalcHashFromFileHandle (). La mémoire perdue est récupérée lorsque l'application se ferme.
Améliore la prise en charge des chemins de fichiers non ASCII pour la réponse automatique aux incidents (IR) Microsoft Defender Advanced Threat Protection (ATP).
Résout un problème qui empêche certaines machines de passer automatiquement en mode veille dans certaines circonstances en raison de Microsoft Defender ATP Auto IR.
Résout un problème qui empêche certaines machines d'exécuter correctement Microsoft Defender ATP Threat & Vulnerability Management.
Résout un problème qui empêche Microsoft Defender ATP d'appliquer des exclusions de fichiers dans certains cas, ce qui entraîne des problèmes de compatibilité des applications.
Résolution d'un problème dans Microsoft Defender ATP qui empêche certaines machines de signaler les applications installées à Threat & Vulnerability Management.
Résout un problème qui entraîne l'échec des investigations automatiques dans Microsoft Defender ATP.
Améliore la capacité de Microsoft Defender ATP à identifier les activités d'injection de code malveillant.
Résout un problème qui empêche certaines applications d'imprimer sur des imprimantes réseau.
Résout un problème qui pourrait faire d'une imprimante un périphérique masqué dans le Gestionnaire de périphériques après un redémarrage.
Résolution d'un problème pouvant entraîner l'affichage d'erreurs de script dans la console de gestion de l'impression lorsque vous activez l'option Affichage étendu.
Résout un problème qui entraîne l'échec de l'impression dans certains scénarios.
Résout un problème qui pourrait empêcher un appareil Windows 10 d'accéder à Internet lors de l'utilisation d'un modem LTE de réseau étendu sans fil (WWAN). Cependant, l'indicateur d'état de la connectivité réseau (NCSI) dans la zone de
notification peut toujours indiquer que vous êtes connecté à Internet.
Résout un problème qui pourrait empêcher la connectivité Internet sur certains modems cellulaires après la mise à niveau vers Windows 10, version 2004.
Résout un problème qui entraîne la perte des quatre premiers chiffres des applications de téléphonie.
Résout un problème avec les bitmaps de parité en mémoire qui peuvent entraîner des problèmes d'intégrité des données sur les espaces de stockage de parité.
Résout un problème qui empêche la création d'un pool de stockage à l'aide de Gérer les espaces de stockage dans le panneau de configuration.
Résout un problème pouvant entraîner l'arrêt du processus d'assistance à distance Microsoft (msra.exe) lorsqu'un utilisateur reçoit une assistance pendant une session informatique. L'erreur est 0xc0000005 ou 0xc0000409.
Si vous avez installé des mises à jour antérieures, seuls les nouveaux correctifs contenus dans ce package seront téléchargés et installés sur votre appareil.
Nota:
Cette mise à jour remplace les mises à jour suivantes : (X64 uniquement pour ceux qui sont en 64 bits !)
2020-06 Cumulative Update for Windows 10 Version 2004 for x64-based Systems (KB4567523)
2020-06 Cumulative Update for Windows 10 Version 2004 for x64-based Systems (KB4557957)
2020-07 Cumulative Update for Windows 10 Version 2004 for x64-based Systems (KB4565503)
Merci ;)
greg250
Message par greg250 »
Bonjour, cette MAJ à été faite dans l'après midi hier sans que je n'intervienne (c'est plutôt curieux un samedi!) et ma version est: 19041.388. Greg.
greg250 a écrit :et ma version est: 19041.388
Non, ce n'est pas la bonne mise à jour
Le système doit être 19041.423
greg250
Bonjour Chantal, la version que je possède est celle qui à été installée. Je vais tenter de la faire de façon autonome ! Merci d'être sur le forum y compris les dimanches! Greg. :+1:
Merci chantal11 et aussi pour la traduction ;)
J'avais vu mentionné office (Word, Excel), je l'ai donc mis à jour sur le seul PC avec Office, est ce nécessaire pour tous les PC?
Car il y a beaucoup "d'indications" ou il est difficile de se repérer, mais rien que pour ça, ce serait bien de le faire, pourquoi facultatif alors?
J'ai failli la rater, en effet il faut aller dans les mises à jours facultatives.
Capture-Mises à jour facultatives.PNG (8.34 Kio) Vu 2213 fois
puis dans le carré choisir, enfin télécharger n'est plus grisé
Capture-cocher et installer maj facultative.PNG (12.01 Kio) Vu 2211 fois
Puis il y a demande de redémarrage ensuite après quelques secondes.
J'ai eu aussi une préversion de framework?
Capture-mise à jour facultatives_LI.jpg (140.32 Kio) Vu 2215 fois
En tous cas, ça ne pose pas de problèmes visibles, c'est déjà ça :D
greg250
Voila qui est fait! Hier c'était la KB 4562899 qui c'est installée : Préversion de la mise à jour cumulative pour NET Framework......etc..! Merci!
@ mwonex : je l'ai pourtant signalé qu'elle était planquée, j'avais même posté une capture ;)
C'est vrai Chantal, mais j'ai zappé la capture pensant m'y retrouver avec ton explication, ça a été le cas. ;)
J'ai refait les captures sur le portable ou elle n'étais pas installée pour greg250, en même temps, je n'ai pas eu de demande de redémarrage. Je l'ai fait quand même après un certain temps.
Bonne soirée
